shaved240
- Jun 6, 2003
- California
you get those intercooler brackets and other goodies?
I went over the radiator with the maf wiring on my 240 years ago.
It runs and drives! And it makes a nice turbo sound. I can't say it is fast yet. I'm running basic wAstegate pressure for now. But it is MUCH better that the NA power. It doesn't feel dangerous when crossing traffic now.
The engine dies sometimes when I close the throttle. And worse if I close it quickly from boost. I'm not sure what is causing that. But I'll fack around with tps and MAF orientation to see if That helps.
.Won't help. You need to make absolutely sure that the idle switch on the throttle body is set perfectly.
You guys are so cute with your little itty bitty turbos and all the noises its makes.
