Old 01-07-2012, 03:05 AM   #101
propav8r
F*ck Edgar
propav8r's Avatar
Gonna throw a few more pics in for good measure.
Here's what the passenger floorboard looks like at the moment. Everything is...everywhere, but it's functional. I'll take some time and clean it up/shorten up wires next time I'm home from school.
Getting close to done under the hood. I still have to finalize my intercooler piping, paint the rad support, and re-install/bleed my brake system.
There are basically three separate connections in the ECU harness. One is for the ignition, and is a large four-pin GM Weatherpack near the wiper motor. Two smaller weatherpacks, one four-pin for the injector wiring, and the other 3-pin for the DSM CAS are situated here. Makes removing the harness fairly simple if needed, and came out as clean as I could get it with what was available to me.
Here you can see my harness routing. From left to right is the coil pack harness, the main harness, and the harness for the fuel injectors.
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 01-07-2012, 04:02 AM   #102
N/Avolvo
N/Avolvo's Avatar
Will that be up at western this semester? I demand a ride!
Nathan
-79 242 197K
-97 Nissan Hardbody 311k DD beater
-98 v70 190k-Sold
-81 K5 Blazer 4"lift suspension/3" body lift, 37" TSLs, 8000lb winch,bed lined interior....Sold
N/Avolvo is offline   Reply With Quote
Old 01-07-2012, 06:28 AM   #103
propav8r
F*ck Edgar
propav8r's Avatar
It'll hopefully make it up by semesters end.
Old 01-20-2012, 11:34 AM   #104
propav8r
F*ck Edgar
propav8r's Avatar
IPD Springs and Decarbons installed this past weekend...the boat-esque front end is banished! Pic related...the IPD springs were like half the height of the stockers, and only dropped the car .5". The second pic is how a 240 with fresh stock springs looks...I don't ever want to hear anyone say springs don't wear out ever again. Maybe in a perfect, controlled environment, they don't, but in the real world, oxidation happens.
Old 01-20-2012, 03:12 PM   #105
BoostIt
BoostIt's Avatar
pics of the front end drop pretty please!
'83 244tic - Ipd bars, Ipd adj. panhard, Noltec v1 camber plates, front coilovers with 300# springs and Koni Yellows, rear cut wagon springs and Koni Yellows
'65 122 S - B20 bored .010 over, D cam, E head, M41 J-type, IPD poly all around, Bilstein HD's, tons of other goodies...
'91 245SE - Sold
'82 244tic - Sold
Originally Posted by Stephen View Post
At full compression, there's enough room for a credit card to slide in.
BoostIt is offline   Reply With Quote
Old 01-20-2012, 04:41 PM   #106
propav8r
F*ck Edgar
propav8r's Avatar
Don't have any...I'll grab some when I'm home next.
Old 02-01-2012, 11:21 PM   #107
blueinportland
blueinportland's Avatar
Your car looks great and I really dig the classic look of the quad round headlights. On a side note, my car, the blue '85 wagon in your second photo, is so high up because it has Bilstein HDs and no lowering springs, they tend to push the car up. It also has rear overload coils in the back, so I think it's higher than it would be when it was brand new from the factory. That being said I'm sure your right, springs do wear out and most old volvos probably ride a fair deal lower than when new.
blueinportland is offline   Reply With Quote
Old 02-01-2012, 11:45 PM   #108
propav8r
F*ck Edgar
propav8r's Avatar
Haha, thanks for the kind words.
It's a bit of an ongoing argument here as to whether springs wear out or not. I posted your wagon as an example of some of the 240s I've seen with new factory suspension material.
Old 02-01-2012, 11:48 PM   #109
blueinportland
Well, everything fatigues with stress and age so being that springs have both, it would only make sense that they would wear out.
Old 02-02-2012, 08:21 AM   #110
940guy
940guy's Avatar
yea i agree my 940 before it was called mine the left rear sagged pretty bad . my mom was pretty big and she drove it all the time also the gas tank is on that side.
93 944t
b230+16v+holset hx35 16cm hot side +75shot CRUSHED
01 v70 boring DD
88 745 racewagon lots of around cones goodies
940guy is offline   Reply With Quote
Old 02-02-2012, 10:43 AM   #111
smokeyfan1000
Guest
Originally Posted by propav8r View Post
DOH!
Yeah, I have. Buuuut I left them at the shop again
I've been scatterbrained, running all over the city to try and find a custom spark plug wire set with the correct ends for LS1 coils. I'll probably have to end up ordering them from somewhere. Le sigh.
And thanks for the compliments!
Call Kingsbourne . I'll bet they'll make custom GM/LS1 coil/Volvo plug wires
Looking good BTW.
Old 02-02-2012, 12:02 PM   #112
propav8r
F*ck Edgar
propav8r's Avatar
I got a set from Scott Performance Wire in Mooresville. Still waiting on TrickMick to get back to me on a set made by him...
Old 02-02-2012, 01:08 PM   #113
smokeyfan1000
Guest
can ya post pics of the Scott Performance wires from Mooresville? Aren't they the NASCAR wires?
Old 02-02-2012, 01:48 PM   #114
propav8r
F*ck Edgar
propav8r's Avatar
He makes them for several teams, yeah. $40 for the set and same-day turnaround...I can't complain.
Check the first post on this page.
Old 02-10-2012, 05:38 PM   #115
FullEnglish
Love this car. It's Bentley-esque in the first pic. Very tidy install too. As soon as I organise a workshop (next year?) I'll be on the hunt for a late 70s 244 to play with. I mean, I like my 940, but these things have soul, or some crap like that. Dunno, maybe I'm a closet hippy, but who cares...
FullEnglish is offline   Reply With Quote
Old 02-10-2012, 06:11 PM   #116
propav8r
F*ck Edgar
propav8r's Avatar
Thanks very much! And yeah...you can't beat a late-'70s 240.
Old 03-01-2012, 12:43 AM   #117
propav8r
F*ck Edgar
propav8r's Avatar
Props to Derrick and Mark.
The car now has a full 3" exhaust. To the junkyard tomorrow to pull the brake lines I need to fix my screwup, and then hopefully on the road on Friday or Saturday before I go back to school on Sunday.
Old 03-01-2012, 01:07 PM   #118
spe1983
spe1983's Avatar
Looks good sir. Very impressive work.
1972 142 w/ 130K, in progress.
1992 944T w/ 195K, DD
2004 XC90 2.5T AWD w/ 124k
1984 242T - gone, now brettmobile
1994 855T - gone
spe1983 is offline   Reply With Quote
Old 03-01-2012, 01:42 PM   #119
smokeyfan1000
Guest
Springs do lose their strength over the years. Volvo springs seem to hold up better than the American car springs(back in the 60-70s).
The springs on my 69 Chevelle were shot when I bought it. Replaced with new & made a big differnce. Why I'm not big on lowering with old cut springs.
Old 03-06-2012, 05:56 PM   #120
propav8r
F*ck Edgar
propav8r's Avatar
Thanks! Glad you enjoyed it.
Also, I never did get photos of the exhaust...but I will, I swear!
Old 03-06-2012, 08:44 PM   #121
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
That bay is nice. Clean up the IC/Rad area with a shroud or something!
Old 03-08-2012, 11:18 AM   #122
propav8r
F*ck Edgar
propav8r's Avatar
Oh yeah. I need to snag a little bit of aluminum sheet to throw down there.
Old 03-08-2012, 02:13 PM   #123
BoostIt
BoostIt's Avatar
pics of the exhaust? vids of it driving/running?
Old 03-08-2012, 03:09 PM   #124
propav8r
F*ck Edgar
propav8r's Avatar
Hopefully heading home this weekend. I chickened out and registered TS, so I'm just going to click a button and watch VE Analyze Live work it's magic.
If it doesn't rain (and soak the ground behind the garage) I'll try and get it on the road. I just have to get it out of a low area and up a muddy hill lol.
Old 04-01-2012, 12:19 AM   #125
propav8r
F*ck Edgar
propav8r's Avatar
Made it home, and did some stuff. Promise.
