bumblebeeman
- Sep 26, 2012
- Petaluma
Yo Everyone!
So years ago I took out the giant clock and swapped a tach and small clock in.. Its an '86 245 N/A. The cluster was a bit funky but I broke all the seals and completely cleaned it, went through the whole thing in the evenings as I was doing the Ending wiring Harness....
so six months back, tach sometimes won't run, until now the tach does absolutely nothing... snagged another form the yard the other day. tested the tach wire, it had a signal that went up and down when I pressed the gas... put the different tach in, Still nothing..
I should also tell you that this cluster sometimes has an issues where the temp gauge starts to go up, both blinker lights come on, and high beams are illuminated. gas still works, speedo shows ~35 during this time.. if I reach around the underside and wiggle the little white connector on the Speedo it usually stops..
Haha ok guys, ideas or leads to chase?? It must be the cluster right?? but how to diagnose it and make sure I get a new one that works well???
Thanks!
BBman
Thanks!
BBman
