Old 06-19-2012, 10:03 PM   #101
dalek
Benchracer Tribe
dalek's Avatar
Originally Posted by crandandall View Post
Some of the coils have an integrated noise filter/capacitor, the one I have uses an external filter so it can easily be removed if needed.
How do you identify them by staring at them?
Feedback!
Old 10-18-2012, 08:08 PM   #102
auditechjs
Clever words here
auditechjs's Avatar
I have unlimited supply of Audi A4 2.0T ign. coils with built in ignitors if anyone needs them for MS or 16v setups. i don't know if anyone needs them, but i have like, ****s loads of them. lol
-1990 780 Bertone-M46 N'stuff
-1994 945 Turbo. Stock.
-2012 Triumph Tiger 800 w/ABS.
Originally Posted by mr brick driver View Post
Do you realize this is a rare car. From what i can see you ruined the eblems, the door lock cylenders, and casued about an additional 1000 in work for someone who wants to actally paint this car. I don't get it. It needed the upper surfaces painted and you completed f-ed the whole car.
auditechjs is offline   Reply With Quote
Old 04-09-2013, 04:49 PM   #103
kodja
kodja's Avatar
hi, anybody have the partnr on the mazda ignitionmodule that will give out the tachometer signal and also work with the bosch 2x2 coil with the buckha card?
98' 945 LT RF stereo, aprx. 2600watt RMS Dynamic bodykit, 18" rims, Black leather 965 interior, bilstein + ipd swaybars +++
82' 242 (Turboproject) C70 two-coloured leather and alcantara seats (electical adjusted), Harman/Kardon amps++
kodja is offline   Reply With Quote
Old 04-09-2013, 05:42 PM   #104
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Hmmm let me go see. BEfore I go look, it's for a 1990-1997 mazda miatatatata
Old 04-09-2013, 07:06 PM   #105
Texas240
Prius Owner
Texas240's Avatar
I guess I could go walk 20 feet to my car, pop the hood and look at mine
93 245 LS Engine Swap Project
Old 04-10-2013, 05:06 AM   #106
kodja
kodja's Avatar
lol.... would be very nice. need to order the few parts i need for this thing :-)
Old 04-15-2013, 07:39 AM   #107
kodja
kodja's Avatar
nobody?
Old 04-15-2013, 07:54 AM   #108
DNAsEqUeNcE
†John3:16
Hey look! there's one in my pocket.
It's a J702T mitsubishi. surprised I didn't remember that.
Old 04-15-2013, 07:55 AM   #109
boosted12a
weapon of mass detonation
boosted12a's Avatar
i used a mitsubishi 6 cyl ingniter and just didnt use one of the i/o channels. worked great
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 04-15-2013, 08:22 AM   #110
kodja
kodja's Avatar
http://www.ebay.com/itm/90-91-97-Maz...item3f012aac80
so This is the exact ignition module to use if i am correct then?
Old 04-15-2013, 08:30 AM   #111
kodja
kodja's Avatar
if anybody else thinks this is usefull:
the J702T ignition module for Mazda MX5 \ Miata
Mazda Partnr: B61P18251
cost aprox: 4800 NOK (Norwegian Kr) in dollar aprox depending on the currency: 800$
Old 04-15-2013, 10:12 PM   #112
DNAsEqUeNcE
†John3:16
that's it fella!
Old 04-17-2013, 04:46 AM   #113
Beachee
Beachee's Avatar
What do you connect the IGF to?
Beachee is offline   Reply With Quote
Old 04-19-2013, 08:16 AM   #114
Beachee
Beachee's Avatar
Got it:
OC1 Output coil bank 1 (to 1-4 side of your coils)
IB1 Ignition bank 1 (from buchka spark 1-4
VB Voltage Battery 12+ switched
TAC Tacho output straight to your 240 tach if miata unit, IF dsm unit, wire in a 12+ pullup wire with 1k ohm resistor tied into tach line)
IGR 12+ passthrough (unused)
GND Self explanitory
IB2 Ignition input 2 (to 2-3 side of your coils)
OC2 Output coil 2 (from buchka spark 1-4)
Old 04-20-2013, 09:21 AM   #115
DNAsEqUeNcE
†John3:16
I have to edit that post that everyone keeps quoting, because OC2 and IB2 are switched
Old 04-20-2013, 02:27 PM   #116
DennisvdB
DennisvdB's Avatar
You are right, when we wired everything in my car we initially did it wrong because we took your schedule. Turned out good anyways
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 05-03-2013, 07:27 AM   #117
leon740
Just installed the but no spark what readable signal should i get from the wasted spark board? 5v?
leon740 is offline   Reply With Quote
Old 05-03-2013, 07:37 AM   #118
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
How have you wired it? What components are you using?
Fake Race Car
Old 05-03-2013, 08:02 AM   #119
leon740
replaced the stock power stage with the J702T and a using a 'diamond' subaru coil.
Old 05-03-2013, 08:11 AM   #120
Karl Buchka
Have you double checked the wiring inside the EZK? Are you getting a steady 5V across the power and ground pads on the spark board?
Old 05-03-2013, 08:26 AM   #121
leon740
Yeah, I've got 5v across power & ground. Also getting a signal from the launch control
Old 05-03-2013, 09:48 AM   #122
Karl Buchka
What do you mean by this?
Every board i send out is fully tested and I haven't had a single one be DOA. Is your coil and power stage confirmed working? Is that wiring properly done? There seems to be some confusion above regarding the J702T pinout.
Old 05-03-2013, 05:39 PM   #123
leon740
I have 5v from one of the launch control connections. My wiring is correct, is it a 5v signal to the power stage when cranking the engine?
Don't know why I didn't think of it before, I swapped my aw71 with a w55 manual tranny at the same time as installing the wasted spark. Think I might have missed something there. I'll be back at the car tomorrow and will have another look.
Old 05-17-2013, 04:26 AM   #124
leon740
Finally got around to having a good look, always learning! Sorry about my noobness
Is the wasted spark basically a "switch to ground"? Is there a way of confirming if it is operating correctly or if it's receiving the correct info from the EZK with out an oscilloscope?
Engine's cranking, fuel and suppression relays are fine and switching, fuel pump primes, replaced the J702T power stage with another one that was confirmed working, also tried a Subaru power stage, Coil is in working condition and I've checked the wiring at least 20 times and still no spark
I read somewhere that, with accessories on, the crank angle sensor is meant to have ground, 5v & 12v across the 3 wires. I have ground, 3.5v & 0v, could this be because I damaged the EZK when installing the wasted spark board or maybe a faulty CAS? Any way of testing without an oscilloscope?
Old 05-17-2013, 05:08 AM   #125
Karl Buchka
The wasted spark board simply takes the stock coil trigger signal and diverts every other pulse to two outputs. It is grounded when nothing is happening. When it goes high, it triggers the power stage to start charging the coil. When it then goes low, the power stage turns off and the coil makes a spark.
"ground, 5v & 12v" across the crank angle sensor doesn't sound right. It should output a sinusoidal signal of increasing amplitude with increasing RPM.
You mentioned that you did a manual swap. Does that car have a neutral safety switch that you have to bypass?
