vwbusman66
Stößelstange über alles
- Oct 12, 2016
- SE MI
Pulled the pan and found this:
This engine has digested a cam and lifters and was ready for its 2nd post break-in oil change (500 miles) when I yanked it to do the oil pan and rear main seal. Drained the oil, saw a tiny bit of shiny stuff (small particulate matter from the fresh cam). Pulled the pan, and found slivers/shavings.
Bearings look fine, thrust bearings show copper but not ruined. The crank has some texture from what I suspect was contamination, but I suspect it's less than 1 thou.
