Old 11-11-2011, 07:50 PM   #51
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Andy, thanks for both the kind words and the dwell tables. The table values seem to be close enough to the EZK to work. If anything, the EZK dwell might even be a tad on the high side.
Fake Race Car
Old 11-12-2011, 07:12 PM   #52
Texas240
Prius Owner
Texas240's Avatar
for the people that are not quite sure what Lawrence was talking about when it comes to modifying a generic 30amp relay for the tach out here it is.
the copper arm that is sticking out is the piece that you remove.
93 245 LS Engine Swap Project
Old 02-03-2012, 10:47 AM   #53
SLO240
Awesome Sauce
What gauge wire is recomended for the wiring inside the EZK box? and for the output signal as well?
1985 244 B230F Sister Killed It (RIP)
1982 242 B21FT Kid Hit It (RIP)
1993 245 B230F <--You can do it!
Buyer/seller feedback. http://forums.turbobricks.com/showth...67#post4602067
SLO240 is offline   Reply With Quote
Old 02-04-2012, 09:09 AM   #54
Karl Buchka
It's all low current TTL stuff. 20 AWG is more than enough.
Old 03-05-2012, 04:51 AM   #55
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Is there a Masterplan setup for the 16v ?
Which coils do fit ? Maybe anyone who can fab some screw on adapters for the plugs? What igniter do i need ?
Problem is, most of the cars you mentioned arent available in germany not to mention finding them on a junkyard ^^ so no "lookylooky what i found here" for me :(
Old 03-05-2012, 08:10 AM   #56
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Hai there! I ran the 16v with this thing.. and I used 1st generation miata coils and igniter. (no tach dummy relay needed!)
Pretty sure stock plug wires are no problem with it (length wise and coil mounting wise).
there's some other options, will post those later.
Old 03-05-2012, 11:29 AM   #57
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
do you have part no's for me?
the miata for example was never sold here... but known to us aka MX5 and is selled pretty often... but do the numbers match? i dont know...
Old 03-05-2012, 12:00 PM   #58
Karl Buchka
Miata = MX5. Same car.
Old 03-05-2012, 12:30 PM   #59
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ah cool, good to know
Old 03-06-2012, 08:24 PM   #60
DNAsEqUeNcE
†John3:16
Ignition module, j70t2 mitsubishi
coils, off same car?,unsure of PN. 1st generation NA mx-5, 91+ to like 98?
Old 03-07-2012, 05:24 AM   #61
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Ah...
is there a possibility to use coils similar to the ones the b6304f uses?
just for the looks ;)
btw:
i cant find any j70t2 module in the web... not on google nor on ebay usa... hard to find part?
Old 03-07-2012, 07:58 AM   #62
DNAsEqUeNcE
†John3:16
I derpd. J702T.
As for using COP coils, that's a whole nother' ballgame.
Old 03-07-2012, 04:24 PM   #63
Beachee
Beachee's Avatar
Originally Posted by MadDog_945 View Post
Ah...
btw:
Hello
The coils from the b6304 is too short...
Beachee is offline   Reply With Quote
Old 03-07-2012, 06:11 PM   #64
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Originally Posted by Beachee View Post
Hello
yeah, but if you look on the coils for the miata gen2 they are directly CoP, they should fit... but.. can you "adress" them like the miata gen1 module ?
sry.. i dont have a clue about the electronics behind ignition modules... therefore the question ;)
Old 03-07-2012, 06:23 PM   #65
JW240
All idiot, no savant
JW240's Avatar
the Bosch 2x2 coil is pretty easy to find (in Germany/NL etc) and works good with the stock dwell times that are mapped in the ezk. not as neat as COP on a 16V but maybe a good alternative for the time being or for longer time. Also nice Bosch quality and works with stock 740/940 cables!
240 | 1991 | 330 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 supermoto swapped
Old 03-08-2012, 04:16 AM   #66
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. there must be a masterplan for CoPs out there...
Can anyone measure the 16v head from surface to the Plug pins screwed on and unscrewed? Oh and the diameter of the hole.. maybe we can find "the coil" ;)
How would you address single CoPs? will there be there a difference in wiring ?
Old 03-09-2012, 08:14 AM   #67
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Maybe found something...
https://www.germanautosupply.com/sto...70_-_6_pcs.jpg
It's 24€ each
Old 03-12-2012, 01:21 PM   #68
Karl Buchka
I just put this "tach driver" together for a local guy with a spark board. It's just a standard relay with the flapper and spring tossed out and a transistor/resistor stuck inside.
Old 03-12-2012, 09:36 PM   #69
boosted12a
weapon of mass detonation
boosted12a's Avatar
why the resister?
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 03-12-2012, 09:59 PM   #70
Karl Buchka
To limit the current that flows to the base.
Old 03-12-2012, 11:25 PM   #71
DNAsEqUeNcE
†John3:16
That's pretty cool! I don't think I've seen anyone yet who's wired up COP's yet with the Board. There's a fellow here that tried them with the LS1 coils and they didn't spark. Probably because not enough dwell or something. I know Kenny had success with triggering Toyota coils off MS LED outputs, and they should be very similar if not identical to how the Buchka stuff is wired up, I don't know for certain though.
The LED's off megasquirt have a 5v trigger signal that's voltage is pulled up from a 5v source, and I measured the buchka board to be the same thing, so, I suppose you might be able to draw some kind of conclusion from that if the data matches up
Old 03-13-2012, 01:41 AM   #72
crandandall
Turbobricks Low Life
crandandall's Avatar
You should be able to use two wire COP's (no built in igniter). You'll just have to wire them to spark two at a time, cylinder 1&4 and cylinder 2&3.
crandandall is offline   Reply With Quote
Old 03-13-2012, 05:16 AM   #73
ipdown
Член на форума
ipdown's Avatar
I run VAG COPs, but I have modified dwell map in the EZK for them.
More than 10k kms on them. With stock dwell they won't work as they overheat in a mater of minutes and start to missfire.
Not using "genuine" buchka module though, but the principle is the same, so it should work perfectly with what you use.
In the EZK I use dual 512 bin - can select between vag and stock dwell, and can switch to/from dizzy in a couple of minutes.
Attached is the holder plate drawing I laser cut from 1.5 mm stainless steel for VAG COPs - someone asked for dimensions of the 16v head cover.
Diameter of the spark plug hole is 32 mm and the holes are not equally spaced..
ipdown is offline   Reply With Quote
Old 03-13-2012, 06:32 AM   #74
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Whoa ipdown.. thats awesome what coils exactly you run? The ones from 1,4TFSI?
Old 03-13-2012, 06:37 AM   #75
ipdown
Член на форума
ipdown's Avatar
Not sure, coils are 06F905115F. Now see that they are for 2.0 (T)FSI: http://uniautopart.com/product.asp?id=3432
