Old 02-23-2011, 09:53 PM   #26
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
$200 later to Oregon DMV I finally have new plates. Not sure why it took almost 2 years to get my life sorted out enough to get them. Street legal now!!!
One Volvo left.
1982 244ti (313chp), 2011 Audi S4 (333chp) , 2016 Kawasaki 650R (76chp)
DurableSwedish is offline   Reply With Quote
Old 02-27-2011, 07:03 AM   #27
DurableSwedish
Hunting for a turbo
somebody at work this week noticed that my brake lights don't work. The circuit boards are cracked and corroded. My lenses are cracked and in bad shape too so I bought a set of these:
Should be here next week, I'll post up a picture of them installed. I need to have a windshield guy replace and update the front and rear seals too, they are all dried out and split.
Old 03-09-2011, 10:48 PM   #28
DurableSwedish
Hunting for a turbo
Old:
New:
Plus wiring was screwed up for the tail lights, took it to RSI and they fixed it. I'll be visiting there more often from now on...Just need to get some more ca$h set aside for them.
Old 03-11-2011, 08:33 AM   #29
bjorny
bjorny's Avatar
those look great!
god i need a set of those lights... i put up a thread in the wanted section before but im reluctant to have them shipped over through ebay and find them all banged up and cracked in the package, also shipping was waay to much.. anyone know if theres a dutch or belgian company that imports them?
'Rock over London, Rock on Chicago!'
'89 240 GLT Sedan / '95 850 T-5R CY Estate
I'm no lightweight, but I don't weigh as much as two people (unless they're midgets):
Originally Posted by Paddler Ed View Post
Imagine Mad Max, but without the cheerfulness of the cars
bjorny is offline   Reply With Quote
Old 09-01-2011, 03:52 PM   #30
DurableSwedish
Hunting for a turbo
I worked on the car last night. Removed ALL extra crap in the car except for my tool box, removed a couple more vac lines and electrical lines not going anywhere, removed a handful of bolts/screws that weren't going to anything, removed the charcoal canister and all it's lines. The junk in the car was about 30lbs, the charcoal canister and all the nuts and bolts and hoses and clamps was about 20lbs.
I'm having a bunch of rattles underneath the car when the motor is revving, either from the exhaust or something else vibrating, it really detracts from the exhaust noise.
Bought some OEM body plugs to fill in the holes left from removing the AC system.
Just ordered up all new shifter bushings and injector seals to try and fix some more vac leaks to get a more stable idle. I think my head is hosed because it buzzes at 7k rpm. I have so much to do to this car!!
Old 10-05-2011, 04:14 PM   #31
klr142
Turbo, what?
klr142's Avatar
Your head, or the car's head?!!? You shouldn't be revving it that high... You need stronger valve springs to rev it that high, among other things. You trying to kill it?
Old 10-05-2011, 04:30 PM   #32
DurableSwedish
Hunting for a turbo
It was more of an accidental thing, I bought the bosch 6500rpm rev limiter and it's much nicer then revving too high. 1st gear is too short in the m46!
Old 12-10-2011, 12:16 AM   #33
DurableSwedish
Hunting for a turbo
Original:
Re-welded and partially polished:
Painted black:
[forgot to take a picture when the paint was drying, I'll get one Monday]
An update! I bought Jordan's 3" turbo back exhaust, cleaned it, polished it and painted it flat black with ceramic paint. Maybe the paint will help with some heat? I'll get some install shots when it gets installed next week.
I removed the stock 45lb battery and 5lb plastic battery tray with a stainless steel one that is about 6oz for a 19lb miata battery with similar cranking amps. Another 20lbs of weight off the front of the car. I've been working on removing a bunch of weight from the car so far:
-40lbs from no a/c
-20lbs from battery
-40lbs from removing everything from the trunk (carpet, spare tire, tar, repair tools)
-20lbs from scraping the tar out from under the carpet (still working on this)
-12 pounds from switching to lightweight wheels (about 4lbs lighter per corner with the enkei race wheels versus virgos)
-20lbs from removing the stereo and all wiring
-5 pounds from removing charcoal canister and all brackets
-30lbs from removing the crash triangles from the rear of the car
There's about 180 pounds from little things, switching to skinny bumpers should pull off another 50 pounds (awaiting installation in the garage). The race seats I have in my house are about 25 pounds lighter per seat including brackets, the OEM ones are freaking heavy, maybe 40-50lbs each? All that stuff just pulled almost 300lbs out of the car without any extensive modification or cutting...
I hope to get the car down to 2600lbs eventually. Stock was 3000, so 400+lbs shouldn't be hard.
Old 12-26-2011, 06:44 PM   #34
DurableSwedish
Hunting for a turbo
11 hours of professional detailing later...
Before:
After:
Old 01-10-2012, 10:46 PM   #35
DurableSwedish
Hunting for a turbo
doublepost
Old 01-10-2012, 11:12 PM   #36
DurableSwedish
Hunting for a turbo
Pulled the old ugly trim off the car
having the paint under the trim buffed out and a vinyl shop making me a satin black stripe to cover up the holes. Hopefully they can touch up some paint chips at the same time. I'm hoping to have the car back by Thursday.
Performance oriented note: I weighed the trim and it came out exactly at 5 pounds, so more weight reduction woo!
edit: whoops, just realized this is a before picture, forgot to take an after trim removal picture before the detailers took it away.
Old 01-10-2012, 11:29 PM   #37
smokeyfan1000
Guest
Just curious... how stable did the 240 feel at 140mph? Pretty solid, or getting light & scary?
Old 01-11-2012, 12:20 AM   #38
DurableSwedish
Hunting for a turbo
extremely light and scary! That was completely stock on a straight of road way out in eastern Washington. Probably a 3-5 mile straight shot to get up that high and brake. Not recommended with worn out suspension and brakes. The car is much nicer now, should be much more stable at high speeds.
Old 01-11-2012, 12:54 AM   #39
smokeyfan1000
Guest
With my suspension mods, my 240 is pretty good & stable @ 100 mph. I had to 104 mpg, before the mods,about all she'll do probably, but haven't tried over 100 with the mods.............yet.
Old 01-11-2012, 11:00 AM   #40
klr142
Turbo, what?
klr142's Avatar
140mph? Lol. What size tires were on the car at the time?
Old 01-11-2012, 12:01 PM   #41
propav8r
F*ck Edgar
propav8r's Avatar
I'd laugh my ass off if it was like 185/70/14 or 15s
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 01-11-2012, 02:04 PM   #42
DurableSwedish
Hunting for a turbo
I say 140 because the speedo needle was pointing straight down at the H in "MPH" and my friend in his saab 9-3 turbo said that's as fast as we got...
edit: whatever gearing will get me to 6000rpm in 5th gear with an M46 is the speed I was going. 195/55R15, 3.73 gears (stock I think), the top speed calculator says theoretical top speed is 142.4 so I think my estimate is pretty close.
Old 01-11-2012, 02:57 PM   #43
smokeyfan1000
Guest
Was probably doing 140 or close to it. Mesure your tire height in inches, and you can compute your actual speed using a formula,as you already know the diff ratio & rpm.
Old 01-11-2012, 03:08 PM   #44
klr142
Turbo, what?
klr142's Avatar
You crazy, mang!
Old 01-11-2012, 03:31 PM   #45
DurableSwedish
Hunting for a turbo
It's funny because it was still pulling hard, just ran out of gears. This was when it was totally stock in $400 purchase price status too (barely running after sitting in a guys driveway for a year or so). It was safe right? because Volvo?
Old 01-11-2012, 03:34 PM   #46
smokeyfan1000
Guest
Maybe speedo was way off then? Or maybe your speedo is KPH?
Old 01-11-2012, 04:23 PM   #47
DurableSwedish
Hunting for a turbo
it did take a couple miles of straight farm road to get to that speed...
Old 01-16-2012, 03:44 PM   #48
DurableSwedish
Hunting for a turbo
This car really needs an LSD...
Old 01-31-2012, 10:00 PM   #49
DurableSwedish
Hunting for a turbo
The restoration shop I use: http://www.apexautospa.com/
Finally had some time to install some black vinyl over the removed trim holes, they also touched up the whole car and filled in all the chips. It looks even more awesome. They will be painting my group-a spoiler after I get the windshield and rear window seal replaced.
Old 01-31-2012, 10:16 PM   #50
holtzboy
Honda CRV DD WTF
holtzboy's Avatar
Looks like you have made some major progress, looking good. There should be about 30 pounds of sound deadening material. That's how much I got out of my 79 242.
1. 86 244DL- 1st car & owned for 17 years, 500k miles, 94 B230FT mild build in the works
2. 87 244DL - Sister-in-law's DD
3. 93 244DL - Daughter's DD
My feedback thread
holtzboy is offline   Reply With Quote
