Old 02-22-2014, 04:18 PM   #1
didenpx
didenpx's Avatar
Default 1977 240 Instrument Cluster Wiring
I have pulled my R-sport cluster to get some stuff sorted out and am trying to swap in a 1979 instrument cluster so that the car can be driven in the meantime.
I have the circular and half moon plugs connected but am getting no idiot lights when the ignition is switched on and also no readout on gas or temperature. High beam indicator and directionals work.
I looked at Haynes and the pinout of the 77 and 79 circular and half moon plugs seems to be the same. Looking for some hints or troubleshooting advice.
My feedback: http://forums.turbobricks.com/showth...hlight=didenpx
1970 1800E (Project Roedluvan:http://forums.turbobricks.com/showth...highlight=1970)
1977 242DL "Senf" (Summer Cruiser)
2x1973 1800 ES (Project Reanimator; coming 2019/2020)
didenpx is offline   Reply With Quote
Old 02-22-2014, 04:56 PM   #2
DennisvdB
DennisvdB's Avatar
Gas or temperature problems? Swap out the voltage stabilizer for a working one or make a new one like this:
http://www.164club.org/spanreg.html
Had that problem too with swapping the original to a R-Sport, this solution fixed it.
Edit: Idiot lights problem as well btw, new exciter wire from D+ on alternator to firewall plug (which goes to red wire -> cluster) solved the problem.
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 02-22-2014, 06:10 PM   #3
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
http://www.ebay.com/itm/291083368163...84.m1555.l2649
How PSI a stock can support?
Always Be Crushing!
Old 02-22-2014, 06:55 PM   #4
didenpx
didenpx's Avatar
Thanks Dennis and KJOP.
Is there an easy way to test the regulator that I have to confirm that it is the problem?
Old 02-22-2014, 07:06 PM   #5
didenpx
didenpx's Avatar
On second thought.....I pulled it out and pried the circuit board out of the shell and this is what I found:
[IMG][/IMG]
There's a good electronics supply place near me and I've got a decent soldering station so I may go the DIY route.
Old 02-23-2014, 11:27 AM   #6
DennisvdB
DennisvdB's Avatar
Go DIY. Gives much more accurate readings than with the regular voltage stabilizer.
Old 02-23-2014, 05:56 PM   #7
didenpx
didenpx's Avatar
The IC should be on it's way (it was cheaper to buy it online than to pay for the gas to get it). Definitely going the DIY route.
Once I have it put together I'll report results.
