Old 06-05-2017, 01:41 PM   #151
t8fanning
8v are still cool, right?
t8fanning's Avatar
If it shatters, I'm doing a TKO.
1982 242 Turbo.
Old 06-05-2017, 02:47 PM   #152
cosbySweater
cosbySweater's Avatar
If it shatters a GeForce would be sweet as chocolate balls.
Problem isn't the internals as much as it is the case that's made out of a Coke can
Old 06-05-2017, 02:49 PM   #153
t8fanning
t8fanning's Avatar
Really? That's interesting. Where do they usually break? I always thought third gear broke somehow.
Old 06-05-2017, 03:00 PM   #154
Quin
ಠ_ಠ
erik broke one because his pilot bearing fell out, and now thinks that all t5s are that fragile.
Old 06-05-2017, 03:33 PM   #155
GTJordan
Been here for too long
GTJordan's Avatar
For the ABS sensors, did you use the non-abs strut housings, with the ABS style tone ring hubs?
I really want traction control, but don't have ABS strut housings, and wasn't sure if the ABS tone ring hubs would bolt on?
Jordan
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 06-05-2017, 03:40 PM   #156
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
The ABS hubs fit non-ABS spindles with no issue. I'm currently running that combo on my car.
Fake Race Car
Old 06-05-2017, 03:46 PM   #157
t8fanning
t8fanning's Avatar
Yep. I made a sensor bracket a la Karl and welded it to my non-abs knuckle. Eventually I'd like to get some baller ABS monotube struts from Ben, but that's down the road a ways.
For reference, the Bentley manual says the ABS tone rings are pressed on and can be replaced. So the interested TBer could probably just turn down a non ABS hub and press fit an ABS tone ring on.
Old 06-05-2017, 05:31 PM   #158
The Full Banana
not yet good enough
The Full Banana's Avatar
That's a pretty neat setup, nice job. I could (and probably should) get on board with that.
Tom 1980 242 GT
Old 06-05-2017, 07:02 PM   #159
Theres not enough material on a non ABS hub to mount the ring by just turning it down,
You would have to make an adapter, easier just to source a set of ABS hubs
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 06-05-2017, 07:04 PM   #160
t8fanning
t8fanning's Avatar
Good to know.
Old 06-06-2017, 05:50 PM   #161
cosbySweater
The t5 cases flex with a hard launch.
Old 06-20-2017, 08:46 PM   #162
t8fanning
t8fanning's Avatar
Drove it to IPD; the trip was something like 1800 miles total. The way out I had no problems, car ran fine. However, on the way back, my electric fan motor seized a little less than halfway home. So I drove 50 miles on the freeway with no fan, stopped in a junkyard in Boise, found an 850 efan and made it work. No overheating problems unless I was stopped at a light or an exit or something. Turns out the 850 efan motor has much shorter wires than the 940 fan, so I had to dangle my relay on the skid plate. Ghetto but I had limited time and tools. After swapping the efan motors, I drove the rest of the way home without incident. I'm trying to find another 940 efan locally.
My seats have been pretty bad for some time, so I decided to do something about it. These showed up the day I was leaving for IPD:
I made some brackets yesterday, just waterjet out a shape from 1/8" mild steel and pounded them into submission with a hammer and vice. Small compound bends aren't really possible on the brake I have access to. The flange near the rear mounting point is to make the brackets stiffer as they hang off the back of the stock seat slider.
They fit perfectly:
I really need to find a black carpet and redo the rear bench.
I really like these seats. They're Recaro Expert L. The driver side has hand inflatable lumbar support, but the passenger doesn't. The driver also has an armrest I can't use because it interferes with the seatbelt console. I'll probably machine some bracket to make it work, I really want an armrest. I made the brackets hang off the back of the slider because I'm pretty tall. Doing it this way gives me plenty of leg and head room.
Old 06-20-2017, 09:10 PM   #163
okoye
okoye's Avatar
what turbo do you have on the car?
Old 06-20-2017, 09:17 PM   #164
t8fanning
t8fanning's Avatar
GT2871r with 0.63 AR T3 turbine housing and 4" ported compressor housing.
Old 06-20-2017, 09:25 PM   #165
Quin
ಠ_ಠ
ironically i really liked the seats that were in it. they fit a tall fat guy nicely.
having driven it: the motor is astonishingly good.
Old 06-21-2017, 01:39 PM   #166
The Full Banana
not yet good enough
If you made a second set of those seat mounts, I would buy them...
Old 06-21-2017, 01:43 PM   #167
t8fanning
t8fanning's Avatar
Do your Recaros have 6 mounting bolts? I'm happy to share my dxf/ model so you could get them cut locally and bend them yourself.
Old 06-21-2017, 05:21 PM   #168
The Full Banana
not yet good enough
Yep! I'd really appreciate that.
Old 06-21-2017, 05:32 PM   #169
t8fanning
t8fanning's Avatar
Here you go. I've included a solidworks part file and a dxf (in mm). If you can't find a cheap waterjetting or laser cutting place local to you, I'd cut them out if you want.
I made them from 1/8" mild steel. The holes in the part are undersized. I do this to get a location reference from the waterjet, and then I go through and drill them to the finish size. I'm pretty sure I used a J drill bit for the seat holes and U bit for the slider holes. This gives room for the square base of the slider studs so the bracket can sit flat.
Old 06-29-2017, 03:18 PM   #170
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I didn't see this update, Glad you made it home safe and sound, when I first read "However, on the way back, my electric fan...." I was like, "If this dude killed a relay I'm going to LOL" that is one of the spares I brought with me and you scoffed at it.
Those seats are the cat's ass, I wish I could have gone for a ride in this beast.
1980 242 Turbo
2004 V70R
Old 06-29-2017, 03:24 PM   #171
t8fanning
t8fanning's Avatar
Haha. The irony wasn't lost on me. When I realized it was the fan that's all I could think about. I almost wish it was the relay though, that would have been a much faster fix. Maybe I'll start carrying a spare fan motor on road trips. I do have two spare relays now that I'll toss in just in case.
Old 06-29-2017, 03:32 PM   #172
Uncleknucklez
bruspeed
I feel ya on the relay being easier. As I gain confidence in my car, There is less and less in my trunk. Before leaving for Portland I told my wife, "I'm bringing everything, so we will hopefully need nothing" and it worked!
Old 06-29-2017, 03:35 PM   #173
t8fanning
t8fanning's Avatar
It's a good way to do things. I could have saved myself 3 hours if I happened to have a fan motor in my trunk. I'm not sure what I'm going to take to Big Socal yet.
Old 06-29-2017, 03:41 PM   #174
I would of gone w/out a fan
Old 06-29-2017, 03:43 PM   #175
t8fanning
t8fanning's Avatar
It's not really reasonable to bring a whole spare fan imo, but my life would have been easier if I did.
