Old 03-30-2009, 10:28 AM   #1
JohnMc
JohnMc's Avatar
Default YASVT (Yet Another Sixteen Valve Turbo) - now 16V Whiteblock (LS)
What the heck, I thought I might do a project thread too instead of just randomly glomming pics into other threads. Belatedly, since it's nearing completion.
Background: In Dec 2005, I bought a pristine '93 245 Classic (#1141/1600) on ebay. Looked brand new still, not a speck of rust underneath, and a brand new (actually, not 'nearly') tan leather interior. And under the hood, a very neatly swapped '93 940T drivetrain - round toothed B230FT and AW71 trans. When I got it it was running a nice healthy 12 psi. Felt fast and peppy!
(Shouldn't all late model 245's have come from the factory with this under the hood???)
The skinny 14" wheels came off, 17" wheels went on. IPD lowering springs and Bilstein HD's (it already had IPD sways).
And gradually, I'd gotten used to the amount of pep it had, and wanted more. The 13C was quickly out of puff, so the next step was browntops, NPR intercooler, 3" exhaust, and a 16T turbo.
That was more like it. Somewhere along the way (as planned) I got rid of the AW71 and put in an M47. Which lasted about 8 months.
So a T5 went in.
It ran a 14.0@97 with that setup.
During the spring of '08 I put on a 531 head, with an IPD Turbo cam and 37.5 exhaust valves, with some mild porting to match the larger valves.
Was it faster? Butt dyno was a little ambiguous on the matter. In the fall of '08 it did run a 13.8@100.
However, it wasn't running quite right that evening. Bad tank of gas? I'd tried to compensate for that by putting in some octane booster, which seemed to make it slightly worse if anything. I fidgeted with the plugs some. It got a little better. I should have gone home, but no, I pushed for some improvement over the previous year's 14.0 and got the 13.8. But only with some fairly high boost levels and a little pinging. Here's one of the runs in a datalog:
Car survived the night, I drove it home, all seemed well. But inside the motor, 2 rods were slightly bent, a 3rd bent even more. And probably stress cracked from bending. They survived a few more days of normal use, until on the way to work, #2 let loose at around 15 psi. BAM*crunch*clatter*crunch*smoke*clatter. Yay, cross flow crankcase ventilation!
Bendy rod:
Got a '94 940T junkyard motor. 240K miles, still crosshatching in the cylinders. However, also a lot of copper showing on the bearings. Briefly considered just slapping bearings in it and putting it right into the car. ... ... Nah!
Got some blingy rods and pistons...
...before realizing that they didn't work together. Crank-steered pistons, and piston steered rods. D'oh! RSI to the rescue with crank steered H-beam rods in the stock length. Uber strong Pauter rods sold.
Cruising the PnP for a aux. shaft with dist drive gears, I spotted a 940GLE. New addition to the sleepy Volvo section of the PnP! Opened the hood, yep, 16V head still on. Yanked off the t-belt cover, yep, timing belt still intact. Score!!! (Oddly enough, there was a parking violation sticker on the driver's side window, AFAIK it was jsut abandoned somewhere too long, got towed, then sold off). My project just got more complicated and expensive. D'oh!
J/Y shortblock with J/Y 16V head sitting on top:
Striving to make it fairly easy, I used sdturbo's intake adapter to put an 8V intake on the 16V head. Did some porting to match the round shape of the manifold to the oval shape of the head:
Also used sdturbo's tensioner setup. A very nice bolt on solution that still uses Volvo parts (belt, idler, tensioner):
Also, tried a HE351VE Holset for size, as they are intriguing (variable aperature for quick spool and mega flow). But the shear physical size of the hotside made me scrap that idea. Just didn't fit, and I don't want to reconfigure the entire engine compartment just to fit an extremely bulky, 50 lb 400 hp turbo. Even if it was dirt cheap and the variable gate stuff was very intriguing:
To mount the block distributor, I got on eBay.UK and ordered some dinky little Citroen cap. Clips right onto the distributor body, but the 'roof' is somewhat lower inside the cap. So I had to trim about 1/2" off the tip of the distributor shaft, re-notch the stub slightly, then chop the bottom 1/3" (+/-) off the stock rotor so it would sit down a little lower inside, then the cap fit properly. And it can barely be removed and replaced with the head on. The dist body itself, however, is there for the duration. Zoidberg cap:
After putting the motor in to check for fit on the Holset, I started to see some problems with the intake manifold. The problem with the 16V manifold is that it points right at the master cylinder. Well, the mounting point for the intake on the 16V head is farther out and I think angled up slightly more, as compared to the 8V. So the 8V intake isn't quite a miracle solution to that clearance problem (although it probably avoids that anecdotal flow issue under boost the 16V intake supposedly has).
Two pronged solution - first, carefully bend that brake line over so it runs closely along the master cylinder. Secondly, go to the PnP and get an 850 throttle body. I found two different sizes there, and got the larger one (3" OD). Much shorter, bigger throttle, nice non-rigged TPS mount. w00t! Only problem was that it mounts with 4 bolts, not the 8V's weird 3 bolt pattern. I found that two of the 8V bolts would work once the 850 TB holes were enlarged, with the TB just rotated a few degrees off level. For a 3rd bolt, I just drilled a hole in the intake and put in a stud with some JB-Weld for sealing. For the 4th hole, I would have done the same, but it was aimed at a tricky transitional area on the 8V plenum where the side drops down sharply to the #2 runner. I didn't think the same trick would work there, so I left that one off. 3 bolts out of 4, should be OK. I think. Clearance issue is now gone:
Started dressing the motor. Engine harness back on, injectors/fuel rail back on. Throttle cable and throttle spool back on. Hmmm... (really should have taken a picture at this point to illustrate things). Well, on an 8V manifold the brackets hold the cable and spool up above the manifold fairly far. Which isn't a problem when the 8V manifold is sitting down farther in the engine bay. But on a 16V head, it's poking up higher. To the point where they'd leave dents in the hood when you close it. So I hammered, bent, trimmed, hacked at both brackets until they sat down a little over an inch. Even after all that, they are still the high point of the motor, and I'm slightly uneasy about their proximity to the hood. I guess on the positive side, the hood does curve upwards across the center from the sides, and the center section is raised even more. Fingers crossed that I don't have to do more. Or that the engine doesn't rock over under power and jam the spool against the hood. *THINKFASTANDSHUTTHEKEYOFF*
I put a short (1" tall?) PV motor mount on the left side, to lean the motor over a little and get it away form the A/C line on the firewall. With stock mounts (well, diesel mounts) in, the engine was about 1/8" away from these lines. I considered gently bending them to the right, but I didn't like the odds on that. So I left them alone and did the motor mount thing.
The JGSTool's log mani is arriving very soon. And I already got the (I'll regret this at some point in the future) knockoff ball bearing GT3076R turbo. Yes, non-optimal cheapness afflicts that side of the motor. But it's been dragging on long enough and cost enough at this point that I'm jsut getting it done for now. In the future, I'll likely revisit it with a 'real' manifold and a 'real' turbo. For now though, a log mani (1.6" ID tubes), GT3076R turbo with ATP 3" V-band adapter and internal wastegate going into the 3" Dp and exhaust.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-30-2009, 10:40 AM   #2
.t.i.m.m.y.240
.t.i.m.m.y.240's Avatar
Looks great! You make it look so easy.
.t.i.m.m.y.240 is offline   Reply With Quote
Old 03-30-2009, 10:43 AM   #3
OldSchoolEuro
That is going to be a monster....GOOD JOB!
OldSchoolEuro is offline   Reply With Quote
Old 03-30-2009, 10:51 AM   #4
Bob
Away
Bob's Avatar
But it's been dragging on long enough and cost enough at this point that I'm just getting it done for now.
I know that feeling
Bob is offline   Reply With Quote
Old 03-30-2009, 10:58 AM   #5
JonnyP
Bored Member
JonnyP's Avatar
I love that intsall on the first turbo motor. Looks completely stock!
JonnyP is offline   Reply With Quote
Old 03-30-2009, 11:25 AM   #6
JohnMc
JohnMc's Avatar
It was extremely clean. Not a single thing looked non OEM/factory under the hood. Later on when I MS'ed it I found a wire in the passenger footwell that looked a bit out of place, that was it. Don't know who did the work, but it was well done.
Old 03-30-2009, 11:31 AM   #7
JohnMc
JohnMc's Avatar
Forgot to mention how snug it was getting the trans back on. The 16V head doesn't let the motor lean back as much, so I couldn't fit the trans on with the bellhousing attached. Even with it roatated so the starter bump wasn't hitting, the rest of the bellhousing would hit the tunnel before the pilot shaft had hit the center of the pressure plate so it could move forward.
Which would be a bigger problem if I still had an M47 with the bolts inside the bellhousing. But the T5 swap has external bolts holding the trans to the adapter plate. So I pulled it off the bellhousing, put the bellhousing on, and then put the trans on the bellhousing.
I'd heard that it was too snug to put the motor in the car with the trans already attached, so I didn't even try. I could see how it wouldn't work though, just not enough clearance between the back of the head and the firewall, and the oil pan and the crossmember, and the bellhousing and the tunnel.
Old 03-30-2009, 12:55 PM   #8
lookforjoe
lookforjoe's Avatar
Nice work there!
Thanks for describing all the little mods required to make things fit, it really gives a better sense of what you've done to make it all come together thus far.
Youtube vids when it's running???
My XR July2013 - 446AWHP @ 8K rpm
Old 03-30-2009, 01:55 PM   #9
Vol242vo
Vol242vo's Avatar
Nice attention to detail, everything is looking really nice! Just gave her 5 stars!
Derek - 1980 242
Vol242vo is online now   Reply With Quote
Old 03-30-2009, 09:28 PM   #10
sdturbo
sdturbo's Avatar
Solution for the tb fitment problems is in the final stages of development and should be on the shelf and forsale by the end of the week.
It also offers the advantage of increased plenum volume and the ablitly to run the larger 16v/850/960 style tb.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 03-30-2009, 10:04 PM   #11
JohnMc
JohnMc's Avatar
Looks nice, that would take care of the cable bracket/spool clearance issue as well.
After dropping mine down by about an inch, I put the hood on and saw about 1/4" clearance. To the hood pad, though, more if it was bare metal under there.
Old 03-31-2009, 03:51 AM   #12
The Redeemer
The Redeemer's Avatar
Wow! Looks great!
The Redeemer is offline   Reply With Quote
Old 03-31-2009, 06:59 PM   #13
JohnMc
JohnMc's Avatar
Well, the DEI concept was too complicated, I always thought. Why not just route the exhaust from one cylinder to another cylinder more directly?
Yeah, I just need to use an 8V camshaft on that side, that way one of the exhaust valves works as the intake, the other as the exhaust...
Yeah, the log manifold came. Welding and cutting are in my near future. The Chinese GT3076R fits nicely underneath with the flange pretty much centered in the manifold. Zap, weld, cut, smooth, should have a turbo hanging on the motor before long. Parts to plumb it all are in the mail.
Old 03-31-2009, 07:23 PM   #14
shellshock
Below, is a photo of Clay
shellshock's Avatar
Will I see this car at midsommar this year?
Looks Sweet man!!11
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 03-31-2009, 07:35 PM   #15
JohnMc
JohnMc's Avatar
It's coming together nicely. I'd have to hit a major snag to not make it at this rate.
Old 03-31-2009, 08:03 PM   #16
Poik
Backwards Turbo
Poik's Avatar
That cap does look like Zoidberg!
Great project, I look forward to reading more progress.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 03-31-2009, 08:47 PM   #17
Tom Wiley
Man. THis thing is going to be a SLEEPER!
Tom Wiley is offline   Reply With Quote
Old 03-31-2009, 09:14 PM   #18
80/20 speed parts club
thank you for all the info! this answers a hell of a lot of questions!
Old 03-31-2009, 09:22 PM   #19
btw what engine mounts are they exactly and what rear cam seal did you wind up using?
Old 03-31-2009, 09:36 PM   #20
JohnMc
JohnMc's Avatar
I tore up some poly stage 2 mounts pretty quickly with the 8V motor. I'm still pondering what to do with this.
Currently it has a diesel 240 mount on the right side, and a Volvo PV motor mount on the left side, because it's so short.
I just got these in the mail, though, I'll be trying them on for size. Dirt cheap ($3.10) old Dodge V8 pickup motor mounts. With interlocking metal tabs. They offer full cush 99% of the time, then under stress, the deflect a certain amount and then the tabs lock into each other. Could work...
I'm also keeping an eye on posts around here where people are working on motor mount solutions for 240's. The basic problem with the stock 240 mounts is just that they are so close together. You either need to fix that with some custom brackets, or run a 3rd mount. Or a cargo strap...
Rear cam seal is just a normal plug like you'd use in an 8V head. 16V head has the same sized hole back there.
Old 03-31-2009, 09:51 PM   #21
MrBill
fige=500Dollar Mistake
MrBill's Avatar
man that manifold looks so much better than mine
Someone say crazy rays?
Old 03-31-2009, 09:55 PM   #22
JohnMc
JohnMc's Avatar
You can see up close that they did a lot of grinding on it to make it look nice. And then put some sort of coating on it. Probably just flat black BBQ grille paint.
Old 03-31-2009, 11:13 PM   #23
VQ
Not such a PRVert Anymore
VQ's Avatar
That is awesome! I remember reading about you buying the car when you did, wondered what had happened to it, answers a lot of questions!
Old 03-31-2009, 11:44 PM   #24
sdturbo
sdturbo's Avatar
I am excited to what that turbo can do.
Old 03-31-2009, 11:51 PM   #25
thelostartof
unbalanced chemical
thelostartof's Avatar
about time ... that is what i have been wanting to do for ages, just never could get anyone to weld the flanges i have sitting here ... damnit ... looks pipe .. price?
