Old 11-11-2019, 07:12 AM   #1
The_Geoffrey
Default Hubcentric Wheel Spacers
I have a 95’ 940 estate and I recently bought a set of Columba alloys with 205 width winter tyres fitted. The backs went on ok but the front need spacing by at least 20mm which got me thinking. The way the backs sit currently look a bit pants and would look better if I spaced them as well.
What’s the widest adaptor anyone has run or has heard someone else running without them leading to issues. I’ve found a company that makes them to order and can go up to 60mm which would sort the problem out but I’m a bit skeptical about them being so big?!
The_Geoffrey is offline   Reply With Quote
Old 11-11-2019, 08:13 AM   #2
AndrewNance
Amateur hour!
AndrewNance's Avatar
25mm front and 32mm rear used to be the special sauce around here for running FWD Volvo wheels on a RWD Volvo.
'71 142
Feedback
Old 11-11-2019, 10:35 AM   #3
Chumley360
I've got 25mm spacers all around on my 95 944 and things look OK, but the rear could use a little more push out.
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 11-11-2019, 04:17 PM   #4
Redheaded sailor bum
Redheaded sailor bum's Avatar
https://www.motorsport-tech.com/ is the company I used and got here super quick
I was running 1.5 and I ended up having alot of issues on the rear tires
Since then I switched to 25mm all the way around and never had an issue since
I do agree 25 fronts and 32 rears look better
1991 940 SE W/IRS (drift car)
Redheaded sailor bum is offline   Reply With Quote
Old 11-18-2019, 12:28 PM   #5
The_Geoffrey
Thanks for the ideas guys, 25 up front and 32 round the back does sound good.
I will eventually be running banded steels which will need spacing all round. I’ve ordered 1 wheel to get my fitment and measurements decided and then I’ll order the spacers, as good as the motorsport tech ones sound I will probably try my luck on eBay and report back with the results.
Old 11-27-2019, 08:26 PM   #6
quillc
yv1a.com
quillc's Avatar
I run 25/25 spacers on my 242 with 17" Tethys. I bought a set of Ben's spacers and extended wheel studs so I didn't have to do the bolted on spacer that you bolt on the wheel too. Ben's stuff is super nice.
Chris
www.yv1a.com
Old 11-29-2019, 04:19 AM   #7
The_Geoffrey
Have you got a link to these spacers?
Old 11-29-2019, 10:54 AM   #8
dbarton
Dejected by Volvo
dbarton's Avatar
https://www.bneshop.com/
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80.
Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085
Old 12-01-2019, 03:51 PM   #9
ermit71
ermit71's Avatar
If you are in the UK. Check if Classic Swede has the BNE ones?
Feedback
ermit71 is offline   Reply With Quote
