mhhhkay drove some KMs on the weekend after we had our last notebookdrive on last tuesday..
ECU tune to drive is done.. it has 0,7bar of boost which is far too much for the ignition angle from the factory 219 goldiebox.. you can hear the motor running knocky past 4500rpm..
But.. amazing so far... the turbo is producing a quite infernal sound
and the bov is twittering like a boss...
I had one moment of total adrenalin when some parts fell off the engine and got meshedup in the wheelhouse.. it sounded like the motor was gone
So.. my copperbolt got a lil bit dry on its tip in that moment..
Instant stop... check for motor.. runs.. OK?! Dafuq was that?! My buddy went to the place where it happened and i looked for the new V70 Calipers but nothing.. it turned out that it was just a fawking enginemount for hanging it with a crane... somehow i disassembled it and forgot it anywhere near thar steering...
Oh.. Steering btw.. the power part of it... doesnt work..
Otherwise the ignitions still runs stock 219 it runs a bit boggy here and there also it stalls when lift off the throttle from above 2500 rpm.. played around with the throttle itself.. when i adjust it to proper "falling in idle from anywhere" i had no cutoff cause the poti was bypassed then. I now have it adjusted to something like a compromise... Also as saif the ECU tune is a preliminary one...
Turbo kicks at around 3100rpm in your back... so i think its choosen wisely
But the dealers said its a 0,3bar actuator... so.. why this MoFo goes up to 0.7.. seems to be a lil small and i have to grind it bigg0r.. also the wasteflapper cant open rly good cause it hits the wall really soon.. i grinded some meat for it to open more but still not enough... chinaturbs.. argh...
100kms to go then i have to retighten the headbolts from KL-Racing.. Maybe i'll also get some new hydros...
And i dont know if its something about the 960TB but i have a superstrange whistling while accellerating... sounds like swirls in the intake.. will do a vid of that...
V70 brake does its job like a champ btw
Ja.. aber sowas von die Geile Drecksschwarte
