Old 07-06-2018, 10:52 AM   #201
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Good luck man!!! Keep us posted on the low timeslips Get those slicks to hook on the warm tarmac.
2010 Porsche Cayenne S - My ride - 99k stock
2010 Cadillac Escalade ESV - Wifeys ride - 205k stock
2007 Audi A4 3.2 M6 - daughters ride - 166k stock
2006 Volvo XC70 Wagon - sons ride - 175k stock
1992 Volvo 965 - "Savage Wagon" w LS 5.3 LM7 + LS7 cam + GM T5 swap in progress.
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 07-06-2018, 05:35 PM   #202
740atl
educator monkey
740atl's Avatar
Originally Posted by Andrewhans View Post
Got the final piece of the fuel pump puzzle. Going to have the MS3 GoldBox trigger this at 4-5psi to boost voltage to the pump. Going to turn the voltage back down to very slightly above normal. I want 13.9-14v at hot idle. When triggered this will boost voltage to 17.5v at the pump only. We will see how much it shorten pump life but this is the go to method for some other chassis that have a pump that is near the edge of being not enough.
12v in from Batt on fused(40a) red, good chassis ground on black, direct pass through when off on orange and when triggered orange outputs 17 ish volts. Ground trigger is Brown. DC-DC converter with passthrough.
Andrew what does the fuel pump booster do? Does the increased voltage correlate with increased pump output?
btw, lovin the build.
Old 07-06-2018, 11:05 PM   #203
volvo?
That One Guy
That is what it does.
Well that got out of hand fast.
volvo? is offline   Reply With Quote
Old 07-07-2018, 05:41 AM   #204
740atl
educator monkey
740atl's Avatar
I might be answering my own question again, but if the pump output is increased at the same kPa/RPM, then that is something that would require less VE at the same kPa/RPM which means a bit of retuning.
Is the voltage output of the multipler consistent?
Was the choice to go with the pump multiplier instead of larger injectors?
Old 07-07-2018, 06:49 AM   #205
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
moar volts is betters. if the ecu can handle it, coils hit harder, injectors work faster, pumps pump more.
Megasquirt Tuning!
Old 07-07-2018, 06:30 PM   #206
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Cheaper to get this booster($100 used of CL)
Voltage output is constant 17.5v independent of input voltage(to a point obviously) when activated.
Im triggering the booster prior to when I was loosing fuel pressure before. So that area is fine but the part of the map that was overcompensating on the pulse width to bring my AFR back in line is now overly rich.
Back to the updates!
New best time! 7.5 @103
Left the line at idle and floored it right away. Viewing the datalog I seem to be lifting as boost comes up in first gear. Not sure why though I dont remember lifting at all...
This was at 12psi 13ish deg timing on e85. Going to turn the boost up to 15psi and make a few more passes. Got some great datalogs too of the Boost-A-Pump working great prefect fuel pressure the entire pass.
My wife took a few videos for me. Had a blast last night.
Overall great time.
Current setup - Aluminum L33/Summit Turbo Stage 2, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 07-07-2018, 06:35 PM   #207
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Couldnt agree more. I had the system voltage overboosted too much. 15.4v cold and 14.8v hot. I felt like eventually I was going to cook the battery so I lowered the voltage. Now its around 14.8v cold and 14.4 hot which is perfect IMO. Under full song it drops to 13.8v and I only have a .3v drop from batt to fuel pump relay output post and 17v output of the actual boost a pump.
The walbro 450 is an animal when fed the proper voltage.
Old 07-07-2018, 10:26 PM   #208
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
That last video coming around the Mustang was beautiful!
Sorry if I missed it, but why not leave harder? What stall converter RPM? Traction? trans brake? And I say that because you all pulling all of them on the back half. Once the launch is perfected, you are going to make some people cry looking at your taillights!
Old 07-08-2018, 12:00 AM   #209
cosbySweater
cosbySweater's Avatar
Did you verify the timing???
1995 Porsche 993
2013 VW Passat TDI
Old 07-08-2018, 08:14 PM   #210
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Working up on the boost off the line. Also I just got to the point where I can floor it in first and not spin the tires. Now that I have that down Im gonna turn the boost up and try and brake boost a bit to leave a bit harder. No transbrake, unsure on stall number. Its a custom spec'd unit from PTC, works amazing.
Once the launch is dialed, its gonna be mean at the track.
Not yet. I need too, but I've been too lazy. I need to find the right kind of timing light too. I have a fixed one the just flashes, no dialback or readout.
Old 07-09-2018, 09:02 AM   #211
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
[QUOTE=Andrewhans;5822600]Once the launch is dialed, its gonna be mean at the track./QUOTE]
Yes it will!
Old 07-14-2018, 08:56 AM   #212
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Got the 2 step working. First video is 2500rpm and -2 timing second video is 3800rpm and -4 deg timing.
Didnt really do mich better. Im traction limited. The open diff is ****ing me on the burnout and at the 60'. I dont want to weld it bc I drive it on the street quite a bit and don't want it to be miserable and destroy the bushing back there any more than they are lol.
Old 07-22-2018, 09:21 AM   #213
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Had someone ask about the fuel filter mounting. Its nothing special, just some zipties near the factory fuel tray.
Old 07-22-2018, 12:03 PM   #214
cosbySweater
That looks so gross man. Haha
Old 07-22-2018, 03:25 PM   #215
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Lol, pretty doesnt equal fast. It's secure and with how big that filter is, I dont ever see needing to change it out. Ill increase my fuel line size before its dirty at all. I will cut it open when the time comes to change it.
I was trying to find some solid data on a voltage boosted(over 13.5v) walbro 450 and could find nothing on the internet. So I went to the source.
Sent TI Automotive an email asking about data and charts. I received this in return.
He did mention to expect shortened pump life when running these higher voltages. My voltage booster when triggered outputs around 17.5v with 40amps available current at that voltage.
These walbro 450 pumps are monsters when fed the power they need. Zero fuel pressure issues with e85, deka 80's, 15psi, 6800rpm with a 7875 on a 4.8. Should be in the 530-550whp area on a Mustang dyno. Duty cycle tops out at 83% at 15psi which is far better than the 104% I was seeing at 12psi before.
At 73psi of rail pressure the flow increase from 13.5v to 17v is around a 40% increase.
Old 07-22-2018, 05:24 PM   #216
BillyMaysHere
BillyMaysHere's Avatar
Plz get a timing light and dial that in.
Old 07-22-2018, 11:11 PM   #217
cosbySweater
Just set in 6 degrees of offset. Both engines had that with the Elgin cam I don't even use a fuel filter with the 450 in the tank. Lol
Old 07-23-2018, 08:09 AM   #218
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So here's my question. 6 degrees of offset means that your timing map was in reality 6 deg more aggressive than your timing map showed or 6 degrees less aggressive.
I ask because at 14-15psi it feels VERY strong for only commanding 11-12 deg of timing under boost.
Old 07-23-2018, 12:28 PM   #219
77volvo245
77volvo245's Avatar
How many times have you changed your center bearing support rubber on you driveline?
STSmachining
Old 07-23-2018, 03:01 PM   #220
740atl
educator monkey
740atl's Avatar
EDIT>>> I Looked at the graph...
I guess I still have a couple questions. How does MS account for the increased flow? Does it have a fuel pump output vs voltage table or do you correct for it in VE? In other words, you have to tune for it.... if that's the case, is the voltage-flow output consistent? answered my question on that part. I could imagine the tuning would be difficult if the voltage-flow output was changing.
and one more... do you have it set such that the pump voltage ramps up or is it just a reach a certain boost and pump booster turns on?
Thanks.
Mike
Old 07-23-2018, 09:58 PM   #221
cosbySweater
Yea it's to advanced. Add six degrees to what you have
Old 07-24-2018, 07:33 AM   #222
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Just the first time when I had the driveshaft built. Put a new bearing and rubber on it.
Old 07-24-2018, 07:39 AM   #223
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Thanks.
Mike
It is actually very easy to tune around. I was having massive fuel pressure loss issues at high rpm and boost that I was already tuning around so this was just doing the opposite of that.
The booster comes on like a switch. Either on or off. I have the ecu trigger it at a certain point that I can change or set to whatever I want(MAP, Throttle, RPM...) What I did to minimize the amount of tuning needed was turn on the booster just before I would have normally started dropping fuel pressure so I don't actually have a pressure spike or anything in my datalogs. I now just have steady fuel pressure.
I guess I don't look at any of those variables now. I simply monitor the fuel pressure, AFR and VE1. As long as the AFR is what I'm commanding and the fuel pressure is steady I set the VE to whatever the engine needs.
EDIT: The flow through the injectors doesn't really change because the pressure stays the same with the regulator doing it's job. As long as you weren't increasing injector pulsewidth before hand for a "lack" of flow/pressure, there should be no tuning around the pump coming on(as long as you aren't overrunning the regulator when the extra flow occurs)
Old 07-24-2018, 09:24 AM   #224
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
No wonder my plugs are reading like there's a bunch of timing in it haha. I've also been consistently finding little balls of aluminum on my plugs and heads... it all makes sense now. Need to find/rent a dial back light really bad now lol
I have a standard fixed timing light and have thought about installing a timing tape on the balancer, finding cyl 1 TDC and locking timing at like 14deg at idle and checking it then.
I'm probly running nearly 17-18deg of timing at 15psi... A bit aggressive I would say. Really surprised I haven't spit out a rod or melted a piston
Old 07-24-2018, 10:07 AM   #225
cosbySweater
I had mine like that for a long time on 91 octane. It was sitting at around like 22 degrees. Didn't loose any material but still. Lol
