Mbeas96
- Aug 7, 2017
- Charleston
90 740, just finished heater core and now I'm tasked with getting the blower to turn on. It stopped worked over the last couple months of no use, before quitting it had a rubbing/whining noise that I assume meant it was on the way out.
Fuse 16 (I think, one fuse that was marked heater fan) keeps blowing (30amp) within seconds of trying to turn the motor on. Went thru 2 additional ones after I pulled the original blown one.
Am I right in thinking the motor is probably just seized aND a replacement will fix my problem? Or is it possible the resistor or other wiring could be fubar causing it to pop?
