Old 11-30-2020, 10:46 AM   #1
dalek
Benchracer Tribe
dalek's Avatar
Default Is my diff leaking or somebody else is incontinent?
I stuck my head under the butt of my car yesterday and took some pictures. Someone is leaking enough to cover the entire right driveshaft. Who could be doing that?
I might take the car to the powerwash place and use engine degreaser thingie on the rear axle to see where it starts leaking...
Also, shouldn't it be a metal plate held by one of the diff bolts somewhere?
Feedback!
Old 11-30-2020, 06:32 PM   #2
Probably a trail from a seeping pinion seal. You may also want to change the rear cover gasket. check and see if it smells like gear oil. You only get a small metal tag if the anti spin diff is installed.
Old 11-30-2020, 06:42 PM   #3
The Librarian
Metal tags were used on 140 and older models to identify the gear ratio. Later cars came with a sticker on the axle tube.
The anti-spin tag was much larger than the ratio id tag.
Old 12-01-2020, 12:54 PM   #4
nyalex
Did you verify that the breather tube on the right driveshaft is free and clear? I can see it in the picture, its in towards the diff on the top of the right driveshaft. Its a nipple that has a plastic flex tube attached that acts as a breather. If thats clogged the heat could be causing some pressure inside the diff thats forcing its way out somewhere, creating your leak.
nyalex is offline   Reply With Quote
Old 12-01-2020, 02:54 PM   #5
283SD
On the tube type axles the tubes are pressed into the diff housing and plug welded to the housing, not oil proof. I have seen this on many rears as time goes on. Other than a bad pinion seal those leaks are normal as time goes by
Old Today, 12:20 PM   #6
dalek
Benchracer Tribe
dalek's Avatar
What are the two round thingies in this picture?
nyalex, I have not found the nipple you mentioned, but I will look for it later on today
Old Today, 12:44 PM   #7
The Librarian
They receive the pins for the diff case spreader.
The vent tube nipple is on the drivers side axle.
Old Today, 12:57 PM   #8
Lankku
Lankku's Avatar
On a 140/240 yes, but the picture is from a 700/900 and on those it's on the passenger side.
245 -90 "B6284T"
Old Today, 01:45 PM   #9
The Librarian
Originally Posted by Lankku View Post
On a 544, 122, 1800, 140/164, 240/260 yes, but the picture is from a 700/900 and on those it's on the passenger side.
FTFY.
I rarely work on 700/900 cars so it was an honest mistake.
Old Today, 02:14 PM   #10
FTFY.
Too new and full of gadgets for me.
