Old 02-25-2017, 08:59 PM   #101
57plymouth
57plymouth's Avatar
I bet you have a vacuum leak, causing your recirculation issue AND your misfire issue. Once you bite the bullet and dig into the dash far enough, you will find whatever actuator is leaking vacuum. Any vacuum leak will affect engine performance.
Old 02-25-2017, 09:40 PM   #102
Cwazywazy
Single jingle
Cwazywazy's Avatar
I know there's a vac leak, and I know the recirc actuator is leaking vacuum but even with the recirc button pushed (Blocks off vacuum from the line) the engine still has issues indicating a vac leak. So there's probably a bigger one somewhere.
I don't know what I have
Old 02-26-2017, 09:07 AM   #103
57plymouth
57plymouth's Avatar
Try disconnecting the vacuum for the HVAC from the engine and capping it. Then run the car and see if the problem goes away. You still have a HVAC problem, but it will tell you if you have an engine problem.
Old 02-26-2017, 11:22 PM   #104
Cwazywazy
Single jingle
Cwazywazy's Avatar
So I took a look at my ECUs. The one in the car has 740 turbo written on it and the number is 0 280 000541 but my 780 ECU has the same number. I thought that since the Bertone allowed overboost it would have a different ECU? Is it known how much boost this ECU can handle? I think it has brown top injectors.
Old 02-27-2017, 06:04 PM   #105
Cwazywazy
Single jingle
Cwazywazy's Avatar
So the dying issue is only after it fully warms up, if that means anything. Also I cannot figure out how I broke the speedo. It stopped working after I fixed the blower but I can't find anything out of place in that area.
Old 02-27-2017, 06:12 PM   #106
Cwazywazy
Single jingle
Cwazywazy's Avatar
Also my air scoop went missing. I assume it flew off on the highway when I was testing the turbo...
I don't think I'll be getting that back a second time.
Old 02-27-2017, 08:47 PM   #107
oldnfast
Just for the hell of it,try swapping the ecu's.usually ecu's either work or don't,however I had intermident stall issues on my last 945 turbo.it turned out to be the ecu,I think it was even a 541.
oldnfast is offline   Reply With Quote
Old 02-27-2017, 09:38 PM   #108
Cwazywazy
Single jingle
Cwazywazy's Avatar
Already did, made zero difference. Next step is to test for vac leaks.
Old 02-28-2017, 09:12 PM   #109
Cwazywazy
Single jingle
Cwazywazy's Avatar
Sprayed carb cleaner around all the vac lines and injectors. Nothing. Noticed zero change in idle.
Old 03-01-2017, 03:27 PM   #110
Cwazywazy
Single jingle
Cwazywazy's Avatar
This is getting frustrating. Can't find any vac leaks whatsoever and I replaced the weird single wire o2 sensor (which was twisted together in the middle after it got cut somehow) which made zero difference.
I got a new dashcam today and tested it. At the start the engine dies and I pop the clutch to restart it.
EDIT: Also tried a spare MAF. The first one I tried was labeled "fuel injection corporation" and made it run super rich. Then I tried a Bosch and that works fine, but it made no difference to the dying problem. I think the next thing to look into is the IAC. Also swapped the steering wheels. "Racing" wheels don't belong in a 240.
Old 03-02-2017, 06:12 PM   #111
Cwazywazy
Single jingle
Cwazywazy's Avatar
I think replacing the MAF may have fixed the high RPM issue. At least it hasn't happened since I replaced it. The dying at idle issue still persists. I've already tested/replaced the MAF, IAC, ECU, o2, and checked for vac leaks. There might still be a leak, need to cap off the HVAC like 57plymouth said and test.
What could cause the idle to dip and sometimes die after letting off the gas when the engine is fully warmed up? It drives 100% fine when it's not warmed up yet and it only happens when the RPMs are dropping to idle speed.
Old 03-05-2017, 02:23 PM   #112
Cwazywazy
Single jingle
Cwazywazy's Avatar
I dynod it because why not. Put on a boost controller and turned it up slightly so it was making 9psi max.
175HP and 235FT LBs. I'm happy with that.
I only recorded the first run which was kinda messed up. Only made 150.
Old 03-06-2017, 01:36 AM   #113
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Not bad numbers at all for a basic +T. Impressive
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 03-07-2017, 09:22 PM   #114
Cwazywazy
Single jingle
Cwazywazy's Avatar
If I whip the steering wheel one way something clunks and then the steering wheel is a little off center. If I whip it the other way it then clunks and goes straight. wtf.
Old 03-08-2017, 12:48 AM   #115
Cwazywazy
Single jingle
Cwazywazy's Avatar
Is swapping to EZK ignition worth it? I have almost everything I'd need, I think.
Old 03-08-2017, 09:30 AM   #116
57plymouth
57plymouth's Avatar
Steering shaft worn out?
Old 03-12-2017, 09:21 PM   #117
Cwazywazy
Single jingle
Cwazywazy's Avatar
Okay so now it's making 5psi max with or without a boost controller when it used to make 6-7 without. Boost leak?
Old 03-21-2017, 09:36 PM   #118
Cwazywazy
Single jingle
Cwazywazy's Avatar
I've been doing some minor stuff. Today I replaced the oil drain hose and changed with Rotella 5w40 synthetic. Put on a quality boost controller and it's currently at 11psi. Pulls hard, I love it. Interior is pretty much fixed up, just need to fix the drivers seat and figure out what to do with the boost gauge since I want an oil pressure gauge. Also recently did the tailgate harnesses, so that crap works now. And I did a crappy eBay catch can install which isn't pictured. Just ziptied to the clutch cable next to the brake booster and venting to atmosphere. Better than getting oil on my valve cover, I guess.
Old 03-25-2017, 04:52 PM   #119
Cwazywazy
Single jingle
Cwazywazy's Avatar
Old 03-25-2017, 05:24 PM   #120
esmth
not even broken in yet
1991 244 LH2.4 m46 330k? miles
Old 03-27-2017, 05:37 PM   #121
Cwazywazy
Single jingle
Cwazywazy's Avatar
I think my rear main seal is leaking. Goddamn it.
At least the underside is well rust proofed now.. And the driveway..
Old 04-14-2017, 04:53 PM   #122
Cwazywazy
Single jingle
Cwazywazy's Avatar
RMS is done and it's driveable again, but I think it's safe to say my oil box might be slightly clogged..
I broke off a piece of the oil cap seal to provide a way for the pressure to get out so I wouldn't blow any more seals on my way home. Oil box is sitting with degreaser inside it right now.
Old 04-14-2017, 04:54 PM   #123
Or pull the dipstick up a bit...
Old 04-14-2017, 04:57 PM   #124
Cwazywazy
Single jingle
Cwazywazy's Avatar
Now, where can I get a new oil cap seal?
Old 04-14-2017, 05:04 PM   #125
JY, FCP, dealer, ect
Or post in wanted if you're too cheap to pay corporate shipping.
