![]() I've been running a cone filter since I bought my car, never had any real problems with it other than it being a little louder. This weekend I bought an airbox, closed the hot side of it with some screws and hid my boost controller behind it.
No difference at all on the butt dyno whatsoever. The car is quieter now, the power seems to be identical at 14psi as it was with the cone, and the only noticable difference seems to be that the car doesn't run quite as hot when driving a long distance. So has anyone done any real testing on this, like dyno comparisons? I'm tempted to if I have the time, because I think the airbox is better (or atleast the same). Just my 2 cents
"The turbo has never been used while driving" - Best line in a 740 Turbo ad I've ever seen, Craigslist |
![]() Unless you're running a foam cone with some form of cold air box to keep it away from engine compartment heat, the OEM filter is really nice and big. If you're running a K&N style cone, consider the surface area of the cone to the surface area of a stocker. Just gut your airbox and enjoy.
Bored Member
![]() Trying to increase flow by going to cone...but doing nothing to isolate it from hot air from engine is not a good idea. Very ricerish to just do it to enjoy the spooling sound and reduced performance.
#4 |
Turbo, what?
![]() And if it's a small cone instead of the largest beast you can possibly squeeze in there, it's not only sucking hot air(without a shield), but restricting flow because it has less surface area than the stock filter.
700 series airboxes can be made to work very nicely for a cheap CAI. Block off the hot air bit, take out the cover thing on the inside of the lower airbox, and pull out the cone that fits into the inlet on the side of the airbox.(is the 900 airbox the same? It might be.)
Kyle - NLMGG: '91 244 NA Toy - General Leif: '71 142 Endurance Racecar - The General's Facebook - Oregon Volvo Tuners - Died ![]() |
#5 | |
![]() Quote:
#6 |
Turbo, what?
![]() Look at the air intake part of the 700 box, there's a cone in there that restricts the size. Take it out and it will flow better, and be a little louder, but not nearly as loud as the cone. It'll be better.
You can't get much better than that for a basic intake setup on these. |
#7 |
safety first
![]() what about a cone with a heat sheild. thats what i have, the heat sheild is made from insulated sheet metal. you think this is doing anything for stopping hot air?
'07 S60R: MT, black sapphire metallic, Atacama interior | Eibach springs | OBX 3" DP (no cat no res) | IPD stg1 tune | Forge cbv | poly engine/tranny mount | HD tcv | snabb intake pipe | custom FMIC | old 745 project |
#8 |
Has been
![]() heat shields don't really do anything. The heat is coming from the engine and the radiator heating up the engine air. You really need a snorkel of some sort, like every OEM car out there.
#9 |
Turbo, what?
![]() Depends completely on what it looks like, and if it is pulling in cold air from anywhere... Picture?
#10 |
safety first
![]() what can i do to improve this? i also used an hvac laser temp guage the one day and with the hood open the air temp diff was about 10 deg so it is doing something
#11 |
![]() Just extend the aluminium upwards so it seals with the 'hood' when closed, and extend the rearmost baffle so it seals with the side of the engine bay. I'm presuming it's like the 240 where there're big holes at the front of that enclosure; and all your cold air from not-inside-the-engine-bay will come from there, once you've sealed-off the engine-bay.
Officially more homely than Paul Buck. When I'm cruisin' in overdrive ... Don't have to listen to no run-of-the-mill talk jive. Shatner: The Colonel is breakdancing ... gimme a break!! Rollins: Credit terms raised! Shatner: I can't get behind any of that! Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ... Rollins: Well, I can't!! |
#12 | |
![]() Quote:
#13 |
safety first
![]() lol it sure it. 6000k mCcullough's worth every penny
#14 |
![]() it says on the ID plate 745, and the intercooler looks pre 90, im assuming you have quad headlights, how did you get HIDs? unless you have the 2 headlight design.
#15 | |
OEMplus++
![]() Join Date: Aug 2003
![]() Quote:
That's the smallest HID ballast I have ever seen. |
#16 |
safety first
![]() 745 means wagon, the intercooler better not be pre 90 lol. its the car in my sig though, and the HIDs came from ebay 9004 bulbs.
#17 |
![]() no, i like wasting time. lol. i didnt see it at first, "show sig once per page"
it is small indeed. i guess il have to either complain about how i cant get them with a quad light design, or spend a rediculous amount for HIDs and the quad light shells you put them in. |
#18 | |
![]() Quote:
anyway, i was assuming if it was pre 90 740 it had quads, but further inspection of your sig proved me wrong ![]() |
#19 |
safety first
![]() its not the ballest, heres the whole set up, the little black box in the upper left is what the high beams run off of since i got the bi-xenon HIDs
#20 | |
safety first
![]() Quote:
#21 |
OEMplus++
![]() Awesome. Thats what I was thinking. How is the high/low beam?
#22 |
safety first
![]() honestly there is very little difference between the high and low. its nothing like the difference from regular H4's. i only got the bi-xenons bc you need a high beem to pass inspection. either way HIDs are worth every penny, i cant tell you guys how much of a difference they make when driving at night.
#23 |
![]() ther are HID's with motorised shrouds for H4's on Ebay Uk if that helps.
#24 |
OEMplus++
![]() Pishaw. Yeah I know. Thanks BB.
#25 | |
![]() Quote:
-80 242 DL- base as a mo -82 242 GLT Turbo+I Stage 0, 15psi, 3" catless TBE, WORKING Air Con... 186k -96 850R Estate, 114k miles. -96 850R Estate, 238k miles. -06 V70R -142K -05 Subaru Impreza WRX STi CGM 30k -95 Toyota Land Cruiser Locked 214k |
