ukemike
- Feb 27, 2021
- SF Bay Area
Hi, my first post here. About 18 months ago I bought a 1991 240 Wagon MT, for my son's first car. We are currently having a problem with it. The turn signals stopped working.
The relay works because the blinkers work. The bulbs are all good. And I put a multimeter on the terminals on the turn signal switch and the switches seemed to open and close as expected.
The fuse (#5) for the turn signals blows when the car is on. We did just a bit ago put in a new fuse and turned the ignition to the on position without starting the car, and the blinkers all operated as they should. Once we started the engine though, the fuse blew.
We have traced our the wiring to the blinkers and all the insulation looks intact and in good shape. The fuse list on the fuse box cover says that the fuse also includes:
I'm not sure which are the tail lamps but when the head lights are on the bottom lights (which is also the brake lights) are on. The lights on the top of the rear cluster never seem to come on at all, even when the fuse was intact and the headlights were on. All the wires back there look and feel like they have intact insulation and I don't see anything like a short circuit.
Maybe unrelated and maybe not. When we bought it we noticed that the wires in the passenger side rear hatch hinge are frayed and one is broken. That looks like a hell of a hassle to fix those. Not sure what those wire power. The wires in the drivers side hinge look intact.
direction indicator
tail lamp
control unit preheater (don't know what this is)
diesel (this is not a diesel)
tail lamp
