Old 05-21-2018, 06:57 PM   #776
klr142
Turbo, what?
klr142's Avatar
I've only made it through just over a tank of gas since I did the work and never got around to doing the back to back tests.
Initial thoughts are that I was not blown away by the result of my SINGLE groove experiment. Performance is basically unchanged(expected only an improvement around idle and maybe under 2000rpm), but there does seem to be improved detonation resistance. So at least it has that going for it.
Initially the idle was worse with reduced idle vacuum. It was acting as if I put in a larger camshaft. I'm pretty sure the valves are at about the same clearance as they were before, but during the downtime the buckets did get mixed up and I did have to reshim a couple. One intake might be a little tighter than before, but I doubt it's enough to make a difference. After the car learned through the tank of gas, it improved and the idle is now higher than before, MOST of the time. Sometimes it doesn't idle higher and it has low vacuum, other times it's comparable to before but the idle rpm is higher(indicating it's more efficient?). I didn't adjust the base idle setting on the throttle after doing the work. Low rpm performance doesn't feel much different, and may have even felt worse at first. I may or may not be able to lug the engine around more at really low rpm and low throttle openings with less interior rattling, but it hasn't been the larger difference I was hoping for.
As far as the detonation threshold goes, I used to have a lot of detonation when running the stock fuel tune and the advanced ignition timing. Even when it was cold out(<40° F) I had problems running that "tune" combination. I have continued driving the car in ambient temps over 65° F without issues. Maybe even as high as 75°. So, I would definitely call that an improvement!
My thoughts on the grooving experiment as a hole(for this round), are that doing ONE groove is not enough.
ONE groove may work ok with additional chamber modifications, such as reducing the squench pad near the spark plug and unshrouding the exhaust valve. Both of which reduce the need for grooves.
In a stock combustion chamber, I think TWO or THREE grooves is required for optimal results.
Njål's head is pictured above in post #758 and he had the desired results. Coupled with a K camshaft, he had a massively flat torque curve with good performance and no detonation until PAST MBT while running over 12:1 static compression in a B230. SEE HERE
I'm not sure what I'm going to do at this point. I may pull the head to add some more grooves, or I may just run it as is. Or I may pull the head, add some more grooves and take another mm off the head to bump the compression up some more with new valve stem seals as at least one is leaking some.
Old 04-15-2019, 12:47 PM   #777
klr142
Turbo, what?
klr142's Avatar
Took NLMGG out for a beating at the track(car in signature's link). Not fully prepared but ran the thing anyway(almost half a tank of gas, sub in trunk). 12 runs in an hour and a half...
Current setup: the very mild ported General Leif 530, single grooved, head shaved 0.032", 0.036" headgasket, M47, 3.73 rear end, custom LH/EZK chips, H cam, opened airbox, full exhaust including header(unnecessary and not helping at this power level) and 17" Tethys with 225/45 DWS 06 tires at full pressure.
WEST COAST BEST COAST NON-TURBO TIME(car 224C):
2.209 60’:
10.492 1/8 at 64.46mph
16.532 1/4 at 81.92mph
Lower times later this year if I get enough time to play with it!
Old 04-15-2019, 01:06 PM   #778
80/20 speed parts club
Sounds like your car needs a fresh bottom end
Old 04-15-2019, 01:28 PM   #779
klr142
Turbo, what?
klr142's Avatar
Yes, it could definitely benefit from one(shiny cylinder bores), but I'm not sure how that post about me drag racing makes it stand out? Hah
Old 04-15-2019, 02:02 PM   #780
Considering it was over a second faster some 5 years ago...
Old 04-15-2019, 02:10 PM   #781
klr142
Turbo, what?
klr142's Avatar
That was with the car stripped, no interior or seats, 15" wheels, the big valve head with real port work, etc..
Old 04-15-2019, 03:37 PM   #782
77volvo245
77volvo245's Avatar
Sounds like your car needs a turbo
FIXED
STSmachining
Old 04-15-2019, 04:35 PM   #783
klr142
Turbo, what?
klr142's Avatar
Bwahahaha
Old 04-16-2019, 01:13 AM   #784
Quin
ಠ_ಠ
kyle, have you ever thought about doing an n/a 16v build?
Old 04-16-2019, 01:41 AM   #785
klr142
Turbo, what?
klr142's Avatar
Yes, I have. No thank you. 8V makes more torque and sounds soooo much better. I wasn’t impressed when we had one in the General Leif.
Old 04-16-2019, 02:17 AM   #786
Stock cams, unported head, stock shortened intake, no extra compression?
Old 04-16-2019, 02:24 AM   #787
klr142
Turbo, what?
klr142's Avatar
Correct.
Old 04-16-2019, 02:27 AM   #788
RvolvoR
have you ever thought about installing a turbo? itll make torque and horsepower and still sound like a tractor.
Old 04-16-2019, 03:59 AM   #789
Quin
ಠ_ಠ
kyle, may i suggest that you install a turbocharger?
Old 04-16-2019, 10:53 AM   #790
klr142
Turbo, what?
klr142's Avatar
I did think about it once.
Old 04-16-2019, 04:14 PM   #791
mblue240
mblue240's Avatar
I was all with you on building an NA motor. But watching you get small amounts of performance for a decent amount of work had me start buying turbo parts. Few more pieces and I'll be ready to +t. You move faster on cars, so if you started buying parts now I bet you'd be done before me.
-Michael
Tbricks build
Yep, Michael is right.
Old 04-21-2019, 02:18 AM   #792
klr142
Turbo, what?
klr142's Avatar
I haven’t really done much performance wise to my car in the hopes of more power for a long long time. I actually had bought some turbo parts many years ago and my oil pan has a plug in it for an oil drain, but that ship sailed long ago and I have no interest in turboing the car anymore.
I think realistically it’s pretty simple to get these up to stock turbo levels of hp(K or H cam if not something larger and aftermarket coupled with a shaved head and some engine management tuning - no intake/exhaust mods needed aside from a 2.25” exhaust), but it’s more complicated to get much more than that. I’ll find out one day when I put my big valve head back on with another mm shaved off of it for a total of 2mm off. I’ll be opening up the combustion chamber slightly to unshroud the valves similar to what I did in the General Leif recently, but I’m not sold on adding a groove or two to it yet.
Then the question is when will I ever get around to putting a better intake manifold on the thing...
However, hp apparently has been made on even the junky B230 intake before... I assume with drawbacks at lower rpm due to the aggressive camshafts, though.
https://youtu.be/IJUfQ1a5-JM
https://youtu.be/vgpnXDQLefU
Old 04-24-2019, 11:51 AM   #793
klr142
Turbo, what?
klr142's Avatar
New, more modern injectors for the car: Bosch 0280155868(or 0280155811 or 62203 or 24508208 or 24503406 or 2171389) from a Suoercharged Buick 3800 motor. Proper 15 degree cone spray pattern coming from an EV6 injector with the four hole nozzle. 12ohm impedance for drop in use with LH2.4 without an extra resistor pack like used on the stock turbo cars. Flow rate of 34.6-35.5lb/hr or 363-373cc/min at 3 bar of pressure compared to 32lb/hr and 337cc/min of the stock, later 0280150804 turbo 8V injectors. Running these injectors will permit over 200hp on E85 in the future if I want, and well over that with pump gas(not going to happen).
Here they are compared to the 850T injectors I just had cleaned for the General Leif. As you can see, they're missing the top groove for an injector clip. I may need to add that groove for the injector clip depending on the style used.
Old 04-25-2019, 03:32 PM   #794
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
i wonder how that will change your gas mileage?
One Volvo left.
1982 244ti, 2014 Mazda3 2.5GT, 2016 Kawasaki 650R
Originally Posted by fivealive View Post
Seems like the TB [performance mod] list is normally:
#1: Cut springs
#2: Junkyard +T
#3: Gut the interior
#4: ???
#5: Crush it
DurableSwedish is offline   Reply With Quote
Old 04-25-2019, 04:23 PM   #795
gsellstr
gsellstr's Avatar
Hmm, I wonder how these would be to replace the d-jet injectors on the 140?
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 04-25-2019, 05:15 PM   #796
klr142
Turbo, what?
klr142's Avatar
I don't expect much of a MPG gain with these injectors, but we shall see. I do expect it to idle a little bit better and they'll support more power than what I'm currently running, as well as straight E85 if I want.
I was reading through my thread... Good times, sounds and hilarious Simon video... Maybe my bottom end really is getting weaker(why wouldn't it!), I barely beat my best automatic equipped 1/4 mile time this last time out...
Originally Posted by klr142 View Post
At the end of this movie you can hear the car how it currently sits... Sadly you still can't see much(yet another video of my car in the dark, haha). Good stuff from Simon, as always!
3rd gear pulls... Dynojet dyno, so it should be comparable with my H cam dyno pulls last time, except for the fact that these are in 3rd gear instead of 4th. Which could be making them read lower. *sigh* I guess a trip to the drag strip is in order before I give up on this camshaft for now. It's just too big for my manifolds, and I don't want to spend vacation money on the car right now. Maybe if I get a nice tax return, but that would require DOING my taxes.
Old 04-25-2019, 05:24 PM   #797
IansPlatinum
IansPlatinum's Avatar
Aren't most/all the EV6 injectors high impedence? D-jet is low-impedence, so I don't think it would work. That, and the proprietary injector holds will give you hell.
Maybe you know something I don't?
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'73 1800es - "Sunny"
Old 04-25-2019, 10:53 PM   #798
gsellstr
gsellstr's Avatar
Didn't say I had d-jet on the car, just the injectors, running on MS1V3, but with a resistor pack. lol
Old 04-29-2019, 11:07 AM   #799
shoestring
shoestring's Avatar
I didn't notice much of anything when I changed to the EV6 in my 245. Maayyybbbeee the idle quality improved about this much. Can't see that from where you are? Neither can I.
