Old 07-12-2019, 08:17 PM   #1
Cwazywazy
Single jingle
Cwazywazy's Avatar
Default M46 differences?
I thought all 240 M46s were the same except for the overdrives.. Guess not. Swapping out my '86 M46 for an older model (not sure of year) with speedo drive and ran into an issue with the clutch fork.. The new trans came with one that I've never seen and when I put in the '86 fork it only has about half travel. I'm very confused. It looks like the '86 bell housing has more depth..
The new trans did come with a throwout bearing but it's wasted and I don't know if it would even work with my clutch.. (Dogdish M47 flyhweel)
I don't know what I have
Cwazywazy is online now   Reply With Quote
Old 07-13-2019, 06:10 PM   #2
planetman
planetman's Avatar
If you did everything correctly you shouldn't have problems.
AFAIK, there are only 3 bellhousings for all of the SOHC 4 cylinder engines that are for the M45 and M46.
These is an early bellhousing that only fits the early M45 and M46 with course spline input shafts made through 1978. The other 2 bellhousings fit the later M45 and M46 with fine spline input shafts and are basically the same. The only difference is whether the bellhousing has the notch at the top to go around the CPS sensor which is mounted on the back of the block.
Eric
Torrance, CA 90502
Old 07-13-2019, 06:30 PM   #3
They're boxy but good!
The top clutch fork looks bent
[/url]
Old 07-13-2019, 06:51 PM   #4
Cwazywazy
Single jingle
Cwazywazy's Avatar
I just swapped bell housings. Input shafts are the same but the top clutch fork in that pic only had about half travel in the new trans before I swapped housings.
Old 07-13-2019, 07:20 PM   #5
The earlier style is better. Those later clutch arms are not as strong and can bend easier than the early ones. The throwout bearing is almost the same just the early version has guides to slip onto the the pins on the arm. Make sure you grease the splines and throwout bearing guide tube with high temp grease.
Old 08-22-2019, 08:54 PM   #6
Cwazywazy
Single jingle
Cwazywazy's Avatar
I'm installing an M46 from a diesel 240. There was a shim of some sort on the end of the input shaft, I got that off, and it seems the output flange is about a half inch shorter than it should be. If I'm correct I can just swap it out with a 28mm socket and an impact? Also the shifter is longer? But the output is shorter? I just wanna make sure there's no other differences that I haven't noticed.
Old 08-22-2019, 09:00 PM   #7
Pilot bearing is different yes you'll need to remove that spacer / shim.
The flanges, cages and selector rods need to swap yes.
They both need to be J types however.
The speedo cable drive hole will need to be plugged.
Edit:
A dime filed down a little with a piece of rubber inner tube / EDPM pond liner inside the speedometer cable collar nut will be a good plug with readily available parts from the Volvo junk pile.
Old 08-22-2019, 09:18 PM   #8
Cwazywazy
Single jingle
Cwazywazy's Avatar
Edit:
Already removed shim, both type J, and I'm using a speedo cable. I'll find myself a 28mm socket tomorrow for the output. Manual diesels had a 3.56 rear end, right?
Old 08-22-2019, 09:21 PM   #9
Or an 1 & 1/8" socket.
Yep 354:1, but who's counting hundredths?
Old 08-22-2019, 09:46 PM   #10
Cwazywazy
Single jingle
Cwazywazy's Avatar
Aight, so just outta curiosity, the longer diesel shifter must mean the trans sits further forwards in a diesel? But whats with the different output flange?
Old 08-22-2019, 11:05 PM   #11
sbabbs
sbabbs's Avatar
THe diesel output flange looks like the smaller one is all. There are two different sizes on those. Smaller or bigger, but yeah they swap out. Also there is the guibo type and those swap out also.
1988 245 White slicktop M47 Wagon! Motor still out of it.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 548K Melted motor..
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 08-22-2019, 11:22 PM   #12
Wren
Porkchop Sandwiches
Wren's Avatar
I'm late to the party here, but I was under the impression that the dogdish clutch fork is different than the one used on the flat flywheels with the gas engines. I would imagine that the ones for a diesel flywheel may be different as well.
I've got a diesel (7-series) transmission at the shop. I should compare the fork from it to one from a flat flywheel.
Old 08-23-2019, 12:25 AM   #13
Lower / smoother power = smaller driveshaft, U joints, center support bearing & flange bolts.
