Old 05-28-2007, 06:02 PM   #1
pwschuh
Rolling...
Default 1984 245T mLPT B274FT Project
I decided to go ahead and make this post even though the car is not running yet. I don't know exactly when that will be, but since the Carlisle post and Ben's post have already made the car public, I might as well show you most of the rest of the work. The car is a work in progress that I have been modifying for 23 years. The car looks like I want it to look, although I know it may not be to everyone's taste. There are still things that should be changed and I will get to them as time allows. The car has 27,600 miles with only the hood having been repainted.
The car as it looks right now, although there will be several more external changes made later on this year:
This is a list of most of the modifications:
ENGINE: UNITEK&ST mLPT B274FT Volvo “Crate Motor”:
• OMEX 710 Series digital engine management system
• 1997 Vovlo B230FT block with billet stroker crank
• UNITEK Modified oil pump (spring rate)
• Bore/Stroke: 96.30mm / 93 mm (2.71 liter displacement)
• UNITEK UNI-Flo Phase III 16 valve head with additional flow modifications
• Compression ratio: 8.6:1
• Squish height: .75mm / .0295 in
• Intake valves: increased from 34.5 mm to 38 mm
• Exhaust valves: increased from 31.5 mm to 33.5 mm
• UNITEK “E-level” valvetrain: Cam - 264 duration, 11.8 mm lift; billet cam followers
• Cutting edge head gasket
• Custom forged pistons with Total Seal high performance rings
• Billet H-beam rods
• UNITEK custom intake manifold:
o dual injectors per cylinder
o 48 mm individual throttle bodies
o Jenvey 125 mm intake trumpets
o Kaplhenke Racing custom intake plenum
• UNITEK custom tubular exhaust manifold:
o Swaintech ceramic coating
o Exhaust gas temperature probes in each runner
• UNITEK baffled race oil pan with Ishihara-Johnson crank scraper
• Garrett GT-30R dual BB turbo
• Tial 40 mm wastegate
• Tial 50 mm blow-off valve
• Accusump 2 quart pre-luber / surge control
• RX-7 FC oil cooler
• Remote oil filter
• PCV oil catch can with dolphin’s throat discharge
• MOCAL turbo oil scavenge pump
• Custom 3”” exhaust with Vibrant race CAT, racing glasspak, and NB & WB O2 sensors
• AEM UEGO wideband O2 AFR system
• AEM Dryflow air filter
• Wizard Cooling custom aluminum radiator with Spal 16” electric cooling fan
• NPR 27 row aluminum intercooler
• Modified MOROSO torque-link engine stabilizer
• Cool-Flex radiator hoses
• Hello Kitty +10 HP
DRIVETRAIN MODIFICATIONS:
• 9.5 lb custom flywheel
• Sintered metal, solid center, 4-puck clutch
• Centerforce II pressure plate
• UNITEK M47R race gearbox
o Close ratio 5-speed
o Straight-cut gears
o Dog engagement (no synchros)
o Aluminum race short shifter
• One-piece PST carbon-fiber driveshaft
• Volvo limited-slip differential
HANDLING / BRAKE MODIFICATIONS:
• Momo / R-Sport steering wheel
• 17-inch TSW Blade wheels
• Pirelli P Zero Asymetrico 205/45-17
• Strut tower cross brace (currently removed due to plenum interference)
• Strut tower to firewall braces (currently removed due to plenum interference)
• Front sub-frame braces
• ipd 25 mm sway bars (front & rear)
• MVP adjustable Panhard rod
• ipd adjustable torque rods
• Rear suspension limiting straps
• Choy custom anti-roll bar end links
• MVP Adjustable coil-over suspension:
o Bilstein custom valved HD shock inserts
o 8” Blue Coil springs: 300 lb/in front 200 lb/in rear
• Prince bump steer/ roll center correction
• Battery relocated to right rear tire well
• Brembo cross-drilled rotors
• Braided metal brake lines
• Brake cooling ducts from chin spoiler
AERODYNAMIC MODIFICATIONS:
• Modified Grant/Rensi ground effects
• ABS splitter / front undertray
• Aero headlamp covers
• Hood louvered above turbo
• Rear upper body Vortex generators
• Rear bumper diffuser with underbody tray
Here is a link to the pbase account where you can view 90 other labeled photos if you care to.
http://www.pbase.com/pwschuh/root
Thank you very much to Mike, mikep, blkaplan, volvorules, fidel, towerymt, and many others for all of the help, and to all of the TBricks DC area crew (and Nick) for keeping this to yourselves for 18 months.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 05-28-2007, 06:04 PM   #2
Biesey
Biesey's Avatar
your car is absolutely awesome, it was a real treat to see in person.
-dan
1971 1800e + B230ft | 1999 BMW 528it
Biesey is offline   Reply With Quote
Old 05-28-2007, 06:20 PM   #3
Icey Brick Boyz
This is by far the nicest car ever put together on TB and it still has so much farther to go. I have known of this car and its mythical status since before I had my drivers license.
Paul you sure know how to show the youngin's how to do it!
www.TRIANGLESUNLIMITED.com
My pbase account
neeeener neeener I don't even own a Volvo
Old 05-28-2007, 06:23 PM   #4
BenW
damn nice.
'86 245 DL - Currently killing Battery Daily
'03 VW Golf TDI ---> 48MPG Lifetime
BenW is offline   Reply With Quote
Old 05-28-2007, 06:29 PM   #5
Can play the blues
Default Fantastic car!
It was a pleasure to meet you and see the car in person at Carlisle. Fantastic work in progress.
1982 242 turbo. 318k miles. A few changes for the better.
1993 245 Classic, 280k miles. Now with enem V15.
Old 05-28-2007, 06:36 PM   #6
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
unbelievable Paul. Bravo man Bravo!
off playin building geetar(s). bbl
Old 05-28-2007, 06:43 PM   #7
shaved240
body work hell
very nice, and looks like ALOT of cash was put into this project..
i think your volvo lsd won''t last too long
240 b230f+t, aw70 to m46 swap gone
242 turbo (new project car)
99 Camry (daily)
shaved240 is online now   Reply With Quote
Old 05-28-2007, 06:44 PM   #8
kahlua240
kahlua240's Avatar
OMG WANC TITA
oh my god what a nice car that is totally awesome.
Originally Posted by isaac
If you had any more grille you'd need to run your car off of propane.
Photobucket
kahlua240 is offline   Reply With Quote
Old 05-28-2007, 07:10 PM   #9
MrBill
Can't have my internet
MrBill's Avatar
man im a dumbass and didnt see the car at carlisle.
Awesome car man, quite the project
Originally Posted by gdogg16 View Post
In case you guys forgot, VS sucks.
1978 244dl - Runs - Now with b230f+t/MSIIe/IPDsprings/BillyHDs/25/25sways/adjustable torque rods and panhard bar/holset/T5. And hydras
1986 760 Turbo - Now with 299k and M46
87 245DL - M47 206k, stock and beat.
87 245DL - M47 130k, stock and less beat but still beat.
MrBill is online now   Reply With Quote
Old 05-28-2007, 07:15 PM   #10
Homer
Exklusiv Zubehör Klub
Homer's Avatar
Wowza!
-Jacob
2006 Audi A4 6MT quattro, and ^
Originally Posted by Alex Buchka
Not huge, but THICK. Just how I like it.
Old 05-28-2007, 07:15 PM   #11
adrianpike
hamnområdet tripplar
adrianpike's Avatar
Are there any photos of your vortex generator floating around?
edit: aha, for some reason I didn't spy them in your pbase first time around.
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
I'm looking to buy the following - PM me if you've got any of it: LSD, Big Brakes, 18"s, bucket seat
doug was here
adrianpike is online now   Reply With Quote
Old 05-28-2007, 07:35 PM   #12
fivealive
fivealive's Avatar
very nice. wish that would show up at my door
Got Yellow?
Join the club!
fivealive is offline   Reply With Quote
Old 05-28-2007, 08:32 PM   #13
Crazychopstick
Angrychopstick
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
That thing is incredible!
Crazychopstick is offline   Reply With Quote
Old 05-28-2007, 09:43 PM   #14
aplitz
Donuts on your lawn
aplitz's Avatar
Simply wow.
aplitz is offline   Reply With Quote
Old 05-28-2007, 09:51 PM   #15
Tanglefoot
Tanglefoot's Avatar
This is inspirational. And I now need to go change my pants.
Originally Posted by speedfoos View Post
When I'm in working in my garage, I feel like I'm a Rembrandt, or Picasso, working in my element making beautiful things. Then I visit a Buchka thread and realize that I'm a retarded 4-year old attacking a piece of construction paper with finger paints.
Tanglefoot is offline   Reply With Quote
Old 05-28-2007, 10:05 PM   #16
carloss
carloss's Avatar
Master piece pure inspiration
carloss is offline   Reply With Quote
Old 05-28-2007, 10:14 PM   #17
mikep
The MP
mikep's Avatar
I wish I had taken a picture of the crowd that gathered around it at one point at Carlisle. At least a dozen people, while other cars had two or three (or none) people gathered at one time.
We were so secretive about this car that we didn't even discuss it amongst ourselves. At one gathering in Cambridge we were talking a bit, but nobody would bust out any details, even though we all had seen the car. The ribbing Bne part was fun, though.
Have you thought about training your minnows to vanquish your enemies?
Old 05-28-2007, 10:18 PM   #18
badvlvo
spambot
I see your car and I must touch myself.
Someday I hope my car will be at that level, but I doubt I have the patience.
Very nice work.
Buy this amp! http://forums.turbobricks.com/showthread.php?t=214308
Originally Posted by Chief U.S. District Court Judge Vaughn Walker
"race restrictions on marital partners were once common in most states but are now seen as archaic, shameful or even bizarre. Gender no longer forms an essential part of marriage; marriage under law is a union of equals."
Originally Posted by mullen1120 View Post
Problem solved, my dumbass left a paper towel in the turbo inlet
Old 05-28-2007, 10:19 PM   #19
MikeSr.
Hoodoo Operator
MikeSr.'s Avatar
Nice work!- Is this the Turvo car?
Old 05-28-2007, 10:27 PM   #20
pwschuh
Rolling...
Yes, it is.
Old 05-28-2007, 10:37 PM   #21
Dfer10
# 2961
Dfer10's Avatar
absolutely love your car. you def pay attention to details i really enjoy seeing a volvo with this much attention. beautiful man
Devin
Gone But Not Forgotten
RIP 6-2006 93' 944
Big Turbo,
Manual Tranny,
now a yellow
Dfer10 is offline   Reply With Quote
Old 05-29-2007, 04:02 AM   #22
JW240
visst
JW240's Avatar
very very very impressive. props!
240 | 1991 | 257 KKm | B230F+T | M90H | fuel:E85
Amazon | 1968 | bare chassis | rust fixed | finished 2015+?....
My Gallery, Volvo and other stuff...
Old 05-29-2007, 05:05 AM   #23
Volvo244GLE
Volvo244GLE's Avatar
the amount of work thats gone into that car is amazing, very inspirational
242GT Project - who likes rust?
Volvo244GLE is offline   Reply With Quote
Old 05-29-2007, 05:47 AM   #24
NONo443
NONo443's Avatar
Nice work man. If I was you, I would be very proud.
NONo443 is offline   Reply With Quote
Old 05-29-2007, 07:12 AM   #25
Midgie245R
Midgie245R's Avatar
Oh..ugh...up...oh dear...pass the tissues please.
Congratulations mate. Looks awesome
Midgie245R is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
