Old 07-14-2019, 10:22 PM   #1
Murploid1
Murploid1's Avatar
Default WUR connections
Hello,
I am in the process of removing and cleaning out my WUR (its a Kjet car)
Car is a 1982 Volvo 240 Turbo.
Aside from the fuel lines everything else was pretty loosely fitting and almost fell off!
One of the items that did was the pipe that connects at the top near the electrical socket. It makes a U shape and go downward, but to where I cannot see.
Where should this piece of rubber be connected? And what does it do? Or does it just connect to the top of the unit and remain unconnected to anything else?
Murploid1 is offline   Reply With Quote
Old 07-14-2019, 10:31 PM   #2
It doesn't go anywhere. It's just a vent tube. It's there to prevent water from getting into the CPR.
Old 07-14-2019, 11:21 PM   #3
Murploid1
Murploid1's Avatar
Excellent thanks!
Apart from cleaning the screens anything else I should be testing or doing with this unit out?
Voltage to the unit?
Old 07-15-2019, 05:05 AM   #4
apachechef
Burnt Sierra Madre
http://www.ferrari400parts.com/Warmu...atorrepair.php
Dammit, Lummert.
Old 07-15-2019, 01:46 PM   #5
Murploid1
Murploid1's Avatar
Another question....
The banjo bolt fuel fitting that goes into the WUR - should there be a copper crush gasket at the bottom pressing against the WUR? Or should it just be at the top pressing against the fuel fitting?
Old 07-15-2019, 04:09 PM   #6
planetman
planetman's Avatar
AFAIK, all banjo bolt fittings require 2 copper sealing washers, 1 for each side of the fitting.
Eric
Torrance, CA 90502
Old 07-15-2019, 07:42 PM   #7
Murploid1
Murploid1's Avatar
Thanks!
