Old 10-19-2019, 02:53 PM   #101
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
driver's side is 27540R18, passsenger side is the 21545R17 just to show a comparison.
They are Jaguar F-type wheels! I'm still working on the car, little bit at a time. I added 3x original horsepower (110 to 320), now to add more lightness!
One Volvo left.
1982 244ti (313chp), 2011 Audi S4 (333chp) , 2016 Kawasaki 650R (76chp)
DurableSwedish is offline   Reply With Quote
Old 10-19-2019, 10:07 PM   #102
RvolvoR
245s fit easily in the front...but you need 245/40 at minimum and 275/35s in the back and cutting out the inner fender and pushing the outer skin out.
Old 10-19-2019, 10:07 PM   #103
RvolvoR
the 275/40 is too tall for the fender well
Old 10-20-2019, 02:07 AM   #104
DurableSwedish
Hunting for a turbo
Yeah, sidewall is tall, but the brand new sport contact 2 tires were free :-)
Old 10-20-2019, 03:23 AM   #105
RvolvoR
free doesn't matter if they aren't right for the car...do it right and do it once or do the same thing multiple times while spending 3x the time and money.
Old 10-20-2019, 02:09 PM   #106
DurableSwedish
Hunting for a turbo
Lol, that's the theme of the car! Keep wasting money and revising it
Old 10-21-2019, 02:01 PM   #107
klr142
Turbo, what?
klr142's Avatar
passenger seats and seatbelts removed for more weight reduction.
debating on having it covered in leather to make it nicer.
Hah, but seriously. Why make the car more annoying to drive?
Where are the side pictures? The 275s will actually NOT clear everything unless your rear axle doesn't move at all(not only because of the width, but the height!). I recommend sticking with the same size front and rear so you can actually fit them and the car's handling isn't negatively affected(understeer). 245/35-18, 245/40-18(still tall) or 235/40-18 is what I would run, personally. What width and offset are the Jag wheels? The tires you posted are too tall for the car.
Old 10-21-2019, 02:03 PM   #108
klr142
Turbo, what?
klr142's Avatar
Hah, didn't see there was another page of comments... Like Asher says, those tires don't fit the car, they will rub and you will be doing body modifications to run them(or just pulling your hair out instead of driving the car, which you seem to maybe enjoy?!).
What are the dimensions of the wheels?
Old 10-21-2019, 03:48 PM   #109
RvolvoR
I said that because hackster had issues getting the wheel perfectly centered in the well front to rear to get 275/35s to fit.
Old 10-21-2019, 04:17 PM   #110
hackster
I saw the car when it was at PRE in the summer, cool car. I have a few buddies that work there so I get to shoot the **** with them on occasion back in the shop.
Cool car.
Just to chime in on those rear tires a touch. I have a ton of time getting the 275's to fit the car. I am running 275/35r18 Rival re71r's front and rear on a 10" wide wheel.
It is going to depend on your rear ride height. If your car is relatively high and you dont want to tuck the tire, probably could make it fit.
The problem is the taller the tire, the farther you have to move the wheel forward. I am very close to the front of the fender, probably less than a finger away. This gets you farther away from the taper in the rear of the fender opening and allows a bigger tire. My car is lowish, but wish I could go lower. When I get the 315's I will lower it more and chop up the exterior.
You are local if you ever want to see how I did my rear fenders you are welcome to check it out.
Without a ton of work I think getting a 275/40 is going to be tough to fit in there.
Sean
hackster is offline   Reply With Quote
Old 10-21-2019, 07:48 PM   #111
77volvo245
77volvo245's Avatar
run 245/40 imo
STSmachining
Old 10-22-2019, 08:01 PM   #112
DurableSwedish
Hunting for a turbo
I don't mind body work, been looking for a good shop that can pull the rear fenders or mini-tub it. I have all the trianglesunlimited.com rear adjustable stuff, so hopefully it'll adjust where it's supposed to.
My DD is a 2011 S4, so I don't mind that the Volvo isn't comfortable at all lol
Old 10-23-2019, 10:36 AM   #113
RvolvoR
you can't really "minitub" it. The rear frame rails are in the way. Those tires are physically too tall for the fender well.
Old 10-23-2019, 12:19 PM   #114
klr142
Turbo, what?
klr142's Avatar
Sell the tires for and get proper sized ones. If you're trying to keep the tires because they were free, what the hell is the point if you are going to spend a thousand or two trying to make them fit the chassis when you'll never order that ridiculous size again? That doesn't sound like you're saving money. Or headache.
Old 10-23-2019, 12:21 PM   #115
culberro
culberro's Avatar
245/35r18s will fit, but you can't get super low with them. I have a set for the drift car, and just use them when I need to roll the car around or I'm waiting for the "normal" wheels to get new tires on them.
You will need to trim and roll the rear fender lip, and widening the rear fenders 1-2" would be even better. Just have Hackster do your rear fenders
Old 10-23-2019, 01:39 PM   #116
klr142
Turbo, what?
klr142's Avatar
He's talking about 275/40R18s, though, so wider AND taller.
Old 10-23-2019, 01:44 PM   #117
culberro
culberro's Avatar
Oh I know. I'm just letting them know my experience with 245/35. They fit, they work... but it's not the best option. Getting 275/40s to work is going to be a pain.
Old 10-23-2019, 01:50 PM   #118
Stiggy Pop
Stiggy Pop's Avatar
275s are also unnecessary for a 300-400hp car. Buy tires that fit in a compound that grips.
'79 242
943 pickup
Old 10-23-2019, 03:12 PM   #119
RvolvoR
if just a ****around street car. If you actually want to use it and have it handle well, you put them on all 4 corners even at 300-400hp. The car still weighs 3000lbs after all.
Old 10-23-2019, 04:07 PM   #120
DurableSwedish
Hunting for a turbo
the tires are conti sport contact 2, so good tires. it should only weigh 2800lbs. I want the widest tires possible. This is not a budget build lol, like under $100k?
Old 10-23-2019, 06:16 PM   #121
hackster
Huh, thats simply an opinion based on what you would do with the car......not what someone else may do or want to do with the car.
This is what is confusing to me, and even though I have no dog in this fight, what do you want to do with the car? Is it an all around fun car, drag car, street car, autocross, road race?
Personally unless your goal is to road race the car or be a serious cone killer I would stuff the stickiest 245 on it that you can. Some of the tires out now are a 200 treadwear tire that stick like a race tire in most conditions. RE71r and Rivals are two of the top tires.
Its a ton of work to get 275's to fit in the rear and to find a shop that is going to do it is going to be big money and if exterior paint is of a concern to you, you will need to reshoot the quarters of the car.
If its not a budget car, why run free tires or wheels with adapters?
Just my .02.
Old 10-23-2019, 06:40 PM   #122
Vol242vo
Keep it clean...
Vol242vo's Avatar
Are the wheels 18 x 9.5? Wondering about possible tire stretch with 245s on a 9.5 inch wheel unless you’re not against it. Personally I hate the look of stretched tires...
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 10-23-2019, 06:42 PM   #123
Stiggy Pop
Stiggy Pop's Avatar
Yeah that’s fair! My mind was preoccupied with the rear for traction, not on the front/overall lateral grip.
Old 10-23-2019, 08:29 PM   #124
DurableSwedish
Hunting for a turbo
I got the wheels and tires for free and thought they would be fun to run on the car. Ill probably put the tires up for sale online somewhere then get a lower profile. It was just an idea. I already spent a ton of money at PRE this year, so am just putting more of the parts I've had in my garage on the car. Ideally it'll be a fun track day/auto cross car. Its more of a hobby to play with. I enjoy throwing large amounts of money at it.
it's still maybe worth $5k even though I've spent maybe $30k+ on it in the last 15 years...It's a fun toy for me. It was the first car I ever bought too, so some sentimental attachment to it.
Old 10-23-2019, 08:56 PM   #125
DurableSwedish
Hunting for a turbo
Here are some rough side pictures of the wheels and tires on the car. The centerbore of the Jag wheels are 1.7mm smaller than the centerbore of the volvo, so I need some lug centric on the Jag side spacers instead of hubcentric ones. the fronts rubbed on the front struts so need to be pushed out about 10mm (for 35 total) and the rears were pretty centered with the 32mm, but poked out about 4mm due to not being able to be seated from the bore differences. I'll try and get the tires properly mounted and balanced this weekend so I can see how things look with lowered down all the way.
