Old 11-03-2011, 12:29 AM   #26
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Originally Posted by malloy1 View Post
Probably best to post this over here too on the J702T ignitor:
How are you powering your coils? What kind of gauge wire should work?
Paul
Oh howdy!
I used some 10 gauge stuff with a cube relay. Some 12g from the ignitor to coils works good too. in also this case, you are eligible to use an MSD DIS2 box.
Old 11-03-2011, 07:13 AM   #27
boosted12a
weapon of mass detonation
boosted12a's Avatar
Originally Posted by DNAsEqUeNcE View Post
I used a mitsubishi (mazda 1.6l miata) J702T ignitor, and the tacho output pin off of that wired directly to the volvo tach.
i see. im guessing that a wire that goes to the stock ignighter is the tach?
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 11-03-2011, 08:17 AM   #28
Bando
By bando123 at 2011-11-03
Forgive me, but I prefer visual diagrams. Would this be a simplified wiring diagram, essentially a transplanted Mazda Miata wasted spark system.
Would I need moates to change the ezk tables to make this system work.
Bando is offline   Reply With Quote
Old 11-03-2011, 09:21 AM   #29
DNAsEqUeNcE
†John3:16
Nice one.
and negative boss, it'll plug right in and work. you can change the EZK spark tables for more power or more economy if you want, but its not required.
Old 11-03-2011, 09:55 AM   #30
SteveMD
Not A Typical Dating Site
SteveMD's Avatar
Nice one.
Cool. I picked up the Jwhatsit ignitor on my last JY visit. Now just need to find a coil next time and I'll be in business once the Buchka Super Happy, etc, etc gets here.
Old 11-03-2011, 12:02 PM   #31
DNAsEqUeNcE
†John3:16
pick your coils, I have been wanting to experiment with all different sorts. I have only experience with the subaru and miata coils, both of which worked well and handled boost no problem.
I have yet to try pairing up the ls1 coils and toyota cop coils.
Old 11-06-2011, 06:41 PM   #32
boosted12a
boosted12a's Avatar
i have a set of jegs GM 2 post coils. we will know how well they work in a few. just a couple more wires and it should run
Old 11-07-2011, 02:02 AM   #33
ZVOLVO240
ZVOLVO240's Avatar
Here is the pinout on the 0 221 503 407 unit:
and the 0 227 100 203 unit is pinned out as (the unit is used to run 3 sets of wasted spark cylinders):
Pin 1-#1 negative coil
Pin 2-#1 Input
Pin 3-#2 negative coil
Pin 4-ground
Pin 5-#2 Input
Pin 6-#3 negative coil
Pin 7-#3 Input
This should be the setup using these two parts:
Out From EZK: -> Into 203:____ Out From 203: -> Into 407:
1-4 output -------> Pin 2 _________ Pin 1 -------> Pin 3
2-3 output -------> Pin 7 _________ Pin 6 -------> Pin 1
Pretty picture:
Photobucket
I'm assuming pin 3 & 5 of the 203 unit won't be used to run any cylinders. Also, "Switched 12+", I mean 12+ when cranking too.
Karl looked it over, and thinks it looks right, but if somebody sees something wrong with it, please point it out.
Paul
I'm just curious if this is the definitive correct wiring for running the setup or is this for Launch control? All the credit to Karl for the instructions, but I'm a visual guy too.
Also, if I chose to wire it this way(sans launch control), do I follow directions for the dummy coil, or for the alternate MS tach signal.
Pardon the dumb question, but where is the best switchable 12v connection for this install?
Sorry, I'm just not very electronic savvy.
- Will Z
1989 244 DL - - - Beige N/A
1988 245 DL - - - Original owners/Dad's Car
1991 244 Turbo - DEAD
ZVOLVO240 is offline   Reply With Quote
Old 11-07-2011, 02:09 AM   #34
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
There's obviously no definitive wiring diagram since it's setup dependent. The above diagram is correct for a 203 module and the Bosch wasted spark coil.
I would say the tach wiring depends on how reversible you want the system to be. Leaving the stock ignition module and wiring in place lets you quickly and easily revert to a distributor, but obviously at the cost of having to leave all the old stuff in the bay.
I would probably just tie in to the existing 12v feed for the stock ignition module. It's already there and you know the wiring will be able to handle the current draw.
Fake Race Car
Old 11-07-2011, 09:31 AM   #35
boosted12a
boosted12a's Avatar
mine. works, and works great! thanks Karl. more torque and much better top end!
i used a 6 Cyl j somthingn or other ignighter from a mitsubishi and it works just fine. i ran the tach out put to the stock tach wire on the powerstage plug(red/white) and i also had to wire in the dummy relay to get the tach to work. i used the + (blue)from the power stage plug for the ignighter and the + (blue)for the original coil to power the 2 GM style dual post coils. i added extra wires to the EZK plug at spots 14 and 15. prety simple. for your wires in the box to the board i used O2 sensor wire, solders good and its good wire.
Old 11-07-2011, 02:23 PM   #36
ZVOLVO240
ZVOLVO240's Avatar
I really hate sounding dumb, but what do you connect those 6 header pins (the ones that got bent in some packaging) to? I get all of the other connections and mostly how to run the dummy coil setup.
Also, I don't mean to sound cheap but the coil pack is expensive new! Any source of a used form of it? I mean I can wait and save for it, but this is just out of curiosity.
Thanks in advance
Old 11-07-2011, 03:02 PM   #37
boosted12a
boosted12a's Avatar
Thanks in advance
Header pins are for programing. the coil packs are all over the junk yards. ford, gm, mazda, mitsubishi......hit up krazy rays and go a scouting.
Old 11-07-2011, 03:54 PM   #38
ZVOLVO240
ZVOLVO240's Avatar
Any specific part numbers? Im bad with lots of varying options hahah
Old 11-07-2011, 06:38 PM   #39
DNAsEqUeNcE
†John3:16
the miata 1.6l coils from NA body miatas work perfectly, and should be cheap. they also plug into stock ignition wires. I'd use the ignitor off that too. it has a 4cyl tach output on it that plugs into the factory volvo tach and works.
Old 11-07-2011, 09:51 PM   #40
boosted12a
boosted12a's Avatar
posted pics in my car thread, see the last post
http://forums.turbobricks.com/showth...32#post3952632
Old 11-08-2011, 09:25 AM   #41
Beachee
Beachee's Avatar
Looks good. :-) Works well?
Beachee is offline   Reply With Quote
Old 11-08-2011, 12:33 PM   #42
boosted12a
boosted12a's Avatar
thanks, it works great
Old 11-08-2011, 03:27 PM   #43
malloy1
malloy1's Avatar
Would it be best to unplug the 124 module?
I would assume that the EZK box is still sending out a signal to 124 module (that's why you can use it for a tach signal). Right? So if the wasted spark board fails, and if the 124 module was plugged back in, the dizzy/coil reinstalled, it would run as stock (if the EZK isn't damaged)?
Paul
Paul
malloy1 is offline   Reply With Quote
Old 11-08-2011, 03:54 PM   #44
Karl Buchka
This is correct. The stock function of the system is completely unaffected.
Old 11-09-2011, 01:46 AM   #45
Texas240
Prius Owner
Texas240's Avatar
was the general assumption on the 960 cops? Im assuming that these could be used with 960 ignitor module ?
93 245 LS Engine Swap Project
Old 11-10-2011, 05:59 PM   #46
Mariust
Mariust's Avatar
Installed and works perfectly
Volvo 940 `98 3"lmm, 968`s, hx35, ostrich, Buchka Spark, 3" xhaust
Volvo 242 Turbo `77. 16v Project
Volvo B20 Dragster
The world fastest B20
http://forum.savarturbo.se/viewtopic.php?t=15737
Mariust is offline   Reply With Quote
Old 11-10-2011, 10:07 PM   #47
DNAsEqUeNcE
†John3:16
any externally ignited COPS will work fine, just wire them in series.
I have tried the 4/5/6 cyl cops/ws thing, they are too short for the 16v head.
as for using the yota cops, they might work still with an external ignitor wired in parallel, unsure on that. there's no way to wire the trigger signal from the EZK to the cops without keeping the output voltage from dropping (unless perhaps you use a 12v transistor on the buchka board, if possible, that would then send 2 6v signals to the yota cops to fire).
I forget if nathaninwa is using COPS, he just might. he then might also be using the external ignitor with them.
Old 11-10-2011, 10:13 PM   #48
Texas240
Prius Owner
Texas240's Avatar
I have my toyota ones which fit nicely but there was talk about the volvo ones a year ago and Im not sure it ever got settled or not.
Old 11-10-2011, 10:42 PM   #49
DNAsEqUeNcE
†John3:16
Old 11-11-2011, 06:55 PM   #50
AndrewEG
AndrewEG's Avatar
Hey karl awesome to see an engineering student applying their knowledge to things that actually interest them!
I have a LS2 "yukon" coil dwell table here for reference. I've also included the coolant temp modifier table.
Multiply the coolant temp modifier values to the base dwell times to get your final dwell values
If you need LS1 coil information from the pcm .bin file let me know.
AndrewEG is offline   Reply With Quote
