Old 09-25-2014, 10:09 PM   #201
Mylesofsmyles
Originally Posted by Homer View Post
You shouldn't need to use shielded on the logic level signals.
A wise idea though?
Volvo wired the logic level output to Powerstage with a shielded wire
Old 09-26-2014, 09:53 AM   #202
calvintibia001
Bench-Race Fanatic
calvintibia001's Avatar
Does DSM Coil with J702T work ?
Originally Posted by Disco Inferno View Post
mooooooooooooooooooBRBRRRAAAAAAAPAPAPAAPAAPAAAAPAPAPVTAK
calvintibia001 is offline   Reply With Quote
Old 09-26-2014, 05:31 PM   #203
Mylesofsmyles
Meh, I already laid in a shielded wire for it, so...I don't think it can hurt anything
Old 09-27-2014, 12:46 AM   #204
turbomatic2010
turbomatic2010's Avatar
yup
Originally Posted by MrDoug View Post
Thats interesting, because the Miata ignitor even has the same Mitsubishi logo & part number as the DSM one- I would think the Hyundai coils wold be the weaker ones, since all 4 coils share a common pole piece, the DSM coils can be seperated
turbomatic2010 is offline   Reply With Quote
Old 09-27-2014, 12:56 AM   #205
calvintibia001
Bench-Race Fanatic
Originally Posted by turbomatic2010 View Post
yup
Anyone know which wire does what on a 3 Wire DSM Coil ?
Old 09-28-2014, 03:03 PM   #206
Mylesofsmyles
Pretty easy peasy...
Use your continuity beepy tester...
One of the three is your switched 12v...which'll get split to both coils...the other is your (-) trigger from your igniter...one for each coil
Old 10-26-2014, 12:26 PM   #207
Mylesofsmyles
With my Buchka Board installed...I'm not getting enough voltage to Igniter.
Wasted Spark Leads off the board show 0.08-0.1v while cranking...that's not lighting off the igniter.
Any advice?
Old 10-26-2014, 12:28 PM   #208
Mylesofsmyles
Looks like I put my VR Conditioner Signal in the wrong place...that'll do it.
Old 10-27-2014, 12:11 PM   #209
turbotankshane
got it all installed and running then?
Old 10-27-2014, 03:41 PM   #210
Mylesofsmyles
Installed. Not yet running. Gonna play with it some more, this evening
Old 10-27-2014, 09:16 PM   #211
Mylesofsmyles
Checking in...
Car runs like a bat outta hell!
I'm getting NO TACH signal from my J702t igniter...bummer, as it's the whole reason I chose it.
Wonder if it's bad or if it's with my car/tach.
Old 10-28-2014, 10:47 AM   #212
turbotankshane
Glad the car's running for you, seems like a good product. Now if I could only figure something out about where mine is at...
Old 10-28-2014, 03:35 PM   #213
Mylesofsmyles
Great product...terrible availability.
That's how Volvo aftermarket performance goes!
Old 10-28-2014, 07:01 PM   #214
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
We get it man.
Originally Posted by rvolvor
Old 10-28-2014, 10:44 PM   #215
thevolvokid
142 whore
thevolvokid's Avatar
I got a 1997 eagle talon's ignition amplifier and the coil pack set up. These should work eith the wasted spark board right?
90 745 Turbo, tuned by myself made 365 whp completing a 1/4 mile pass at 12.93 @ 105.xx. Not bad for a stock block w/ 265,xxx miles that runs lh 2.4 and ekz
thevolvokid is offline   Reply With Quote
Old 10-28-2014, 11:15 PM   #216
Mylesofsmyles
Seems like a pretty open slate to choose your igniter/coil pack.
Eagle Talon...that's DSM stuff? probably good stuff
Old 10-28-2014, 11:18 PM   #217
Mylesofsmyles
Any reported issues with NO TACH Signal from a J702T...I have no tach yet!
Old 10-28-2014, 11:20 PM   #218
thevolvokid
142 whore
That's the miata amp right everyone seems to be using it just fine. Brett used it just fine I think?
Old 10-29-2014, 12:48 AM   #219
Mylesofsmyles
Yep, Miata amp...I used it for this feature...
I'm going to have to do some testing, this weekend to see where the problem is...
Could be bad cluster wiring, as well....
Old 10-29-2014, 11:49 PM   #220
cosbySweater
cosbySweater's Avatar
I used the miata amp in my car and it worked just fine on the stock tac. If I remember correctly there is a pullup wire you may have to splice in as well to get your particular tach working properly. I'm gonna go look at my notes from when I ran mine
Old 10-30-2014, 10:14 AM   #221
Mylesofsmyles
Please do...it's a freshly restored R-sport cluster, so it's doubtful I have a issue with the tach.
Tested for continuity from wire at gauge to igniter...that's fine.
Old 10-30-2014, 10:39 AM   #222
Lord_Athlon
Sf1k Kryptonite
You might have to fire a dummy coil. The tach might be counting the voltage spike from the coil.
Old 11-01-2014, 05:30 PM   #223
Mylesofsmyles
What a surprise...the TACH output on the Miata J702T igniter is (+)...it pulses like a tach should, but it's (+) not (-)
Rewire tach to get constant (-) and let the (+) pulse trigger it?
Has anyone successfully driven a Volvo Tach with this?
Old 11-02-2014, 05:37 PM   #224
Mylesofsmyles
K...I was wrong.
I have a proper (-) tach signal...but it's only 2v....
My 245 with stock ignition has 10v for a tach signal....seems the issue is signal strength.
Is this how all J702T tach outputs are, or is mine broken?
I suppose I could drive a ignition amplifier but that seem excessive.
Someone must have crossed this bridge before me.
Old 11-02-2014, 08:18 PM   #225
Mylesofsmyles
I attempted a 10k resistor, pull-up wire...didn't get the tach firing.
