DET17
Reformed SAABaholic
- Nov 1, 2009
- NW Georgia
OK, subject vehicle is my 940, the DD. I won't belabor the details of the car; you can check the build thread below. Almost all "wear parts" are new, including all sensors. Your typical B230FT squirter, IPD Turbo cam, fresh 530 head, Garrett T3 from Tryingbe, Browntops, cam advanced 4* via Dales, TME cat back exhaust, and TLAO chips in LH2.4 boxes.
Been slowly twisting the MBC, then making simulated 1/4 runs at my local "proving grounds"
Well the car has been rich at WOT and full boost, showing low 10's on the AEM wideband. Mike (and others) suggested raising the boost which should help lean out my engine just a bit more. On the last round I twisted it up to what I thought would be 15 PSI, and took my son along for a test ride. Well at launch it hit 17 PSI for just a second, then stabilized at 15~16 PSI, smooth power until I was winding out 3rd gear. THEN I heard a different noise....and suddenly the turbo whine was VERY audible, where it was always muzzled previously.
Well, riding home the car was showing LEAN, so I suspected I'd blown a hose...limped her home a couple miles. However my son said he heard something at the end of the run that sounded like "a turkey gobble".......WTF I'm thinking? We popped the hood and no hoses were obviously blown or off. The AFR's were leaner but still OK. I decided to make a couple light throttle stabs, and the T3 still boosts with what feels like the same power (butt dyno, I know), but the turbo whine is MUCH more noticeable, and when I lift, the "gobble" is there for a second.
Parked it, and decided to do a leak check across the IC & both hoses attached. Custom made hose plugs from my machinist buddy, and put approx. 15 PSI in the IC, no leakage. I did find a small tear on my cold side IC hose, so I replaced with a spare. Fired up tonight and the AFR's are sitting rock steady on 14.8 when idling, but then don't twitch around like before....I'm afraid when the issue occurred, the AEM saw lean conditions for a couple seconds and something might have happened to my BOSCH sensor. Tonight, putting around the hood, I warmed it up thoroughly & then punched it going up my hill, and again the WHINE is still quite loud, and the "gobble" is still there.
Well, not an IC problem, so I am suspicious that the wastegate diaphragm is blown, which is allowing the turbo sound to project from it, and then "fluttering" as some describe it, on decel. when back into vacuum.
Certainly somebody out there has BTDT. I can't believe I've got a gasket flapping somewhere on the intake, but I've yet to pressurize the intake from TB to the head, hoping to find the issue on the exhaust side.
Will pull a vacuum check on my old school T3 WG tomorrow; this WG was clearly not replaced when Tryingbe rebuilt the T3. Is the blown WG the most likely suspect?
