Old 10-10-2013, 02:30 PM   #151
kodja
kodja's Avatar
Originally Posted by Karl Buchka View Post
The Bosch coil gets switched 12V. The other two pins handle the return current through the primary windings, so no need for extra ground wires.
ok. thanks.
So i just bolt on the Bosch Coil to a metal bracket to the chassi, no problems?!
hooked up the bosch coil and J702 unit tonight.
2wires for input from Buchka WS Board, 2wires for output to Coil, 2 wires for 12V Switched power and Ground and 1wire connector for the Tachometer. installing it all behind the firewall is the plan. completely removing the wires forward to the original coil and ignitionmodule. Will try this on my FK engine before installing the 16V Turbo so i know it works as it should :D excited!!!
98' 945 LT RF stereo, aprx. 2600watt RMS Dynamic bodykit, 18" rims, Black leather 965 interior, bilstein + ipd swaybars +++
82' 242 (Turboproject) C70 two-coloured leather and alcantara seats (electical adjusted), Harman/Kardon amps++
kodja is offline   Reply With Quote
Old 10-23-2013, 10:41 AM   #152
kodja
kodja's Avatar
https://www.facebook.com/media/set/?...1&notif_t=like
just put togeather a complete HOW TO hook it up guide in pictures at this link now will put togeather a video later on to see. it works amazing! i think even that my engine is pushing more power now thanks to the wasted spark system... just ripped the grip on 3rd gear with my tuned FK+M90 in my 242 on the freeway from 70-140KM/H continously spinning all the way up. Amazing stuff :D
if any inputs, please give it
Old 10-24-2013, 06:59 AM   #153
kodja
kodja's Avatar
http://www.youtube.com/watch?v=GLYbx...ature=youtu.be
How To install video hope everyone understands my english ;)
Old 10-24-2013, 08:05 AM   #154
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
What the hell is that AMM doing in a boost hose?!
Old 10-24-2013, 08:10 AM   #155
kodja
kodja's Avatar
What are You takling about? Everything is right where it is supposed to be ;)
Edit: to best answer You, please refer to what time in The video
Old 10-29-2013, 09:24 AM   #156
Janspeed
hi Boris
in theory it should not matter, airmass = airmass, regardless if it is measured at atmospheric pressure or at boostpressure. I am not really sure if it works that way in practice.
the benefit: shorter distance between airmass measuring point and ignition/injection points.
This should make for faster response to changing throttle inputs.
the downside: the AMM might gets contaminated by oilmist coming from the turbo and crankcase ventilation. (clean more often?) This contamination could throw of airmass measurements which could cause bad AFR's
Old 10-29-2013, 09:28 AM   #157
Mr.Borrie
Mr.Borrie's Avatar
Interesting to know considering i thought i needed to cut the LH2.4 loom off a 240 N/A to get my AMM in place.
Old 10-29-2013, 09:32 AM   #158
kodja
kodja's Avatar
well... my AMM is running quite well this way, and it is a common way to do it here in Norway, althoug i guess it is a 50/50 split on how many run it like this or lengthen the AMM wires to the Turboside.
no problem at my car like this. and i am using a separate oilcatchtank so that will take up some of the unwanted oilmist before reentering the turbo intakehose.
Old 10-31-2013, 08:30 PM   #159
Tyler_Krupa
Tyler_Krupa's Avatar
My AMM is also there in my 940. computer seems to respond a little faster and i was able to put a non recirculating BOV between the intercooler and the AMM without having any problems.
Edit: When and if these ever go on sale again I will be picking one up.
1994 944 Turbo
TLAO Chips, Buchka Spark, browntops, 19t@18psi, ported 90+, Big eBay intercooler, Synapses BOV set to recirculate, GFB G-Force II, RSI STG1 cam (1st gen), Nuke cam gear, Ipd sways, Ipd lower chassis brace, UR Strut Brace, kaplhenke coilovers, kaplhenke adjustable strut mounts, koni sports, 302mm v70 front rotors
I will use all the liquid explosive dinosaurs
Tyler_Krupa is offline   Reply With Quote
Old 11-07-2013, 05:09 PM   #160
kiroileva_fossiili
I got my engine running with the mod, but it doesn't run well. I have checked wirings, changed sparks plugs and cables, tested that there's spark in every cylinder. Seems like bad timing or something..?
http://www.youtube.com/watch?v=MYMM-U_5ugY
What should I try next?
I use Bosch 2x2 -407 and Miata/MX-5 J702T
242 Turbo project
kiroileva_fossiili is offline   Reply With Quote
Old 11-08-2013, 11:42 AM   #161
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
bad ground?
Old 11-08-2013, 12:06 PM   #162
redbaronmulisha
Do the AMM's not heat to 1000 degress for 3 seconds after the car is shut down to burn off oil deposits or contaminated air??? I remember reading in the green volvo manual and haynes manuals that they do.
1997 945 turbo - 20psi of LOL
2002 nissan cube -
redbaronmulisha is offline   Reply With Quote
Old 11-08-2013, 08:21 PM   #163
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
kiroileva_fossiili has a bad board. He's getting a replacement.
This is not at AMM thread. Please keep it on topic.
Fake Race Car
Old 11-14-2013, 12:19 AM   #164
GeorgeDrifts
GeorgeDrifts's Avatar
does anyone know what pin #'s the ignition signal and rpm signal is in the ezk for a 1989 volvo 740 turbo? im trying to wire up a rev limiter. thanks guys
1989 volvo 744: squirter block, ported head, ported 15g, mbc, hks boost gauge, (2nd) m46, spec stage 2 clutch, g80/welded diff, ipd upper and lower chassis braces, ipd sway bars, ipd springs cut, solid motor & trans mounts, ipd strut rod bushing, Azev type A 17x9.5, aero front bumper/side skirts.
2001 volvo s80 t6: cone air filter, magnaflow muffler -my dd.
GeorgeDrifts is offline   Reply With Quote
Old 12-01-2013, 05:23 PM   #165
Jon P.
Jon P.'s Avatar
I'm having the exact same issue. I've hooked it up before but kind of ghetto, and had the same issue. Then I took the time and did my wiring with nice copper wires and waterproof electrical components just like kodja shows in his tutorial. Exact same issue. Although I have not checked for spark, the video posted above is 100% exactly what is happening to me.
Any suggestions on what to check?
Originally Posted by 1BEATK5 View Post
My wife always asks if I was using my penis eyes when looking for stuff.
She looks with her vagina eyes and finds it in about 3 seconds.
Jon P. is offline   Reply With Quote
Old 12-01-2013, 05:43 PM   #166
Karl Buchka
What color is your board?
Old 12-01-2013, 05:45 PM   #167
Jon P.
Jon P.'s Avatar
Green.
Old 12-01-2013, 09:06 PM   #168
Karl Buchka
Then your board was fully vetted before it went out. The problem should not be with the board.
Old 12-03-2013, 08:33 AM   #169
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Maybe it happened during Transport? It is very difficult to screw up soldering 4 pins.. 3 guys with same symptoms...? ...
Old 12-03-2013, 08:48 AM   #170
Karl Buchka
What three guys?
Old 12-03-2013, 10:04 PM   #171
DNAsEqUeNcE
†John3:16
I had a problem where my car would barely idle and wouldn't rev out at all. turns out it was a bad solder joint on the ground wire to the BuchkaBoard.
Old 12-04-2013, 02:26 AM   #172
Jon P.
Jon P.'s Avatar
Thank you sir. I'll probably check this out again this Sunday. I haven't rev'd the car long enough to actually get it start, but it turns over just like the video above posted.
Old 03-28-2014, 10:29 AM   #173
jay f.
jay f.'s Avatar
Hi, just found the connector and wires for the Bosch 2x2 motorsport coil.
partnr for the connector: 977929
partnr for the wires: 30656689 (need 3!)
can be found in your local volvodealer. or ordered there not expencive either!
Figured I'd add to this. Not sure how much the dealer charged,
http://www.summitracing.com/parts/bch-1237000039
It's also known as a 3 pin AMP JPT connector.
Also the bosch 2x2 can be found on some Land Rovers, 2003-2004 I believe. So the coil and connector could be found together at the junk yard.
jay f. is offline   Reply With Quote
Old 03-28-2014, 11:31 AM   #174
ryank
ryank's Avatar
This drawing is very helpful, but just to confirm, BOTH the 12v to the ICM and the coil should be switched, correct?
If so, are the existing 12v to the stock ICM and coil suitable (switched)? Thank you! (Hoping to get my board soon!)
'94 945T | '70 Alfa GTV 1750 | Ducati M800S | feedback
ryank is offline   Reply With Quote
Old 04-04-2014, 02:38 PM   #175
ryank
ryank's Avatar
Launch control clarification question... Will the engine RPM be limited to whatever it is when SET is momentarily grounded? If so, does grounding ARM, or ungrounding ARM release that hold?
