Old 12-02-2019, 02:19 PM   #1
Avtovaz
Default 530 valve seats for porting
just looking at my 530 head today, its got the biggest valves in the standard seats, is taht 44/38? cant remember but, the seats havnt had any material removed from them at all, it looks to me like that is restricting the head flow, can you take material from here?
thanks
Avtovaz is offline   Reply With Quote
Old 12-02-2019, 02:33 PM   #2
The inside diameter of the seats needs to be opened up. I open them up to 86-88% of the valve diameter. Open the intake seat to approximately 38-38.5mm, and the exhaust to approximately 32.7-33.5
The port area under the seat will also need to be enlarged as well.
Old 12-02-2019, 02:38 PM   #3
Avtovaz
thankyou that is exactly what i needed to know!
Old 12-02-2019, 05:31 PM   #4
Avtovaz
one moer question i have a 530 that has been worked and then i also have a stock 531, i can see the 531 on the inlet side has a much better flow. Its the same height port size but the width on one side is much better.
ive only seen pics of the 530 with just enlarged port. is that a real restriction? what can be done in this area to open it up?
thanks
Old 12-02-2019, 07:09 PM   #5
The real restriction on both heads is the exhaust side. It is undersized, and the short turn radius (sharp corner) needs to be smoothed over.
Old 12-03-2019, 09:48 AM   #6
90volvo
Back when I was drag racing and had a friend that ported heads. He showed me how most people wrench the short side radius. They would try and shorted it which would cause turbulence when mix would hit the valve. I wonder if that rule still applies to these heads?
Old 12-03-2019, 12:40 PM   #7
The Volvo 8v exhaust port is designed very similarly to a 90deg brass fitting. It’s basically two holes drilled 90deg from each other, with a sharp inside corner. Widening the port floor (not lowering it) and creating a short side radius is where most of the gains are. There’s just not that much material to remove on these heads in other places.
On some decent heads, removing too much, or the wrong shape, on the short side can be a detriment. The Volvo 8v needs the entire exhaust port moved up 10-15mm just to match a poor flowing iron v8 Head.
Old 12-03-2019, 02:11 PM   #8
Avtovaz
so can it be ported to look more like a 531, or is that not a good idea as its not the heron head?
how wide can you go before hitting anything or making the flow worse?
thanks!!
Old 12-03-2019, 02:40 PM   #9
thanks!!
Are you talking about porting the intake, exhaust, or both to look like a 531 head?
When I get a flow bench, I'll let you know
I just follow what Erland Cox talks about with the 8v heads. It's not radical, it works well, and it's simple.
Old 12-03-2019, 03:48 PM   #10
Avtovaz
isnt the exhaust the same anyway?
where can i find this info from Erland Cox?!
Old 12-03-2019, 04:09 PM   #11
The exhaust it very similar between the 530 and 531. I don't think there is enough material in the port walls to carve a 530 into a 531 style head. But, a ported 530 and a ported 531 have very similar flow capacities.
Erland's site seems to be down, but it can still be accessed through the wayback machine: https://web.archive.org/web/20180829...foretaget.html
Old 12-06-2019, 07:22 AM   #12
Swedbrick
Swedbrick's Avatar
For some extra inspiration, I just uploaded the folder I collected when doing my own porting and valve deshrouding for inspiration, maybe some of it helps I mostly rounded the harsh angles mentioned, and blended the valveseats to the ports, to get rid of the edges.
Volvo 530/531 porting inspiration/own work
I'd also recommend having a look at this video by JafroMobile, a very good tutorial with useful tips, the whole channel is worth a look to learn stuff for engine building
And for part 2
Good luck!
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Old 12-07-2019, 01:36 AM   #13
90volvo
can the valve guide boss be completely eliminated or do you need to keep it for the guide support? Does the head respond to good 3 angle valve job. Would be disheartening to port a head and make it worse or unreliable.
Old 12-07-2019, 08:05 AM   #14
K9 240
K9 240's Avatar
I'm in the process of doing some work on a 1990 530 head before taking it to a m/s to have 38/46 valves installed.
I've been looking for info like this for when I take the head in. However I did the math & got 88% of 46mm rounded up to 40.5mm
Also I've just measured the head (to get an idea of how much needs to come off) & the diameter of the inlet seat, just under where the valve sits is about 40.5mm. It tapers in to about 38mm at the base of the seat. Last measurement could be a little off but there is a definate taper. The actual port where the seat sits is a little larger than the seat (felt with finger).
In opening up the seats would you increase the diameter by 2mm to match the increase in valve size? Is the taper important? I would think reaming/boring it to resize it would leave it parallel.
Tim
Old 12-07-2019, 04:24 PM   #15
A three angle valve job is stock so you need to do this at least to stock. My shop brought the area under the seats to match the same size as the seat where it meets that area. The taper is very important so you don't creat turbulence. Even with stock valve sizes my shop was able to get about a 20% increase in flow.
Here is a thread where there is big discussion on what to do. Even the famous/infamous? Pacman added to the thread. Sorry my picitures are long gone. https://forums.turbobricks.com/showt...ghlight=405%2A
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 12-09-2019, 05:28 PM   #16
The exhaust guide can easily be shortened and ground to match the port, it is very well supported. The intake guide can be shortened up too, but it is not supported as well. I don't think this creates a longevity issue. I have done this on my daily driver 240 and an old race head without any issues. The stock guides are already significantly longer than most heads.
The stock valve seat does not have a 30deg top cut in the stock heads I have worked on, it is really a 1 or 2-angle valve seat from the factory.
The stock valves and seat geometry make it difficult to get a true 3-angle valve seat, as the valves sit protruding slightly into the chamber. This can be done, but it "sinks" the valve into the head a bit, and the valves must be shortened or thin valve shims used.
Tim
Tim, the measurements I posted above were using the valve diameters listed by the Avtovaz, so that's where the discrepancy is
The 85-88% measurement is for the ID of the valve seat insert, and I match this to the aluminum ports in the head. From there, I will taper out at ~70-80deg to the 60deg that I have cut into the seat.
When I do larger valve heads, I bore the seat ID to 85-88% of the valve OD, and then go from there. This is the sweet spot for most engines. I might go bigger on the exhaust, and smaller on the intake, as the exhaust is the true restriction on these heads.
See above for what I've seen for stock valve angles. Even on heads that have been rebuilt, I've seen them done with a single angle seat!
I'm not surprised that the shop was able to increase flow 20%, these heads are pretty bad from the factory
Old 12-10-2019, 03:55 PM   #17
I've been running that 405 now for about ten years. One of the most pleasant upgrades as it made the engine run better at all rpm ranges. No loss of low end torque and will rev out further than the valve springs can handle with it still wanting to make power. I use about 6800rpm or so as the limit. The springs are stock large spring shimmed a bit tighter.
I trust my shop so I know he did what he told me. That's interesting what you have found to actually be on the heads that you worked on.
Old 12-10-2019, 04:00 PM   #18
Avtovaz
i have btw, gone for a 531 head i got now, standard valves, solid lifters etc. kl racing 12.9 300 deg cam too. not going to port it at all as ill get a 530 later on and try my best with it.
Old 12-10-2019, 04:46 PM   #19
The 405 head on the old rally car was one of the reasons it rev'd to 8k so well. They're great heads with a little work.
Old 12-10-2019, 04:50 PM   #20
Avtovaz
culberro, what sort of spec was your rally car? what sort of power too?
my b230a is in a bmw compact rally car
Old 12-10-2019, 05:27 PM   #21
Not my car, I'm just the co-driver and the one who does most of the work on the car.
No idea on power. It was k-jet, a k-cam, .085" machined from the head, and a lot of revs.
The head is really similar to the one that KLR142 made 180whp with their NA 2.3L 8v. But since running stock k-jet (that wasn't running great), it was probably 130hp on a good day.
The car is very simple. It was basically a VOC spec car for the first 2 years (~10 rallies). Then is had a high comp 16v for a few years (not simple, but very reliable until it wasn't), now it has a "simple" turbo 8v.
Old 12-30-2019, 09:17 PM   #22
klr142
Turbo, what?
klr142's Avatar
Woah woah woah, it was only 157whp with the most generous of Dynojet correction factors(STD). 180whp would be awesome! But yes, we have a ported 405 head with stock valves, the ENEM K13 cam(too small for a racecar but ok for a reasonable idle and running LH2.4, says everyone in Europe), 3mm shaved from the head but the combustion chambers unshrouded a bit more than necessary and around or just under 11:1 static compression running pump gas with 29° of timing at peak power. A lot more info can be found in our thread and on our Facebook page in my signature.
http://forums.turbobricks.com/showpo...4&postcount=85
