Old 12-19-2011, 04:33 AM   #76
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
yeah... nathans rail has arrived
proovemounted..
Old 12-27-2011, 05:49 AM   #77
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah!
This is the ****
It screamed for this sticker so i couldnt resist ;)
Also hacked the shizz out of my intake to make the 960TB fit.. it was a real good pile of aluminum on my bench after finishing.. my goodness.. took some length of cigarettes...
Also if you want to make it fit you need to turn the shaft 180° or the desired poti wont fit.. the mountingplate for the 960poti can be unscrewed also.. but thats no problem cause you will clean it before mounting it arent you? so you have to disassemble it anyways...
all in all a real easy mod if you have the right powertools for aluminum... carbidegrinder wont work...
Old 01-23-2012, 04:05 AM   #78
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Bought some new, funneh stuff
80lb/850cc Siemens DEKA
Bosch 044 Main Pump
Walbro 255 intank knockoff but pretty good quality..
and some Bulkheads to make the intank fit under the tank cap
I never should have started with these AN-Fittings ^^
Old 01-23-2012, 04:29 AM   #79
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Hi..
one question... can this:
http://www.anfittingsdirect.com/prod...100ec1b232ac58
..replace the factory fuelfilter ?
Old 01-23-2012, 05:30 AM   #80
Roy 940
I think it's very small, but why not...
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 01-24-2012, 05:15 AM   #81
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
yeah.. that i could think by myself
Its more the question wheter somebody got some exp. with this?
Old 01-24-2012, 05:44 AM   #82
Roy 940
Why you need it? You can't use the stock filter?
Old 01-24-2012, 07:41 AM   #83
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
It's just because
:D
/i know such kinda Filter for air from our fire departments respiratory equipment... it uses a kind of brassfoam... so i could think of this clogs very fast?
Old 01-24-2012, 09:52 AM   #84
Roy 940
Originally Posted by MadDog_945 View Post
It's just because
:D
I think it don't be enough good, I mean it can't stop dirt < 10 micron...
Old 01-24-2012, 10:31 AM   #85
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
my intentention here was to use it right before the rail... ? does this minimize the flow?` i dont know.. it looks cool.. and if it protects the injectors from beeing clogged by stuff from the filter itself `?
Ah i dont know :D
Old 01-24-2012, 12:40 PM   #86
Not Naturally Aspirated
As I am slowly amassing my parts for a similar build, I read through this thread so thanks for the info/display of photos. Nice build btw and good on you!
Quick question though; on your first page of the thread regarding the block used for the build you write that it's a block w/o (without) oil squirters? However looking through the photos of the right side of the block, pls correct me if I'm wrong but, it seems to me that it physically looks like this block has the oil bosses for the squirters... or am I seeing a mirage?
Good build and good work...
Not Naturally Aspirated is offline   Reply With Quote
Old 01-24-2012, 12:51 PM   #87
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Use the stock filter, but put some AN adaptor fittings on it to your desired size?
Old 01-24-2012, 04:11 PM   #88
JW240
All idiot, no savant
you know that normal A2-70 stainless steel hardware is at best about as strong as class 8.8? Volvo studs are 10.9 or 12.9, much stronger. Would be a shame to rip the threads out of the cylinder head or just snap a bolt because the bolts stretch too much.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 02-01-2012, 07:05 PM   #89
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
those arent ss-bolts
its chromized 10.9 i think... but it holds good so y not?
btw... sneak preview..
Old 02-01-2012, 11:04 PM   #90
940 16 valve
940 16 valve's Avatar
Too small. can't see the picture! ;)
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 02-02-2012, 05:37 AM   #91
Roy 940
Engine is in???
Old 02-02-2012, 07:38 AM   #92
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
yes it is :D
im so excited... !!!
only a few issues with oil return and wastegate actuator but the downpipe fits like a boss to the firewall after adding the vband flange... shortened it 20mm before adding it...
unfortunatelythe flange warped extremelywhile being tiggd so i have to shave it again :(
sry for the big pic... uploaded it with ftp iphone crapapp
Old 02-02-2012, 07:41 AM   #93
Sander
Good news everyone!
Sander's Avatar
Nice! More pics please! :D
Old 02-02-2012, 07:49 AM   #94
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
made tons of stepbystep pics
my hands a wound only by cribbling off the gloves all the time to take a shot with the iphone ;)
16v turbos do look much more awesome in person as they aswell do on pics... arrrr
schon ein majestätisches tier ,so ein 16vt ;)
Old 02-02-2012, 08:14 AM   #95
Sander
Good news everyone!
Sander's Avatar
Genau!
Old 02-02-2012, 08:28 AM   #96
Roy 940
Old 02-02-2012, 08:59 AM   #97
tree18is
tree18is's Avatar
humans are suppose to be able to do alot of stuff, but I dont think I could do this
New r3v sig!
84 242 5.0 swap *in progress*
84 245 DD
91 m50 swap e30.. dd?
tree18is is offline   Reply With Quote
Old 02-03-2012, 01:14 PM   #98
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Weeeeeeeeeee
Im so over excited right now...
took a week holiday for this... but was in the evening too tired to upload the photos.. so.. here they are
Get the old one out...
more and more parts ripped off...
higher... higher....
the new one hanging around..
fits like a boss...
mh.. that looks not so good.. my TTV flywheel after 5000miles and 2 misleaded kickstarts.. :(
can you see the bling ? KL-Racing IC
2008... in the meantime... this is my new engine 4 years ago... wtf.. time runs...
Mh.. i could have done the lambda bung better by myself..
rly close.. but...
bended the 2 cores a little towards the engine after cutting a "rail" into the cover for the edge of the IC...
as said.. lika a boss
new tools arrived
with adapter for Volvo brakecylinders...
dads new 960 finally on the road again
Old 02-03-2012, 01:15 PM   #99
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
had to cut the WG bracket a bit to fit the frame
after twisting the core, coldside and IC piping finally its aligned...
but bought a 90° block instead of tube for the return.. might be too less space..
oilcooler... perfect location?
yep... i think so..
i think the trainee welded this... but mainthing is... no leaks..
here you can see how close the WG sits to the frame.. you see upcoming problems here ?
what a picture of misery :( he served me well since 2005 R.I.P. :( !
Old 02-03-2012, 05:46 PM   #100
BigBen
BigBen's Avatar
soo geil
BigBen is offline   Reply With Quote
