Old 03-30-2016, 05:05 PM   #126
amerbritcan
Hnnnnnng
amerbritcan's Avatar
I think a pair of headlights and a grill would do wonders.
With the bumper sitting properly, and front trim installed, the ugliness of that front panel would probably almost disappear.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 03-30-2016, 06:17 PM   #127
LC4CARL
Aero challenged
LC4CARL's Avatar
All in good time big mon.
Everyone knows it's the "stance" that causes panties to drop...
@PDXvolvo on IG
Old 03-30-2016, 06:22 PM   #128
cwdodson88
Originally Posted by LC4CARL View Post
I know that there was no malice intended, but knowing where I started, that I've put a lot of effort into this, and that I was likely a bit proud to be able to post a photo of the car sitting on the ground; the only response that comes to mind is the old quote about "beauty being in the eye of the beholder." I have to believe that you, I and the rest of the TB family of crazies, hang out here because a smile comes to our faces when we look at, work on, and drive these cars. And I think that's beautiful. Even if it is ugly.
Volvo, smile til your face hurts!
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-31-2016, 01:55 AM   #129
LC4CARL
Aero challenged
LC4CARL's Avatar
Dropped her at the alignment shop. The manual steering is fine. Very light, even at low speeds. More turns lock to lock, but that's fine. The new (used) tires absolutely transform the car. No longer feels like a death trap. Had it in 5th gear for the first time. Sublime... Got to fix the signals and tail lights. And that head light... Something wrong with the brakes. Going to have a pro bleed them and see what we have. Exhaust sounds good. Going to have it plumbed out the back with just the front muffler. Pretty stoked. Really a fun car to drive. Haven't had a stick shift in 20 years. Kind of like riding a bike.
Old 03-31-2016, 10:16 AM   #130
quillc
yv1a.com
quillc's Avatar
There is a little post/clip on the front bumper that keeps it from drooping. If you are lucky, it has just come loose. If you aren't, its broken. The JY should pretty easily provide with a little patience. The trim can be harder to find, but should be do-able. Redwood Chair may have some for you. The little clips that hold it on can be removed from a JY car by carefully pushing out the pin from the back side with a small pin punch and then pulling it out the front. It will likely take several trips to the JY to accumulate a full set. Be sure to fully seat the trim so you don't lose it on the highway.... Oh, and a few whacks with a dead blow mallet will take care of most of the wonkiness of the panel. You can actually pull it from the car to do so by cutting a couple rivets on each side. Nothing fancy there, just pop rivets.
Chris
www.yv1a.com
Old 03-31-2016, 04:05 PM   #131
LC4CARL
Aero challenged
LC4CARL's Avatar
Good stuff. Thx!
When I swapped front bumpers I ended up with one usable fender / bumper extension post. On the look out now...
My trim was held on with wood screws.
Stopped by IPD today. This could be habit forming. Scored a Bentley manual and some odds and ends. Only a few miles away. Big trouble. LOL.
Old 03-31-2016, 11:45 PM   #132
LC4CARL
Aero challenged
LC4CARL's Avatar
My bud at the alignment shop said the top bleeders on the front calipers were full of goo. And the L/R caliper wasn't doing anything. Nice to have brakes on all four wheels now.
Think we got our money out of this rotor? Nice to hit on all four cylinders too.
Old 04-01-2016, 12:16 AM   #133
LC4CARL
Aero challenged
LC4CARL's Avatar
Should I put spacers on the rear wheels? They kind of swim in the fenders.
Old 04-01-2016, 12:18 AM   #134
amerbritcan
Hnnnnnng
Wow haha.
Old 04-01-2016, 12:58 AM   #135
quillc
yv1a.com
quillc's Avatar
You can, but you are very limited by the length of the stock studs (assuming you are going to maintain minimum thread engagement).
Ben Kaplan sells extended (high strength too) studs. Makes fitting spacers simple.
Old 04-01-2016, 01:12 AM   #136
Default Form Or Function?
It'll look better to some but it will make it push in the turns.
Old 04-03-2016, 12:01 AM   #137
LC4CARL
Aero challenged
LC4CARL's Avatar
Watching the WRC coverage of the Rally Sweden. Snowy roads through the woods. I could do that in the wagon. Not...
Old 04-03-2016, 12:12 AM   #138
LC4CARL
Aero challenged
LC4CARL's Avatar
Previous total: $1650.
Junk yard parts $35.
Align / brake bleed $110.
Tailpipe $70.
Fasteners $25.
Headlight $70.
IPD $135
$2095
Old 04-03-2016, 12:22 AM   #139
LC4CARL
Aero challenged
LC4CARL's Avatar
Cat, muffler #1, then 2 1/4" tail pipe. Sounds good.
Old 04-03-2016, 12:24 AM   #140
LC4CARL
Aero challenged
LC4CARL's Avatar
Tried out the bike rack. Should be OK.
Old 04-03-2016, 12:27 AM   #141
LC4CARL
Aero challenged
LC4CARL's Avatar
And tail lights...
Just when I think I have them sorted, I went for the back up lights and everything went to heck.
Old 04-03-2016, 12:31 AM   #142
LC4CARL
Aero challenged
LC4CARL's Avatar
As of now, I think I would trust this car. Still a list of issues, but it runs, turns and stops. Pretty much. It's a hoot to drive.
Old 04-03-2016, 12:33 AM   #143
amerbritcan
Hnnnnnng
Hahaha it's a never ending battle. My sedan has no reverse lights and IDGAF, I'm not screwing with it anymore.
I think my car's "first muffler" is gutted/empty, because when I was driving it around without the rearmost section of exhaust (including muffler #2) it was insanely loud. Awesome, but crazy loud.
Old 04-03-2016, 02:00 AM   #144
quillc
yv1a.com
quillc's Avatar
And tail lights...
Those bright upper lights are the 'fog lights'. Its the little weird switch above the headlight switch. When you switch it on, they just stay on like that.
Old 04-03-2016, 02:47 AM   #145
LC4CARL
Aero challenged
LC4CARL's Avatar
Ah, now everything is clear. I thought the front fog lights had fallen off.
1156 in the top, 1157 in the bottom. I'll keep playing with it.
Just ran out to try the switch. Whoa, those are bright! That would explain why I was only getting six volts earlier.
Some really weird things happening with these lights...
Old 04-03-2016, 02:50 AM   #146
LC4CARL
Aero challenged
LC4CARL's Avatar
Yeah, dumping in front of the axle was a bit much. Out the back is mellow.
Old 04-03-2016, 12:30 PM   #147
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 04-03-2016, 12:35 PM   #148
Old 04-03-2016, 07:40 PM   #149
LC4CARL
Aero challenged
LC4CARL's Avatar
Most excellent! I'll check my wires.
I had a thought: The wiring through the lift gate hinge is broken and the wiring to the aftermarket radio is suspect. Any chance unrelated "feed back" could be effecting the tail lights?
Old 04-03-2016, 08:25 PM   #150
77volvo245
77volvo245's Avatar
The tailight on the left might be from a 81-84
STSmachining
