Old 08-04-2019, 07:20 PM   #1
mblue240
mblue240's Avatar
Default m47 shift knob on a t5?
I'm going to run the Summit shifter, but I'd like to stick with the factory shift knob. Anyone have a clever idea how to get them to mate together well?
https://www.summitracing.com/parts/s.../model/mustang
-Michael
Tbricks build
Yep, Michael is right.
Old 08-04-2019, 07:43 PM   #2
sksmith
sksmith's Avatar
Threaded insert to match the threads on the Summit shifter???
Steve
Old 08-04-2019, 07:59 PM   #3
Spend a couple hundred doll hairs at a machine shop to have a threaded insert made.
Old 08-04-2019, 09:43 PM   #4
LC4CARL
Aero challenged
LC4CARL's Avatar
Great idea. Maybe a new project for STS.
Life begins at 10PSI.
Old 08-04-2019, 10:05 PM   #5
2turbotoys
Salaminizer
2turbotoys's Avatar
I have a crappy m46 knob that I didn't get around to throwing out yet if you want one for practice, PM me. Looking at it, without measuring anything, you would need to remove a small amount of plastic, then epoxy or otherwise fasten a threaded insert into it. You may be able to just press the insert in, I don't know the exact dimensions of course.
1978 242, getting prepped for LS
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
2turbotoys is online now   Reply With Quote
Old 08-04-2019, 10:06 PM   #6
sksmith
sksmith's Avatar
I don't remember what is on an M46, was it a pressed on fit?
If so, would could you tap it for one of these?
https://www.homedepot.com/p/E-Z-LOK-...E&gclsrc=aw.ds
Steve
Old 08-04-2019, 10:11 PM   #7
2turbotoys
Salaminizer
2turbotoys's Avatar
It is pressed on splines. The splines are a white plastic with a raised locating "key" or raised slot to center it. Splined area is appox 16mm side to side, the raised key area side to side is 12.5 mm. It just happened to be sitting within reach here haha.
Old 08-05-2019, 06:58 PM   #8
mblue240
mblue240's Avatar
That was one thought I had. It'll probably cost the same as the short shifter did.
I have a few crappy ones too, that sounds like a decent idea.
Steve
This sounds like it will be my first trial.
Old 08-06-2019, 11:30 AM   #9
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
I'd just fill it with epoxy and a threaded insert
Yet Asher here went with...
Old 08-06-2019, 11:33 AM   #10
JohnMc
JohnMc's Avatar
Yep, JB weld is your friend here. Maybe even half-ass it more than using a threaded insert - coat the T5 threaded portion with wax (or something?) and then partially fill the Volvo shifter knob with epoxy, and then (shifter lever out, everything upside down) just sort of push the threaded portion into the puddle of JB weld, let it cure. The wax should allow the threaded lever to unscrew from the knob afterward.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-06-2019, 02:57 PM   #11
Jack
junkman
Jack's Avatar
Old 08-06-2019, 03:18 PM   #12
Old 08-06-2019, 11:14 PM   #13
vwbusman66
Eisen-Stein
vwbusman66's Avatar
I'll post pictures when I'm done molesting my m46 shifter/knob. I'm using the stock mustang base and going to drill/shorten a m46 shift lever to create a standard length shifter for the 140.
1971 142 DD/beater/fake racecar
2011 Jetta Sportwagen 2.5/5 speed
Old 08-06-2019, 11:27 PM   #14
Jack
junkman
Jack's Avatar
please dont
Old 08-06-2019, 11:28 PM   #15
Old 08-07-2019, 01:40 AM   #16
80/20 speed parts club
I can weld the m46 shifter rod to a flange that bolts on to the shifter. You would have to do all of the measuring and angle-ing to get it to work nicely with the rubber boot as that thing loves to pop a normal t5 shifter out of gear.
Old 08-07-2019, 03:09 PM   #17
Stiggy Pop
Stiggy Pop's Avatar
I had an m45 shift knob on my Hurst t5 shift lever for a while, couple years even. I jammed it on and turned it until it was tight. Shift knob is soft, shift lever threads are coarse. Held until I un-threaded it and put a Delrin knob on it (which is much nicer to use)
'79 242
943 pickup
Old 08-09-2019, 12:35 AM   #18
mblue240
mblue240's Avatar
I bought a few of these. They were $2 each at Ace. I'll grind one down and try my hand at shoving it into my spare m46 knob.
Old 08-09-2019, 10:58 AM   #19
Stiggy Pop
Stiggy Pop's Avatar
tap fit with a little epoxy and I bet you'd be all set.
Old 08-18-2019, 03:24 PM   #20
towerymt
the real Towery
towerymt's Avatar
I'm here to spread the gospel of the M45 shift knob. A less sucky near-match to the M46/47 shaped knob. It's hard plastic instead of mushy rubber. I've used one on my M47s for years...it doesn't fly off on a good one-two shift.
Old 08-18-2019, 04:53 PM   #21
Plus when you use the M45 knob. You have a secret gear.
