Old 07-21-2019, 02:02 PM   #126
sksmith
sksmith's Avatar
Still a lot to do. Got the driver & passenger sides cleaned with a wire wheel this morning. Still need to wire wheel the trunk pan & area above the differential, but it's a little toasty out there! My son volunteered to work on some of that tomorrow.
I'm soaking the rear wheelwells with kerosene again & letting them cook until tomorrow evening. Then the multi-tool / wire wheel treatment.
A little scope creep coming. I've decided to remove the front clip so I can get the front inner fenders, backside of the front valance / fenders & frame horns. I'll also need to remove the front crossmember again, but thinking I can keep the steering & brake lines all connected.
I'll probably install the engine onto the crossmember & install as a sub-assembly.
That's a job for next weekend though.
Thanks,
Steve
Pics:
After the China Freight multi-tool -
After a good wire brushing with the angle grinder -
Old 07-21-2019, 06:53 PM   #127
didenpx
didenpx's Avatar
Looks great. Beware the scope creep.....or just embrace it.
My feedback: http://forums.turbobricks.com/showth...hlight=didenpx
1970 1800E (Project Roedluvan:http://forums.turbobricks.com/showth...highlight=1970)
1977 242DL "Senf" (Summer Cruiser)
2x1973 1800 ES (Project Reanimator; disassembly and parts detailing to begin Winter 2020)
didenpx is offline   Reply With Quote
Old 07-21-2019, 07:34 PM   #128
sksmith
sksmith's Avatar
Paul,
This started as a coil springs / shocks / brake job!!
Thanks for the compliments!!!
Steve
Old 07-23-2019, 07:58 PM   #129
sksmith
sksmith's Avatar
One rear wheel well scraped.... God, what a chore!
Passenger side tomorrow evening.
Steve
Old 07-24-2019, 08:24 PM   #130
didenpx
didenpx's Avatar
Steve,
Is the undercoating you're dealing with the Waxoyl (or similar) stuff or black rubberized stuff?
Old 07-24-2019, 08:56 PM   #131
sksmith
sksmith's Avatar
Steve,
It's the black rubberized crap. It'll get there, just going to take a while.
Took the night off from the car, had a couple of late meetings. I'll hit it again tomorrow.
Steve
Old 07-27-2019, 09:50 PM   #132
sksmith
sksmith's Avatar
Rear wheelwells. After scrapping, I got a mini needle scaler from China Freight and knocked off most of the undercoat.
I broke down & ordered one of the undercoating removal tools. Eastwood sells one, but I found a similar tool on Amazon for about $60 less.
It arrives on Tuesday, so I'm going to take the mini needle scaler into some of the tight spots tomorrow morning. Then my son and I are going to remove the front fenders, front crossmember and maybe the front fascia.
Here are pics of the passenger side, driver side looks similar.
Old 07-28-2019, 08:55 AM   #133
didenpx
didenpx's Avatar
that looks to have worked like magic! Super clean.
Old 07-28-2019, 09:26 AM   #134
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looks like good metal. Whoo hoo!
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 07-28-2019, 05:37 PM   #135
sksmith
sksmith's Avatar
Yes, all in all, very little rust on this car.
My son & I dropped the front crossmember today. Bought a dolly & built a padded rack for it. Took it off a unit with all everything still attached, except for the steering box. It came off separately.
Got it all filthy cleaning the undercoating, so I need to clean it before I drop the engine onto it.
Might go back out tonight to mess with the cleaning.
And my son just loves helping me!
Steve
Old 07-29-2019, 10:09 PM   #136
sksmith
sksmith's Avatar
The new stripping tool arrived from Amazon this evening, so I tried it on the passenger side wheel well.
All I can say is that it's a winner! Since it's air driven, it's way lighter than my angle grinder & the wire wheels are about an 1" wide, so you strip more area quicker.
Here's the link to the tool & a quick photo after about 30 minutes of free time I has tonight.
https://www.amazon.com/Sunex-SX8200-...P98S00H2XN3XVG
Old 07-30-2019, 02:41 PM   #137
IansPlatinum
IansPlatinum's Avatar
Are you applying phosphoric acid or anything to prevent flash/surface rusting of the steel now that it's exposed?
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 07-30-2019, 06:12 PM   #138
sksmith
sksmith's Avatar
No acid. It's going to get a sanding & cleaning prior to epoxy primer.
Steve
Old 07-30-2019, 07:31 PM   #139
IansPlatinum
Steve
Rust inhibitor at all?
Old 07-30-2019, 08:40 PM   #140
sksmith
sksmith's Avatar
Shouldn't need it. Epoxy primer over clean metal is sufficient.
Epoxy primer actually seals out the oxygen from the metal, leaving very little chance of rust forming.
I will need to sand & clean any flash surface rust prior to spraying, due to cleaning the undercoat as time (and garage temps!) permits.
Steve.
Old 07-30-2019, 10:18 PM   #141
matt b
You can also use a good etch primer on that metal. The acidity of the primer has a way with very very minor flash rust.
Old 08-01-2019, 10:11 PM   #142
sksmith
sksmith's Avatar
Matt b & Iansplatinum -
I will be using some phosphoric acid on any pits, prior to epoxy primer.
Had an issue with my compressed air filter / dryer. I decided to quit collecting water. I was getting a lot of moisture at my air tools, so I stopped and ordered a Devilbiss QC3 filter / dryer for my hose reel. It came in today and I just finished installing it. Pricey, but good reviews. I also like that it has a warning to change the filter.
I'll see how it works and, if it works as advertised, I'll order one for my blast cabinet and for my workbench hose.
I also reworked the piping to my hose reel so it should keep any moisture from getting into it.
I'll try it out Saturday morning, plans tomorrow evening.
Steve
Old 08-10-2019, 09:29 PM   #143
sksmith
sksmith's Avatar
Big shout out to member vertigosity for giving up his time and help today getting the windshield corners!!!
While I was down that way, I took a detour to Dyuss, AR to see the boyhood home of Johnny Cash. It's been restored by Arkansas State University to how it looked in when he was a young boy. Pretty cool to see, even if it is just a little old house.
Looking forward to getting back under the Swede tomorrow and get some more cleaning done on it.
Steve
Old 08-11-2019, 11:31 PM   #144
vertigosity
vertigosity's Avatar
Glad to see some chunks of one of my follies go to keep another project alive :D
93 245 5.3L LSx / 90 Miata / 90 Spec Miata
Old 08-13-2019, 09:06 AM   #145
VolvoNut4Ever
They had an orange, red, yellow & black that looks like what I have.
Any info you can share on those different upholstery options? I'd love to find a source for those original-style striped fabrics. Any link or contact info would be appreciated!
VolvoNut4Ever is offline   Reply With Quote
Old 08-13-2019, 11:51 AM   #146
sksmith
sksmith's Avatar
I do not know what the codes were for the different colors.
VP Autoparts still has front seats listed. but I may have gotten the last of the full rear sets. Looks like they only have a rear back listed now.
http://www.vp-autoparts.com/US/main....startoffset=50
Steve.
Old 08-17-2019, 07:12 PM   #147
sksmith
sksmith's Avatar
Took off the driver side fender, then finished cleaning undercoating & sanding the driver side inner fender today.
Got a good pic of the rust also.
I'll get out & finish the passenger side tomorrow, it's half finished. Need to remove the fender & get the upper area, and side of the cowl.
Old 08-17-2019, 09:57 PM   #148
Vol242vo
Keep it clean...
Vol242vo's Avatar
You don’t mess around, do you?!? Looking really good, nice to see the amount of attention you’re giving here.
Old 08-18-2019, 07:12 AM   #149
sksmith
sksmith's Avatar
Thanks Vol242o.
Getting the rest of the underside this clean will be a chore. Not really looking forward to it!
Steve
Old 08-18-2019, 12:15 PM   #150
sksmith
sksmith's Avatar
Passenger side done. No rust on it, other than some surface rust where cowl side, bulkhead & inner fender join. Both sides have it. There was a ginormous glob of seam sealer on each that had hardened with age.
I bought a "spot blaster" off of Chinazon, going to try it for those areas. Can't quite get to them with anything else I have, so I'll try it out.
No pics, looks like the other side, just without the rot by the floorpan.
Next up - removing the seats & carpet so I can get a grip on the rust that needs repaired.
Steve
