- May 27, 2008
- Rockland County, NY
Installed the harness, Power stage & coil pack today. Removed the distributor, coil & standard terminal wire set.
Didn't start, so I checked the continuity for all the power connections. Every looked good. I had removed the ground for the stock power stage (which I forgot included the ECU ground), so I reattached that, and it tried to fire. Didn't sound right at all, so I reversed wires for 1-4 with 2-3, and it fired right up. I had wired IB1 to output 1 & IB2 to output 2 on the daughter card, OC1 to coil pin 3, and OC2 to coil pin 1
- based on this diagram
So, it seems the coil connections are inaccurate - I definitely have OC1 going to coil pin 3 & OC2 going to coil pin 1.
Coil pack & isolater board location
Power stage & heat sink location
Wires in place, distributor removed
