Old 05-15-2007, 12:54 AM   #1
Tabor
volvoholic
Tabor's Avatar
Default two piece drive shaft advantages?
So, I can name a lot of advantages for why you would want a one piece drive shaft.
Why did Volvo go with a two piece?
1983 Volvo 245T with too many mods to list
1975 Volvo 242DL PARTING OUT pm me for parts!
Tabor is offline   Reply With Quote
Old 05-15-2007, 12:59 AM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
http://www.rodandcustommagazine.com/...iveshaft_tech/
Old 05-15-2007, 09:53 AM   #3
JohnLane
Of the Volvos I've driven that were fitted with a T-5 it has been the cars with a one piece driveshaft that had the wierd driveshaft noise/vibration. My rallycar with the Jerico has a two piece driveshaft and does not have that wierd vibration.
Old 05-15-2007, 09:54 AM   #4
thelostartof
unbalanced chemical
^^^ from what i have heard lots of others had that same issue
tis why i am going to be retarded and spend way to much $ on a custom two piece aluminum driveshaft that is oversized .... 3" should be more than enough
Old 05-15-2007, 09:57 AM   #5
JohnLane
Do you really NEED aluminum? My two piece steel driveshaft is more then up to the task of handling the stupid power my car makes, is not noticably heavier then stock, was affordable to build and has been failure free.
THELOSTARTOF can feel driveshaft vibrations without driving the car..... Good-good-good vibrations.....
Old 05-15-2007, 10:01 AM   #6
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
3000lb swedish vibrator :D
Old 05-15-2007, 10:06 AM   #7
thelostartof
unbalanced chemical
what size did you get yours built in? all of the old muscle cars i used to work on we liked aluminum but i guess if you can convince me otherwise it would prob save me a bit of $ . tho lighter on the drive train is a big key for getting every last second and mph out of a drag car no?
Old 05-15-2007, 03:46 PM   #8
SteveMD
Not A Typical Dating Site
SteveMD's Avatar
I see the aluminum DS's all the time in the JY. That's some good donor tubes, I guess.
I once saw a composite DS, hella light.
Originally Posted by billkaz View Post
I've hit black ice with winter tires. The only thing they were good for was driving out of the ditch after.
Old 05-15-2007, 03:49 PM   #9
Matt Dupuis
Matt Dupuis's Avatar
Let's hear 'em.
Matt Dupuis is offline   Reply With Quote
Old 05-15-2007, 03:55 PM   #10
SteveMD
SteveMD's Avatar
Originally Posted by Matt Dupuis View Post
Let's hear 'em.
Dare I say ? (not you, Matt. The OP)
Old 05-15-2007, 04:04 PM   #11
JohnMc
JohnMc's Avatar
I'd think that with a two-piece you can get by with a smaller driveshaft tunnel and still have clearance with the rear suspension at full compression.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-15-2007, 04:10 PM   #12
Tabor
volvoholic
Tabor's Avatar
Let's hear 'em.
R U 4 reals?
Seriously:
  1. Weight
  2. Cost
  3. Complexity
  4. driveline losses
Those are the ones I can think of off the top of my head. I am sure there are more.
Old 05-15-2007, 04:21 PM   #13
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
R U 4 reals?
Seriously:
  1. Weight
  2. Cost
  3. Complexity
  4. driveline losses
weight, not really. will get to that in a second tho.
Cost? perhaps, depends.
Complexity, again, yes and no. from a sideline stand point of throwing it in the car, sure.
Driveline losses? if properly lubricated, the loss due to drag from the center support bearing is going to be negligible in comparision to things like axle bearings, gears, transmission, etc.
Benefits of a 2 piece:
Ease of correct pinion angle, and being able to maintain that angle (assuming you set it up properly in the first place)
Requires less clearance under the car since most of your up down/side to side movement can be located towards the back of the car.
As each segment is shorter, does not require large/heavy material to ensure the driveshaft does not sling appart at higher rpms, so you can use a narrower shaft that is as strong or stronger than a comperable single shaft, and as such is likely to weigh less.
I'm sure there are other subtleties, but that last one is the reason I didn't switch to a 1 piece. That, and well, it only cost $50 to have a stock shaft modified for my t5. from the volvo dealership.
Megasquirt Tuning!
Old 05-15-2007, 04:26 PM   #14
Tabor
volvoholic
Tabor's Avatar
Hey, cool beans. That is probably what I will do. I think it is more of a question of "what was the car designed to have" than 1 vs. 2.
Old 05-15-2007, 04:42 PM   #15
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
I'm rockin' the two piece in the 700. Works fine. Not sure why you wouldn't given the cost/strength ratio. It was cheap, balances well etc. I need to replace the center bushing and biscuit soon since I trashed another set of those, but the center bushing for a 700 is fairly strong and can be adapted to a 240 and the biscuit doesn't apply to a T5.
How PSI a stock can support?
Old 05-15-2007, 10:39 PM   #16
JohnLane
I'm using the size that we find under a Ford 3/4ton pickup truck with the U-Joints that are standard for a 9" thing. This was really easy to do as I have a Ford (Jerico) box and a 9" rear end. As we know my toy makes silly power and it has held up even to the rocks in rallyin.'
Weight savings? Well for a drag car you may see some benefit. If it pencils out for you to do so then write the check. For me...... I just add power. Bwahahahahahaha......
Old 05-16-2007, 01:51 PM   #17
2manyturbos
I'm sure one of the main reasons Volvo went with a 2 piece is the more U-joints you have in the system, the less speed change you have in the shaft. If anyone here has ever seen a Buick drive shaft from the early to mid 60s, you would understand. They ran 2 piece shafts with constant velocity u-joints at 2 of the three connections. Very expensive to build, very smooth and quiet.
The problem with a one piece shaft in a 200/700/900 series is the 2 angles at the opposite end of the shaft are quite different. That causes the shaft to want to rock up and down like a see-saw and change speed at opposite ends. I ran a one piece shaft when I did my V8, 240 conversion and I could never get rid of the vibration in the system.
Old 05-16-2007, 02:03 PM   #18
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
i say go with what works and is cheapest! i have seen a twisted na 240 driveshaft, but i think it was one of those things where the planets all alinged at the same time we hit the master resonance, rear end fallowed closly behind
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 05-16-2007, 02:26 PM   #19
gsellstr
gsellstr's Avatar
I've also got a kinda funky vibe in the 140 that's been unable to be figured out. The 1-pc I've got there behind the W50 box is certainly no lighter than a 2pc, since it went from 2.25"OD to 3"OD, similar wall thickness. I will say though it's REALLY nice not having to deal with the center bearing, and launches feel a little more solid.
RIP
74 144 B20
90 745Ti
Old 05-16-2007, 08:21 PM   #20
sberry
I have a one-piece driveshaft in my P1800 T5 conversion. I chose to go with the one-piece to eliminate the center bearing and take complexity out of the system.
I experience the dreaded vibration with my install. I've corrected pinion angle and messed with mounts at length. Still no resolution. My next step is to try oing back to a 2 piece driveshaft.
More here: http://1800philes.com/t5.html
steve
sberry is offline   Reply With Quote
