Here is an idea that has crossed my mind that I thought I'd bounce around on here.
Has anyone experimented on the dyno with intake cam timing under boost?
I had been looking at ways of running a stock whiteblock motor in the short term under boost without having to reduce its compression ratio. If the intake cam timing is retarded (valve closes and opens later), there will be less valve overlap. The valve will also close later on the compression stroke and therefore reduce the effective compression ratio, but the turbo or supercharger will still be able to achieve the same pre-ignition cylinder pressures.
The expansion ratio will remain the same, so in effect the turbo or supercharger can be allowed to do more of the work in compressing the intake charge in the cylinder.
The reduced valve overlap that could use high exhaust gas velocity to help get the intake charge moving in its port initially on a naturally aspirated engine is not so necessary on a turbo/ supercharged engine anyway.
This of course is really only practical on a twin cam motor like the whiteblock or 16V redblock .... just curious if anyone has tried playing with their inlet timing.
Any thoughts?
Any thoughts?
