Old 07-24-2017, 11:53 AM   #226
t8fanning
8v are still cool, right?
t8fanning's Avatar
Waiting for boost caused me to lose the jump on some of the roll races, so I decided to implement rolling anti lag using the cruise control switches. This is nice because it allows for an arming switch and doesn't require me to let go of the wheel. I was thinking about using the switch for nitrous eventually, but I realized nitrous doesn't really fit my goals for this car.
This video shows me testing continuity of the cruise control speed switch. Excuse the vertical video please. I used the red and yellow wires only. Attach one wire to megasquirt, and one wire to ground and that's it:
Here's a really short video of it working. I was in second gear:
And another one, where you can actually see boost build quickly (also in second gear):
I'm really happy with how it works. The car launches way harder from a roll now.
1982 242 Turbo.
Old 07-28-2017, 02:41 AM   #227
Gnomestur
Gnomestur's Avatar
How much boost you currently running? Any issues?
Gnomestur is offline   Reply With Quote
Old 07-29-2017, 01:57 PM   #228
t8fanning
t8fanning's Avatar
It is set to 22 psi currently. No issues at all with the engine.
Had some disappointing results at the track last night. I'm car 406. Best time was 13.6, but my trap speeds are all really slow. My first run is on the left. Last run is on the right.
Tires at 25 psi, launch at 3500 rpm.
Tires at 20 psi, no launch control.
Tires at 20 psi, launch at 2500 rpm.
Tires at 20 psi, launch at 3250 rpm.
No matter what I do, my wheels spin, even with traction control enabled. It's most apparent in the third video. The car pulls both boost and timing with traction control, so it helps a little, but not that much. The new tires didn't do very much either.
I think the main cause of my low trap speeds was the lack of power up top. The car just didn't feel as fast as it has before. I think my clutch is slipping. I checked my logs; it's not pulling timing because of knock or anything else, boost is where it should be, and everything else engine-wise seems fine. It just seems slow, so I'm not sure what else it could be besides my clutch. One thing to note is that my coolant can get up to 200 deg F during a strip run, but it comes back down pretty soon after, maybe my belt is slipping or something. It was a fun night of racing, but disappointing. I was hoping to see low 13s, high 12s.
Old 07-29-2017, 11:18 PM   #229
Texas240
Prius Owner
Texas240's Avatar
You should see if your clutch is slipping in your logs if you were logging at the strip
93 245 LS Engine Swap Project
Old 07-29-2017, 11:43 PM   #230
mopar318
mopar318's Avatar
In my experience, sticky summer tires aren't great track tires. They need heat in them to work and that doesn't happen without a lot of turning.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 07-30-2017, 12:05 AM   #231
Broke4speed
Broke4speed's Avatar
Sticky tires with stiff sidewalls = wheelspin.
1984 B21T (formerly A), AW71(minus L).
Old 07-30-2017, 02:21 AM   #232
t8fanning
t8fanning's Avatar
I don't see any section where RPM increases much more quickly than VSS, which is what I would expect for a slipping clutch. But I noticed in 3rd gear during my recent runs, my RPM is significantly lower at the same VSS than in my first time at the track. In every gear except 1st of my July runs, the acceleration is on average 2 ft/s^2 less than that of my earlier runs.
I guess I found that out myself too. I like the tires; they're good for roll racing and summer daily driving, but I really need a set of drag radials or something.
Old 08-02-2017, 01:06 AM   #233
LC4CARL
Aero challenged
LC4CARL's Avatar
Inspired build.
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
Old 08-25-2017, 03:02 AM   #234
t8fanning
t8fanning's Avatar
I've just been driving my car around on my slipping clutch. The remedy to that will be its own update soon.
I spent about 6 hours cutting and buffing my car for a car show. I'd never done any paint correction before, but I'm pretty happy with the results. There are a few really thin spots on the roof and trunk, but it's not bad for 35 year old paint. After the show, my buddy wanted to take some pictures. The Flickr album is here, but I've included a few of my favorites:
Old 08-25-2017, 05:41 AM   #235
Sander
Good news everyone!
Sander's Avatar
I feel the title of this thread doesn't do its content justice. Looks great!
Old 08-25-2017, 09:17 AM   #236
The Full Banana
not yet good enough
The Full Banana's Avatar
Looks fantastic with the shiny (all) black paint and the LMs. Nice photos!
Tom 1980 242 GT
Old 08-25-2017, 09:57 AM   #237
SquareD
An Anomaly
SquareD's Avatar
Looks great!
I don't know a ton about drag racing, but 13.6 at 103 doesn't seem super out of wack. Get better traction and bring those 60ft times down and you'll see a nice drop in ET. Does seem like a lot of boost for 103 though. I ran a 13.8 at 101 with a mildly breathed on skinny rod engine and a jy frankenstein t3/t4 running 14-15psi. That pretty much my only experience though.
Old 08-25-2017, 10:05 AM   #238
t8fanning
t8fanning's Avatar
You're right. But I don't think 13s are very good for my setup. I realized on the drive home that I had a boost leak. On my really skinny tires I ran a14.xx at 111 mph, so the boost leak killed my trap speed. Between that and a slipping clutch, I think the car is capable of a much faster time. The track is also at almost 5000 ft of elevation which doesn't help. But I'm definitely working on it!
Old 08-25-2017, 11:10 AM   #239
Stiggy Pop
Stiggy Pop's Avatar
why are you switching out your T5 adapter setup? Does the deeworks bearing retainer setup not work with the Tilton?
'79 242
943 pickup
Old 08-25-2017, 11:14 AM   #240
t8fanning
t8fanning's Avatar
Exactly. The Deeworks kit uses the stock bellhousing, so there's no flat surface for the tilton to mount to. The bearing retainer mounts behind the bellhousing, and the throw out bearing sleeve is pushed into the bellhousing. Also I'd have to drill a hole for the anti-rotation pin, so I figured I'd just cut a huge hole and make sure it works properly. Also, I don't know how long my T5 will last, and it would be nice to be able to bolt up a TKO if I want, so I ordered a adapter from Ben.
Old 08-25-2017, 11:17 AM   #241
t8fanning
t8fanning's Avatar
Thanks. A single color 240 is so much better than an orange hood.
Old 08-25-2017, 11:57 AM   #242
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
What a beaut.
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking (sold)|'77 244DL, red/sold.|'90 744T C3P-LOL, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 09-06-2017, 04:10 PM   #243
12david34
this is beautiful!!!
K-Jet über alles.
12david34 is offline   Reply With Quote
Old 09-06-2017, 09:33 PM   #244
fortbrick
fortbrick's Avatar
Yeah, time for a title change. Sweet ride man
Old 09-06-2017, 09:54 PM   #245
Stiggy Pop
Stiggy Pop's Avatar
it's really gonna look good with skinny bumpers
Old 09-07-2017, 03:55 AM   #246
Quin
ಠ_ಠ
but tate loves his commandos.
Old 09-07-2017, 11:18 AM   #247
t8fanning
t8fanning's Avatar
I hate commandos and I hate being able to see the skid plate from the side. That and the overall length of a 240 are my main gripes about how they look. Skinny bumpers and a new air dam should help fix all that.
Old 09-07-2017, 11:34 AM   #248
SquareD
An Anomaly
SquareD's Avatar
Just pull the rubber off the commandos and strip the aluminum for that super sweet dirt track push truck look.
Old 09-07-2017, 02:16 PM   #249
Beforedenied
Beforedenied's Avatar
Awesome thread. Makes me miss my 242.
80' 242 DL, RIP 86' Wagon Sold
Beforedenied is offline   Reply With Quote
Old 09-08-2017, 06:27 PM   #250
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
The steering wheel has fake buttons.
Originally Posted by rvolvor
