Old 06-29-2017, 04:17 PM   #176
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
It's a good way to do things. I could have saved myself 3 hours if I happened to have a fan motor in my trunk. I'm not sure what I'm going to take to Big Socal yet.
You plan to make that trek? I'll go, I just hate to be alone, in a strange town, with socal-ers
Will be a cool show, and I'm sure at least a couple of Bimmers guys from here in Sac will venture down.
1980 242 Turbo
Old 06-29-2017, 04:20 PM   #177
t8fanning
8v are still cool, right?
t8fanning's Avatar
I've done it once before. There's a group of guys from my local club who are planning on making the trip, and I'm thinking of going with.
1982 242 Turbo.
t8fanning is online now   Reply With Quote
Old 07-01-2017, 05:14 AM   #178
t8fanning
t8fanning's Avatar
Don't ask me how or why, but the fuel rail mount broke again. This time it was a total weld failure and the part is off on the side of the road somewhere. I looked for a while but no luck. I did a pull, heard a little pop and lost boost pressure. I went home and noticed what was missing. Luckily pulling the intake only takes 20 minutes or so.
I'll have to machine my own bracket from angle aluminum unless Nathan does them another way.
I also did a few other things. I refurbished my shift knob, made a little extension, and installed a foam isolater. Super easy to install from the top and makes a huge difference in cabin noise.
I'm not in love with the looks of the shift extension, I may have it anodized black or something but it feels much better now.
Old 07-01-2017, 08:19 AM   #179
Stiggy Pop
Stiggy Pop's Avatar
Well that stinks.
'79 242
943 pickup
Old 07-01-2017, 12:34 PM   #180
t8fanning
t8fanning's Avatar
Yes it does. The worst part is I have no idea why it failed. I pulled a strut bar off because I thought the rail hit it. Looks like it's something else.
Old 07-01-2017, 01:00 PM   #181
wennstroma
I have an early one, and the fuel rail mounts are attached at two points on the base plate of the plenum at 90° to yours. Its very solid.
Just having it attached at one point in that direction would bend those angle aluminum pieces with fuel pressure, boost pressure, and any preload that might be on the injectors. I thought I saw someone else's fail the same way yours did too.
Maybe it would be enough if you add an extra piece on the bottom open part of the angle aluminum piece so its boxed in like the early ones.
wennstroma is offline   Reply With Quote
Old 07-01-2017, 01:04 PM   #182
t8fanning
t8fanning's Avatar
I wonder when he switched designs. When did you get yours?
You probably saw mine. This is the second time it's failed and Nathan said he'd never seen it happen before.
Yes, I'm planning on replicating the rear mount with a gusset. Mine was only welded on top so it's probably going to be fine with both sides welded but might as well fix it once.
Old 07-01-2017, 01:17 PM   #183
wennstroma
I received it from him in late Februrary 2010, I think that was the first batch?
Old 07-01-2017, 01:46 PM   #184
Tuff240
240 Ninja
Tuff240's Avatar
IIRC, Bergen's cracked there also.
-Patrick
Old 07-01-2017, 08:04 PM   #185
Uncleknucklez
bruspeed
Bummer, I'd weld it top and bottom, and put a triangle gusset perpendicular underneath as well. Should have no problems then.
Nice work on the shift extension! I actually wish mine was a touch longer.
Old 07-01-2017, 08:19 PM   #186
Pro Sneaker Peddler
Don't we all
Old 07-03-2017, 01:45 PM   #187
GTJordan
Been here for too long
GTJordan's Avatar
Could the fuel line at the back not have enough slack, or is too heavy for the weld? Every time the engine rocks, it might be constantly tugging and pushing on the fuel rail?
Jordan
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 07-03-2017, 02:50 PM   #188
t8fanning
t8fanning's Avatar
I don't think so. There should be enough slack in both fuel lines to account for engine movement. Neither line is anywhere near taut.
Old 07-12-2017, 01:53 PM   #189
Uncleknucklez
bruspeed
What did you use to insulate around the shifter?
Old 07-12-2017, 01:55 PM   #190
t8fanning
t8fanning's Avatar
Foam shifter isolater from Ian (hiperfauto). It's a Volvo OE part.
Old 07-12-2017, 02:21 PM   #191
Cwazywazy
Cwazywazy's Avatar
Expanding foam works too.
Old 07-12-2017, 02:23 PM   #192
Pro Sneaker Peddler
No
Old 07-12-2017, 02:25 PM   #193
t8fanning
t8fanning's Avatar
Why is there a huge picture of expanding foam in this thread?
Old 07-12-2017, 02:26 PM   #194
Pro Sneaker Peddler
Why is there someone showing off hacky garbage in someone else's build thread?
Old 07-12-2017, 02:28 PM   #195
Uncleknucklez
bruspeed
Perfect, I will hit them up. Thanks.
Old 07-12-2017, 02:29 PM   #196
t8fanning
t8fanning's Avatar
No problem. I didn't even know it was a part option until I saw it a couple weeks ago in a thread. It makes a huge difference.
Old 07-12-2017, 02:32 PM   #197
Uncleknucklez
bruspeed
I have a the stock rubber boot, and a leathery boot installed, but I'm sure the foam would help a ton. Just trying to make the car as civil as possible.
Old 07-12-2017, 02:32 PM   #198
Quin
ಠ_ಠ
you didn't know it was an option until i told you it was.
who clogs their trans tunnel with sprayfoam?
Old 07-12-2017, 02:33 PM   #199
t8fanning
t8fanning's Avatar
I have the same along with an additional canvas boot I made. The rubber boot kept popping my shifter out of second so I had to cut it a bit. The foam makes the most difference by far.
Old 07-12-2017, 02:38 PM   #200
Uncleknucklez
bruspeed
Interesting, I haven't had any issues yet with the boots popping the lever out of gear. Although, I'm going to do some work on raising the trans mount (so I can work on the pinion angle a bit more to remedy my drive train vibrations) so I may run into other issues later.
