Old 03-13-2012, 09:17 AM   #76
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
whoa.. these ****ers are quite cheap
http://www.ebay.de/itm/VW-Eos-Golf-5...item53e9e29236
Did you buy come connectors ? these plugs seem pretty uncommon...
Old 03-13-2012, 09:30 AM   #77
ipdown
Член на форума
ipdown's Avatar
I used ready made harness: http://shop.vems.hu/catalog/active-loom-p-149.html
ipdown is offline   Reply With Quote
Old 04-01-2012, 03:27 PM   #78
The Beaner
The Beaner's Avatar
Does anyone know the pin outs for the 124 power stage.
This is what i have :
1-Red and White
2-Black
3-Black (shield)
4-Blue
5-Grey
1984 242 Turbo, M46, Red LH2.4
1983 242 Turbo
1992 745TI Green M46
PAST:
1992 745TI Red M46
1992 745TI Red Auto
1981 242 N/A, M46, Carlsbad Yellow
1992 244 Grey Auto
1993 945TI Flat Black M46
1993 945TI Black Auto
1989 745TI White M46
1991 244 Gold Auto
1993 245 Black M47
1992 245 Blue M47
1983 245 Green M46
The Beaner is offline   Reply With Quote
Old 04-01-2012, 03:59 PM   #79
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
http://apps.bosch.com.au/motorsport/...ionmodules.pdf
Fake Race Car
Old 04-01-2012, 05:35 PM   #80
The Beaner
The Beaner's Avatar
Originally Posted by Karl Buchka View Post
Thank you again
Old 04-17-2012, 11:40 AM   #81
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
anyone installed the current board and made pics ?
BTW: im gonna install this to a 219 goldbox.. seems to be the same... but.. is it ?
Old 04-17-2012, 04:57 PM   #82
Karl Buchka
I don't have any in-progress pics, but here's Leslie's EZK all buttoned up and ready to go:
The base EZK board is the same across all the different part numbers, so you shouldn't have any issues.
Old 04-18-2012, 08:08 AM   #83
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ouuhh !! thats a good one where did you get that throughplug?
anyone with insidepics?
Old 04-18-2012, 10:51 AM   #84
barkster1971
Default stuff
http://www.volvoforums.org.uk/showth...ight=gotenberg
barkster1971 is offline   Reply With Quote
Old 04-24-2012, 05:57 PM   #85
Milos
can anyone tell me if there are other powerstages i can use besides 0 227 100 203? i cant find that specific one anywhere.
i have found many with 7 pins with other partnumber but i'm not sure if they work too?
Milos is offline   Reply With Quote
Old 04-27-2012, 10:46 PM   #86
boosted12a
weapon of mass detonation
boosted12a's Avatar
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 04-29-2012, 02:54 PM   #87
DennisvdB
DennisvdB's Avatar
Originally Posted by boosted12a View Post
Got that one too, with the tach output. Mine's from a Mitsubishi 3000GT.
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 04-30-2012, 06:05 PM   #88
boosted12a
boosted12a's Avatar
on a side not. the GM dual post coils may not be the best choice. i had one up and die on me
Old 05-02-2012, 11:30 AM   #89
Milos
i finally found a coil and powerstage.
coil = bosch 0221503457
powerstage = bosch 0227100200
Old 05-02-2012, 05:59 PM   #90
crandandall
Turbobricks Low Life
crandandall's Avatar
Anyone used a Ford EDIS coil yet?
crandandall is offline   Reply With Quote
Old 05-02-2012, 06:01 PM   #91
Karl Buchka
A local guy is using one. Last I heard it was running well.
Old 05-03-2012, 10:12 AM   #92
Milos
i know many people have used ford edis coil for their projects but i also heared some people talking about problems with the edis coil because of some filter inside so they had to use something else. i will try to find out what they mean.
Old 05-03-2012, 12:34 PM   #93
crandandall
Some of the coils have an integrated noise filter/capacitor, the one I have uses an external filter so it can easily be removed if needed.
Old 05-03-2012, 07:27 PM   #94
crandandall
Any way to tell if my ezk is EGR or not? I have a gold box that I'm going to use, P/N 0 227 400 214.
Old 05-03-2012, 08:21 PM   #95
Karl Buchka
It's pretty easy to check.
If you look at these pics that sbabbs posted: http://forums.turbobricks.com/showpo...4&postcount=68
The top right corner of the first pic, right next to the upper mounting tab of the heat-sink, you can see two black D-shaped components. Those are part of the EGR circuitry.
A non-EGR box will have those spots unpopulated, like in these pics: http://forums.turbobricks.com/showpo...0&postcount=47
Old 05-03-2012, 10:15 PM   #96
crandandall
Awesome, thanks for the info. Just wanted to be sure before i installed my board using the egr pins.
Old 05-08-2012, 12:19 AM   #97
crandandall
Here's some pics of how I did mine. Unfortunately, my box has EGR so I couldn't piggy back the pins like I was hoping. I used a Molex panel mount connector and some ribbon wire from an old alarm system I had laying around. The hole for the connector to mount in is kinda crappy and looks too big, but the tabs on the connector are huge, so it had to be that size.
Old 05-08-2012, 06:04 PM   #98
boosted12a
boosted12a's Avatar
fancy. never seen a silver box before.
Old 05-09-2012, 02:44 AM   #99
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
its goldish... think its the flash which makes it looks so fancy.. but the really fancy part here is... its a 214... i've never heard of a 214er EZK which is gold before... only the 219 aka "goldbox"
Old 06-01-2012, 02:29 PM   #100
TonyS9
Question
I've sourced all the standard parts (Bosch 2x2 + 3 channel driver) but the coil pack has unusual HT connections. I got a set of punto leads with the 2nd hand coil I got on ebay (£1.04+postage ) It seems to have 4mm pins in the coil pack, distributors connections are female normally. Standard distributor end may work, but I suspect they may not be reliable.
I had a good search and not been able to find the necessary terminal to make up my own leads. I can use the ones from the Punto with new cables, but it may weaken the terminals.
Anyone found a source, or are standard leads a reliable bodge?
I would add a photo on the Punto lead connectors, but I'm not allowed.
TonyS9 is offline   Reply With Quote
