Old 02-27-2017, 07:41 PM   #1
CaseyHooligan
CaseyHooligan's Avatar
Default Oil Pump Mods - Max Effort
I'm experimenting with oil pump mods in order to increase flow volume and efficiency at lower rpm's and also add reliability...
So, I'm in the middle of building a solid turbo street engine, a 93' B230FT(squirter) with Wiseco Pistons, RSi rods, ect. Also I'll be running a remote oil filter and cooler.
This engine will be built for lower-RPM power and reliability so I'm motivated to improve the oiling system, mainly the stock oil pump since there is no "performance" pump available.
It seems most people get by just fine with an OEM or stock style oil pump as long as the oil transfer tube o-rings are installed correctly and in good shape..
So why would I bother modding a perfectly stock oil pump?
4 things:
-Can't leave well enough alone.
-Fixing things that aren't broke
-OCD
-Reckless Curiosity
This is my first Volvo engine so please offer some constructive criticism if available.
List of items purchased:
IPD
-120580 Oil Pump Redblock OEM $413.06(one sale)
-Oil Pump Shaft Reinforcing Ring, 1pc $8.95
SUMMIT RACING
-ARP-670-1002 M6X1mmX25mmLong $11.81 5pcs
-ARP-671-1002 M8X1.25mmX25mmLong $12.23 5pcs
MCMASTER-CARR
-9220K381 Smooth-Bore Seamless tubing 3ft. $9.93
-4464K563 3/8 NPTF pipe plug 302 Stainless $1.87 1pc
-92235A108 Flanged head SHMS M4X0.7mmX10mmLong $7.30 50pcs
-1185N37 Brown Viton O-rings, 1.5mmW 14mmDia $8.83 25pcs
iMATERIALISE
-Oil Pump intake, 3D Printing, SS/Bronze $108.14 1pc
LINE2LINE COATINGS
-Abradable coating, Oil Pump Internals $93.27
TOTAL W/O Tax and Shipping: $675.39
I'll follow up with more detail in following posts, Thanks!
Improved Pump installed
Blue 79' 242 GL
Engine Rebuild in process!
CaseyHooligan is offline   Reply With Quote
Old 02-27-2017, 08:01 PM   #2
CaseyHooligan
I started out by purchasing a brand new stock Volvo OEM pump from IPD for a small fortune.
Disassembled and inspected.
Not happy with the intake screen, much flimsier that what came out of the car, Volvo cheaping out on replacement parts?
Old 02-27-2017, 08:07 PM   #3
CaseyHooligan
After having a good look at the OEM pump, I decided it could use a bit of port smoothing.
I also lapped the mating surfaces and gear ends.
Lastly I gave the castings a little part line smoothing.
Old 02-27-2017, 08:18 PM   #4
CaseyHooligan
The internal clearances were in-line with stock tolerances but I'd read that some engine builders were playing with a coating process for their oil pumps that effectively allowed them to run "Zero" clearance. It's called an Abradable Coating, think of piston skirt coatings but thicker, and a bit "fuzzy". the fuzzy outer layer is allowed to wear-in during initial operation, leaving only the bare-minimum clearance allowed by the geometry of the rotating parts.
It's apparently used in the turbine engine industry a lot.
Main advantages are higher efficiency due to tighter clearances and longer life.
Well hell, let's give it a go!
Housing, cover and gears all coated.
After coating and reassembly, the pump was tight, but after a few revolutions, it spun freely and I cant get a .001" feeler gauge in between the rotors and housing without screwing up the coating.
Old 02-27-2017, 08:30 PM   #5
Kenunot
That's sick. Really nicely done.
Kenunot is offline   Reply With Quote
Old 02-27-2017, 08:48 PM   #6
Tfrasca
Tfrasca's Avatar
That pickup tube brace/locator is bad ass.
Old 02-27-2017, 08:50 PM   #7
CaseyHooligan
The next challenge was dealing with the interference between the stock oil transfer tube and the ARP mainstuds, the main studs really wanted to occupy the some space.
Also I was nervous about the stories of the o-rings popping out...
I figured the best thing was to make a new oil transfer tube that solved those problems(hopefully).
I kinda' did it the hard way, started out drawing the stock oil tube in CAD.
3D printed the stock tube model in SLS nylon, then carved away the problem area.
After I had some reference models, I increased the tube inner diameter to match the inner oil passage diameters(Block and Pump), and designed new fittings with redundant o-rings to ensure a better seal into the pump and block. Then another SLS print to check fit.
When I was happy with the new tube and fitting design, I then fabricated the tube and fittings from seamless steel tube and round stock, adding an addition support bracket to ensure that the tube stays in place.
TIG brazing was used for the welding process followed up with a little black oxide coating.
You can see the progression here.
Overall, I feel good about the new transfer tube.
-Better flow
-Redundant o-rings
-Support bracket to limit movement
-Clears Main Studs
In the future, it would be nice to have the tube mandrel bent and maybe get better at TIG brazing. But I think it should work as intended.
Old 02-27-2017, 08:57 PM   #8
Tfrasca
Tfrasca's Avatar
Amazing. Any plans to sell transfer tubes?
Old 02-27-2017, 09:02 PM   #9
CaseyHooligan
Last big issue I wanted to deal with was the intake screen and cover thingy.
I mounted the pump and loosely fit the pan, it was clear that the pump pickup was shoved all the way into the front/passenger's side of the sump. Plus the screen cover is just a hole in a flat plate, hardly seems like an optimal situation..
So I designed a new intake screen cover in CAD(Fusion360), I'm hoping it will offer much less flow restriction and less turbulent flow dynamics. Plus I tried to bias the intake flow towards the center of the sump.
Instead of the bent tab/edge that holds the OEM cover on, I went full overkill and used 4 SHMS and a steel retaining plate.
I had iMaterialise 3d print the cover using the SS/Bronze infusion process, came out great!
Since the screen that came with the new OEM pump was a turd, I cleaned and reused the one that came out of the car. I managed to push the screen out of the outer ring with my thumb without even trying... Shudder to think of the screen coming apart while in the car!
Old 02-27-2017, 09:29 PM   #10
CaseyHooligan
Thanks, not really planning on selling these, I can imagine they might be expensive if I did.
My take away from this whole oil pump saga is that someone should really make and sell a high-volume performance oriented pump like Melling's billet race pumps. But for Volvos!
Old 02-27-2017, 10:08 PM   #11
John V, outside agitator
Nice work.. Outrageous price to get a different box for that water pump, but whatever, your money..One question: relief spring..What did you do?
Shirley you didn't just leave the limp OEM one in there?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 02-27-2017, 11:00 PM   #12
photoman327
photoman327's Avatar
Great work and I was going to ask the same thing about selling them.
Old 02-28-2017, 12:49 AM   #13
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
that's cool. I've also seen people tap and thread the pump and block, and use a larger line
Megasquirt Tuning!
Old 02-28-2017, 01:55 AM   #14
CaseyHooligan
I did! I left the limp-wristed stock relief spring in.. I know, I know, I'm not sticking to my "fix **** that ain't broke" mantra.
I'm going for flow efficiency and higher low-rpm flow and pressure and not focusing on some peak rpm pressure number.
Also, I should mention that of the pumps available, it seemed as though the OEM pump offered the better clearances/finishes and quality, but by a small margin and a HUGE $premium. So I dug deep and started with the "best" pump I could get.
Old 02-28-2017, 01:56 AM   #15
CaseyHooligan
Oh really? Like AN fittings with hard line? I hadn't seen that, but sounds like a solid solution.
Old 02-28-2017, 05:46 AM   #16
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
That looks really nice. Good job.
Devil's advocate: You just spent a lot of time and money solving problems that don't exist. The return on investment here is piss poor at best.
Fake Race Car
Old 02-28-2017, 06:13 AM   #17
BillyMaysHere
BillyMaysHere's Avatar
BUT you're saying there is a return!
Old 02-28-2017, 03:06 PM   #18
CaseyHooligan
Well, Fake Race Car isn't exactly a good investment either. But we do this because we love to do it. ROI be damned.
-Clears Main Studs <---- Actually did solve a problem that existed!
Old 02-28-2017, 03:32 PM   #19
Mueller
Mueller's Avatar
Even if it doesn't add a single HP or make the motor last one extra mile, the mods you made are top notch in quality and detail.
Almost could be mistaken for a professional motorsports build.
Old 02-28-2017, 04:33 PM   #20
Tfrasca
Tfrasca's Avatar
Plus, peace of mind that you wont be blowing out o-rings. Overkill? Absolutely. But it's still top notch work.
Old 02-28-2017, 04:55 PM   #21
Jack
junkman
Jack's Avatar
idle hands lead to masturbation so this is way better, right after the morning session
great work BTW
Old 02-28-2017, 05:25 PM   #22
CaseyHooligan
Wow, Thanks for saying so. I love making/modifying stuff for myself, but getting positive feedback is icing on the cake.
Old 02-28-2017, 05:28 PM   #23
CaseyHooligan
Thanks, I don't have an Engineering degree to use in order to optimize designs, so I tend to go beyond what seems rational!
Old 02-28-2017, 08:52 PM   #24
xmlhack
xmlhack's Avatar
I too have looked at that tin lid with the bent tabs and the hole in the center. The melling pump doesn't have that. The pickup is all screen. I can't help to think the tin cover with the hole serves some purpose. I checked mine to the specs and decided to move on. I did buy the stiffer spring and the support ring.
Please post the height of your pump gears from that new pump.
71 Volvo 144S - The original
75 Volvo 242DL - College beater
92 Volvo 940GL - Workhorse
95 Volvo 855 - My first HPT
06 Volvo XC90 - Daughter’s Truck
98 BMW 540i - Commuter
72 Volvo 142E - Current project
xmlhack is offline   Reply With Quote
Old 02-28-2017, 09:10 PM   #25
xmlhack
xmlhack's Avatar
Is there a post on this site that describes how they did that?
