Old 07-12-2017, 02:39 PM   #201
Cwazywazy
Cwazywazy's Avatar
you didn't know it was an option until i told you it was.
who clogs their trans tunnel with sprayfoam?
Hey, someone here told me to do it. And it works. Though not something I'd do to a nice car.
I don't know what I have
Old 07-12-2017, 02:41 PM   #202
t8fanning
8v are still cool, right?
t8fanning's Avatar
What shifter do you use? I use a pro 5.0, and the shift knob that comes with it is angled down a little too much. I should just make a new one.
1982 242 Turbo.
Old 07-12-2017, 02:45 PM   #203
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Ebay special, This one:
http://www.ebay.com/itm/Core-Short-S...odel%3AMustang
Uses a Hurst lever, that I cut and extended (should have made it another inch longer).
I like the action, and have only rowed sloppy T5's in the junkyards, so this one feels premium
1980 242 Turbo
2004 V70R
Old 07-12-2017, 03:03 PM   #204
cosbySweater
cosbySweater's Avatar
Which ever one harlard has is sweet. That was the best shifting t5 I've ever felt
Old 07-12-2017, 03:04 PM   #205
Stiggy Pop
Stiggy Pop's Avatar
#foamgate
'79 242
943 pickup
Old 07-12-2017, 03:04 PM   #206
Pro Sneaker Peddler
Summit shifter with a homemade handle. I did refresh the trans before putting it in the car...
Old 07-12-2017, 03:09 PM   #207
Uncleknucklez
bruspeed
Now I'm curious if mine has a good shifting action. Who want's to come bang gears in this thing??
Old 07-12-2017, 03:21 PM   #208
t8fanning
t8fanning's Avatar
Does yours have positive stops?
Old 07-12-2017, 03:23 PM   #209
Stiggy Pop
Stiggy Pop's Avatar
I think this is the first complimentary thing I've seen you say about that car
Old 07-12-2017, 03:45 PM   #210
Quin
ಠ_ಠ
+1, leave it to dan crandall.
+1
Old 07-12-2017, 04:05 PM   #211
Uncleknucklez
bruspeed
Negative, Now, in modern trans, they all have internal stops, what's with the shift kits for these trans having the external stops?
Old 07-12-2017, 05:13 PM   #212
t8fanning
t8fanning's Avatar
I've read when you shift it hard it starts to bend the forks.
Old 07-12-2017, 05:31 PM   #213
cosbySweater
I love harlards car, I just like giving him crap more
Old 07-12-2017, 06:08 PM   #214
Pro Sneaker Peddler
+1
Dan didn't touch anything drivetrain-related.
EDIT: actually that's not true, but the transmission and gear linkage was all me. Dan did manage to work the shift lever loose somehow...
Old 07-18-2017, 01:31 AM   #215
t8fanning
t8fanning's Avatar
Finally got around to fixing the intake manifold. I made a new mount from some angle aluminum as well as some gussets. My buddy re-welded the joint and the gussets. No way it's breaking again. The fuel lines have plenty of slack.
While I was in there, I made some RX7 brackets and installed them.
Finally put on my LMs as well. They have Michelin Pilot Super Sports on in 225/45r17 and 245/40r17. Front effective offset is 0 and rear is 15 mm.
The rears rub a tiny bit on bumps. I need to center my axle a bit and maybe roll my fenders a little more. Maybe I could remove a bit of material from the spacer. Really what I need is some adjustable trailing arms to move the wheels to the front a bit.
I also need to get the rest of the air out of my brakes, the pedal is a bit soft.
Old 07-18-2017, 01:57 AM   #216
centason
CNT-FAI
centason's Avatar
Good sht, always like those alum welds.
Member: TBCCS
"Democracy is also a form of worship. It is the worship of Jackals by Jackasses." -H. L. Mencken
Any forums history.
Old 07-19-2017, 09:23 AM   #217
Uncleknucklez
bruspeed
The wheels look killer bud.
Shortening the trailing arms is what I will probably do next weekend. Going to section out .750", and box them.
What happens to the panhard bar when the trailing arms are shortened? I'm running an IPD poly unit, and I'm pretty sure the changing the angle that it mounts at can't be misaligned and taken up by the poly bushings, if that makes sense.
Old 07-19-2017, 09:35 AM   #218
Stiggy Pop
Stiggy Pop's Avatar
The fuel rail tabs is really weird, still can't understand how they were breaking on you. Sure looks solid now though.
Old 07-19-2017, 11:56 AM   #219
t8fanning
t8fanning's Avatar
Thanks.
I raised the rear a little bit, and centered the axle a little bit more and now I get no more rubbing, even on big bumps. I'm happy and not going to shorten my trailing arms until Ben gets out his new adjustable ones so I can use a real coilover in the rear.
But I bet you'll need to cut the panhard to change the angle, or cut one end off and use a heim joint. I don't think the poly will have enough misalignment.
I don't know either, I bet it was because only the top was welded. Maybe my fuel line does pull on it when the engine moves. I need to get a video of that. But in any case it's not going to break now.
Old 07-19-2017, 12:04 PM   #220
toms_elleck
toms_elleck's Avatar
This car is awesome.
-Thomas
toms_elleck is offline   Reply With Quote
Old 07-21-2017, 01:54 AM   #221
t8fanning
t8fanning's Avatar
My upholstery guy got this done way quicker than I thought he would. It's done in black street suede. The fabric doesn't match my front seats that well, but it's black and cheap and looks good. He did try to match the front Recaros with the horizontal striping. The Recaros have three horizonal stripes, and he put two in the bench. He was also going to recover my door cards, but they were in too bad of shape to spend time and money on (I've also pretty well reached my limit on car parts spending for a while). So I'm looking for some decent cards to recover, or I'll make my own out of aluminum if I can't find anything for a decent price. I also need to find a decent parcel shelf to recover. I have until September before he goes back to Venezuela. He's friends with the father of one of my buddies and is visiting for a few months. I'm getting close to my pretty much full black interior.
Old 07-21-2017, 10:45 AM   #222
Pro Sneaker Peddler
Time to hit the rest of the interior with black SEM.
Old 07-21-2017, 10:53 AM   #223
t8fanning
t8fanning's Avatar
Nah. I can be patient. Think how long that ugly orange hood was on.
Old 07-23-2017, 05:35 PM   #224
t8fanning
t8fanning's Avatar
I did some freeway pulls last night after a Saturday night meet. Wish I had some videos, but I hung with an R35 GTR from 50-90 or so until he started to pull on me. I took a few other cars to town, but one really quick wrx pulled on me by a half car or so. I talked with the fast wrx guy and he says he makes 460 whp on ethanol. I saw this on fb this morning:
Old 07-23-2017, 06:50 PM   #225
Pro Sneaker Peddler
Your car is set up to handle EJ25 crank-splitting levels of power. TURN UP THE BOOOOST.
