Old 05-17-2013, 08:52 AM   #126
leon740
Hey Karl, I've bypassed the neutral safety switch. I have ran a wire from the TAC of the power stage to the relay coil that has replaced the ignition coil, and the other side of the relay I have the stock blue switched 12v and ran a cabel from there to the new coil. Is that correct?
leon740 is offline   Reply With Quote
Old 05-17-2013, 09:34 AM   #127
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
I don't follow your description. Can you draw it out?
Fake Race Car
Old 05-18-2013, 04:28 AM   #128
leon740
Sorry mate, that description was after a few beers This should be a bit clearer!
[IMG][/IMG]
Old 06-10-2013, 02:58 PM   #129
Fivehundred
Fivehundred's Avatar
Originally Posted by Karl Buchka View Post
I just put this "tach driver" together for a local guy with a spark board. It's just a standard relay with the flapper and spring tossed out and a transistor/resistor stuck inside.
Can you elaborate on this for the electronically challenged like me?
Does it work like this?
Fivehundred is offline   Reply With Quote
Old 06-10-2013, 04:05 PM   #130
Karl Buchka
That's exactly how I did it. It's the same circuit that's listed on msextra.com.
Old 06-10-2013, 06:50 PM   #131
Fivehundred
Thanks Karl, transistors are very mysterious things to me......
Old 06-11-2013, 07:34 PM   #132
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Hey Tried PM'ing, keeps giving an error code every time.
I was wondering if my board got lost in the mail, i never got to lay my hands on it here @ napa.
B
Old 06-11-2013, 10:15 PM   #133
Karl Buchka
That's strange. Your board definitely got shipped with the others. If you can hang on until next week, I can ship you a replacement from the new batch.
Old 06-12-2013, 08:22 AM   #134
wingnutty
wingnutty's Avatar
No problem at all, just fire away when they show up.
20475 highway 46 #340
spring branch tx 78070
wingnutty is offline   Reply With Quote
Old 07-07-2013, 02:38 PM   #135
Beachee
Beachee's Avatar
Originally Posted by DNAsEqUeNcE View Post
the miata 1.6l coils from NA body miatas work perfectly, and should be cheap. they also plug into stock ignition wires. I'd use the ignitor off that too. it has a 4cyl tach output on it that plugs into the factory volvo tach and works.
Haveing some problems. Please help me out here. Will the J702t ignitor work with a bosch .....407 coil?
Beachee is offline   Reply With Quote
Old 07-07-2013, 04:29 PM   #136
DNAsEqUeNcE
†John3:16
Most likely. Shouldn't matter what ignition module you use as long as it ground fires the coils
What's the problem exactly?
Old 07-07-2013, 04:59 PM   #137
Beachee
Beachee's Avatar
I've asked Karl aboit the same. Can we bu sure that the J702t ignitor will fire the bosch 0221 503 407? The problem is that it dont fire...I have signal from Karl's board to the ignitor. I've made a conector so I can change between the J702t ignitior and the bosch 203. I have 4 bosch ....407 coils.( 3 used and 1 new.) Then I thought it might the signal that came from the Buchka board. So I took my spare LH2.4 gold box and soldered in another board that I had from Karl. But I did look at the wrong picture... and soldered the spark output to a pin on the main contector. (see the green wire here:http://sphotos.xx.fbcdn.net/hphotos-...60470111_n.jpg)
What it did to my system was something bad.... It was impossebile to get the engine fired after..... So I discontcted the battety, again.... and took out my backup fuel box(962). Then it started.... I probably fried something in it. Now i dont have any working backup. I also tried with the bosch....203 ignitor ( have 2 used ones )....But now fire there either...
I have pictures, and I'll try to post them tomorrow.... I was abit feed up when all went bad....
I did follow the installation point to point... so I dont know where I did wrong or what didn't work...
Old 07-07-2013, 06:33 PM   #138
Fivehundred
Where is your ground connection?
EDIT Spotted it now......
Old 07-10-2013, 04:12 PM   #139
kodja
kodja's Avatar
anybody that can supply me with the connectors for the mazda miata ignition module and the bosch 2x2 coil? nobody in norway sell it anymore, and i have bought the parts... but cant get anything happening before i get my hands on some connectors...
98' 945 LT RF stereo, aprx. 2600watt RMS Dynamic bodykit, 18" rims, Black leather 965 interior, bilstein + ipd swaybars +++
82' 242 (Turboproject) C70 two-coloured leather and alcantara seats (electical adjusted), Harman/Kardon amps++
kodja is offline   Reply With Quote
Old 07-10-2013, 04:18 PM   #140
Fivehundred
I salvaged the plastic part of the Bosch connector from a scrap loom. The metal spade connector inserts are readily available.
Old 07-10-2013, 04:22 PM   #141
kodja
kodja's Avatar
hmm that could be an option. but there are not many cars at the scrapyards over here to pick them from :/
Old 07-10-2013, 05:47 PM   #142
Fivehundred
I can get you a 3 pin connector and some new terminals for the Bosch coil (I could also get the 7 pin one for a Bosch power stage) but I don't have access to MX5 bits.
Old 07-10-2013, 06:39 PM   #143
kodja
kodja's Avatar
would have been nice
Old 08-25-2013, 02:18 PM   #144
Jon P.
Jon P.'s Avatar
Potato.
Originally Posted by 1BEATK5 View Post
My wife always asks if I was using my penis eyes when looking for stuff.
She looks with her vagina eyes and finds it in about 3 seconds.
Jon P. is offline   Reply With Quote
Old 09-29-2013, 11:11 AM   #145
kodja
kodja's Avatar
still looking for the bosch 2x2 motorsport coil connector and the mazda miata ignitionmodule connector.
ANYBODY? just got the spirit over me again to start finishing the engine and get it in the car... ASAP... but need the connectors before i can do that...
Old 10-09-2013, 06:48 AM   #146
kodja
kodja's Avatar
Hi, just found the connector and wires for the Bosch 2x2 motorsport coil.
partnr for the connector: 977929
partnr for the wires: 30656689 (need 3!)
can be found in your local volvodealer. or ordered there not expencive either!
Old 10-09-2013, 10:07 AM   #147
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Thanks i was also still kept back by wiring :-)
Old 10-09-2013, 10:17 AM   #148
kodja
kodja's Avatar
my pleasure
looks like this:
https://www.facebook.com/photo.php?f...type=1&theater
Old 10-09-2013, 08:50 PM   #149
kodja
kodja's Avatar
Tried to figure out the places to weld the wires on the board, as my board don't have the markings on it.
can anybody confirm that i have got everything correct here? if so. wohoo... and if correct and anybody else thinks this is helpfull, please say so and if anybody need the diagram in full size 1900x1438 pixels please pm\email it and i will gladly share it.
the wire thickness and colour matching the Miata/ MX5 ignition module writen down also on the picture along with some other usefull stuff for my own use also.
thought this could be a good way to visualize it better for my self in the first place. if it is all correct that is?
BTW: should the Bosch 2x2 coil be grounded in some way??? and constant 12V or 12V switched?
Old 10-09-2013, 10:20 PM   #150
Karl Buchka
The Bosch coil gets switched 12V. The other two pins handle the return current through the primary windings, so no need for extra ground wires.
