DeathWagon
- Feb 6, 2003
- Under the hood of kennys car!!!
I got these from a 240SX fourm I am on also just thought I would pass them on.
I also found some neat stats for stock ic's:
The NPR IC(Med): at 329cfm and 290?F on the inlet side of the IC, the
pressure
drop is 0.09psi. The outlet temp is 130?F, heat rejected is 55553
BTU/hr, and
the calculated heat exchange area is 1404 square inches.
Starion IC : (the bigger one) at 324cfm and 292?F on the inlet side of
the
IC, the pressure drop is 0.29psi. The outlet temp is 139?F, heat
rejected is
52287 BTU/hr, and the calculated heat exchange area is 1217 square
inches.
Saab 9000 IC: at 332cfm and 295?F on the inlet side of the IC, the
pressure
drop is 0.81psi. The outlet temp is 123?F, heat rejected is 60350
BTU/hr, and
the calculated heat exchange area is 1602 square inches.
Volvo IC: at 331cfm and 293?F on the inlet side of the IC, the pressure
drop
is 0.55psi. The outlet temp is 126?F, heat rejected is 58809 BTU/hr,
and the
calculated heat exchange area is 1539 square inches
Granted 331cfm isn't all that much, but it gives you an idea of the
difference between the npr and your Volvo ic. Those npr intercoolers
are stoopidly popular down in central America.
http://www.rx7club.com/showthread.php?s=&threadid=255658&highlight=npr
http://www.15psi.com/ic_tests.htm
pressure
BTU/hr, and
the
rejected is
inches.
pressure
BTU/hr, and
drop
and the
