Old 04-11-2016, 05:37 PM   #1
jack.button
Default 19T or 20G?
b230ft. Getting parts to megasquirt. Intercooled.
Looking to buy a turbo. Which one? 19T 20G? Been looking at the new Kinugawa but am a little scared.
91 octane, Maybe 750cc injectors?
Thanks
1984 Volvo 242 GLT
AW71
Intercooler Package
jack.button is offline   Reply With Quote
Old 04-11-2016, 06:05 PM   #2
whats your hp goal?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-11-2016, 06:51 PM   #3
80/20 speed parts club
I'd rather have a 19T with a B21 from a drivability standpoint.
Old 04-11-2016, 06:53 PM   #4
jack.button
Originally Posted by blkaplan View Post
whats your hp goal?
300-1200 hp to the wheels. Probably, 350 to be exact.
I don't want to modify a bunch of stuff to make it fit. I'm ok with a bit. But I don't want to do a bunch of machining etc...Looking for bolt on or semi bolt on.
Garrett?
Old 04-11-2016, 06:54 PM   #5
jack.button
This is a b230ft on my new 244
Old 04-11-2016, 06:58 PM   #6
cwdodson88
I think I'd still rock a 19t, isnt the 20g a TD05 frame? I dont know if there were any that were "bolt on" for a t3 spaced manifold flange.
The Build Thread
SVEA - PUSHROD TURBO!
Old 04-11-2016, 07:16 PM   #7
mopar318
mopar318's Avatar
TDO5 is still a t3 frame. I will be running the 20g on mine. I heavily modified the exhaust housing for better flow out of the wastegate and wheel.
Seems like the 19t is better suited for you.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 04-11-2016, 07:19 PM   #8
cwdodson88
and corrected... For some reason I was thinking that most were some odd ball spacing... what I get for talking out my a$$ before hitting the google.
Old 04-11-2016, 07:21 PM   #9
jack.button
Anybody read anything about the Kinugawa 19T? It's got a good rating on the Kinugawa website, but no written reviews, could be a case of stuffing. I think it's Taiwanese. Anybody running one?
I did read about a guys Kinugawa 20g blowing up on him in 2012, but that could have just been due to the Mayan calendar ending.
What are the bolt on Garrett options?
Old 04-11-2016, 07:44 PM   #10
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
The GT/gtx series is all nice stuff, as are bw efr turbos. Josh @yoshifab has a few nice turbos for a reasonable price as well.
Yet Asher here went with...
Old 04-11-2016, 10:07 PM   #11
swedish-rocket
I run a 20T and 15g. I like the 15g low end but 20T pulls better on the highway. I haven't tried the 20T with my E85 setup yet though.
swedish-rocket is offline   Reply With Quote
Old 04-11-2016, 11:04 PM   #12
PNW940Pwnage
19 or 20T would be a good choice. Kinugawas are fine, I've run them before.
At around 19-20psi, that will be a fun car. Won't need anywhere near 750cc's for gasoline and 20psi.
PNW940Pwnage is offline   Reply With Quote
Old 04-12-2016, 09:39 AM   #13
jack.button
What injectors are you running for e85? Will the stock fuel pumps move enough fuel to support it? E85 where I am is readily available, even at 20% more volume to gasoline it's cheaper.
Old 04-12-2016, 10:01 AM   #14
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
I doubt you will make over 300whp on a tdo4 turbine housing.. You can put a 67mm compressor wheel on that tiny turbine wheel its only going to flow so much..
I'd go with a smaller t3 based turbo or a non-volvo housing tdo5 turbo to reach the 300whp mark..
Good luck
-Sam
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 04-12-2016, 10:06 AM   #15
You will barely make 300 wheel on a dynojet with a 19T if its completely maxed out. On a mustang dyno it wont happen.
If your goal is a solid 300 a 19T is not big enough.
TD05-20G will be a better match
Old 04-12-2016, 10:24 AM   #16
jack.button
Knock/Boost is the limiting factor? Wouldn't a 19t on e85 and 30 psi do the trick for 300-350 with the right fuel mods?? Mustang dyno is always a buzzkill.
I made 385 in my 2g head 6 bolt bottom 4g63 swapped mirage with an evo iii 16g, AFPR, walbro 255 . It's for sale by the way. HAHA. Mustang dyno.
Old 04-12-2016, 10:26 AM   #17
the turbo size is the limiting factor.
I have the dyno charts to prove it.
Above 24 psi the power stopped increasing, went up to 28 psi with no improvements.
There is no way you will see 350 with unicorn piss on a 19T unless you just find a dyno that reads high and will give you the number that you want to see.
Old 04-12-2016, 10:28 AM   #18
but this is Tbricks so you should just ignore all the advice people give and do what you want because thats usually what happens around here.
19T is a great turbo on a redblock car but 350 wheel aint happening and 300 wheel requires running the turbo to the max if you are happy with inflated dynojet numbers...
Old 04-12-2016, 10:34 AM   #19
turbotankshane
I think we should all be required to make a pass at the local track after any sessions on dynojets.. some are accurate and some are not, and some shop owners like to tamper with the weather settings to inflate their numbers but MPH is king!
Old 04-12-2016, 10:40 AM   #20
jack.button
When my Mirage went on the dyno the engine and bay were spotless. The guy filled up a weed spray container with a hose and sprayed down the intake manifold, all the intercooler piping, the fmic, etc...I think it made about 10 more horses on that pass but left hard water spots all over everything. I paid 500 bucks for that tune, you would think he could afford a bottle of distilled water so I didn't have to go over the whole thing again.
Old 04-12-2016, 10:57 AM   #21
Dyno is great for tuning the fuel and ignition timing but the numbers you get should be used as a relative measure, not absolute.
Trap speed is king, it doesn't lie. Unless theirs a tailwind and the tracks downhill
Old 04-12-2016, 11:20 AM   #22
turbotankshane
This is why diesel guys hate our dynocom.. they always come to our dyno days with inflated numbers from dynojets that have no crank trigger to measure RPM and have no torque numbers..
Have you ever tried to explain to a brodozer how he can't be making 700whp if he makes 700 ft/lbs of torque and only revs it out to 3500rpm? "But it made 750 on a dynojet last year and then I did a bunch of stuff to it. Your dyno's a piece of ****." Ugh..
Old 04-12-2016, 11:54 AM   #23
PNW940Pwnage
Good luck
-Sam
What I've noticed is that it's a VERY different driving experience depending on turbo selection.
A "big turbo" might make more peak power, and pull harder when it hits - but you're going to be waiting for it to come on in many (most) daily driving situations, especially if you're still on the auto with the stock torque converter.
A smaller turbo like a 19T may not make as much peak power, but it's actually going to be more enjoyable to drive and often faster in several situations where you aren't able to fully tach out the car with the larger turbo.
My issue at the drag strip the other night was partially attributed to this kind of a thing...big turbo, couldn't brake boost on the line with the stock torque converter, so the launches were terribad. And you HAVE to drop it into 2 or take OD off and get the revs up if you want to go anywhere without stopping to have a lag party. It hits at about 3500-3600 rpm.
A 19T would be "instaboost" in comparison, and would make for a more zippy DD.
Old 04-12-2016, 12:30 PM   #24
A tough rowing ho
Where did you find a new 244? I have a 20G on my B21 with an IPD turbo cam and it's silly fun, no idea on HP but it spins the tires in 3rd in the rain and I have a G80, and it's not laggy at all. I did find going to a 3.91 from a 3.73 gear in the rear made a huge difference in the way it spools with a 3.35 1st gear T5 tranny.
Me for President
First candidacy driven entirely by smart phone.
Campaign slogan
"Trump, I wouldn't piss on him if he were on fire!"
Old 04-12-2016, 12:44 PM   #25
jack.button
Ha, new 244 to me. T5 will be the first major thing I do. Currently has m47. Bought this car:
http://www.cardomain.com/ride/3245796/1992-volvo-240/
Had been let go a bit. Just going through it now. Exhaust is terrible. A bunch of little issues. Aesthetically really nice though. Not telling what I paid for it. Wasn't what the guy was asking.
