akhan
- Apr 18, 2017
- Prescott, AZ, US
I'm trying to see what exactly is going on with my 1989 Volvo 240. When warmed up, it runs amazingly well. I'm getting ridiculously high MPG on both highway and city: 27.3 with 75+ MPH and 29.4 in the city (35-50 MPH).
The problem is at cold start. I've recently swapped the MAF to a brand new Delphi unit, as well as a Bosch O2 sensor. No codes are thrown by the computer, but on cold start (65? F mornings), the car surges for about 20-30 seconds (as if it's re-learning the settings). After that, everything evens out and it runs great. While it's surging, there is black smoke coming out of the tailpipe, which eventually turns clear after the 20-30 seconds.
I have swapped pretty much everything in this car, including spark plugs, MAF, O2, new Volvo coolant and an 87? thermostat, in addition to the coolant temp sensor and ECT. With the 87? stat, it runs a little over the 10 o'clock temp position normally (faker board removed and contacts 1-3 shorted).
Not a big deal, but I'm wondering why the car seems to be in "re-learn" mode on every cold start. When I swap the old MAF in, I get codes, but a steady start every time. Is this because the new Delphi MAF uses a different technology (looks way different inside)?
