Old 09-10-2007, 09:10 PM   #1
the poi
Has been
the poi's Avatar
Default 95+ 960 Front Coilovers Part 2: There is no Part 1
Alrighty, the following is a very delicate operation, and should be done in a cleanroom, if at all possible. First, obtain some brand-spankin new Koni Sport shocks for an 850. Also, two 2.04" coilover sleeves from Coleman racing, and some springs. I'm starting out with 10" 450 pounders. Now, the delicate operation begins:
OH GOD WHYYYYY?! YOU'RE A MONSTER!!
THE HUMANITY
NOOOOO!
DEAR GOD
DON'T DO IT. OH GOD DON'T DO IT.
WHY ARE YOU DOING THESE THINGS?
Ohhhhh. Pretty!
For the initial cut, I used a Dremel, with a thin cut off wheel, and cut most of the way through the lower perch immediately under the weld. Cutting in through the perch as shown to get started. Shoving a chisel in between the angle-grinder cut and hammering down will eventually get a crack going. Once the crack has started around the circumference (where you weakened the metal with the dremel), hammer down (in line with the strut) on the perch, and propagate to crack around the strut.
There are two annoying welds under the strut perch. You can see how I dealt with them above--cut a pie shaped section out to disconnect the two parts--you can "wiggle" the smaller piece up and down until you break the welded. Repeat for the larger section. Then, remove the remaining 75% strut perch.
Get out the grinder, and grind down the remaining weld--I went really slow and quenched it with water, so it never got to a too-hot-to-touch temperature. May not even be that necessary, but better to be on the safe side. At least with Konis and coleman sleeves, the welded doesn't have to be flush with the body, just close to flush, so you don't have to get into the body much (although that didn't stop me from knicking it a couple times )
I gooed up the top (3m window weld!) to keep it from rattling and keep rainwater from getting in there (also painted the ground section, of course)
Spring stuff! Hog out the upper perch like so:
The spring will pop right into the recess, and rest directly under the bearing (rad!)
My camera ate the next few pictures, but basically, I used a spacer at the top about an inch and a half, as the 850 struts are a bit shorter than 960 struts. The spacer keeps the thread from sticking through the hood. (mines actually a little too long, as I couldn't fit the lockwasher in. I'll fix that...)
Anyway, here's what it looks liek from the bottom:
hawt!
It's practically adjustable!
So ya, the lower spring perch is currently at it's lowest position-any lower and the tire would contact it. There's about 3/16" of clearance between the threaded collar and the wheel rim (on ronal 18x8 RTs). If it needs to be lower, I'll space it out, but it'll probably be fine. Got to get it on the ground before I can figure that all out.
The only bitch is the swaybar endlinks. I modified my stockers, because this nerd I know insisted if I built new endlinks with 8$ heim joints they'd start clunking in a couple hundred miles. Here's what I did:
The two pieces are welded together through the large "window", and the outer cylinder provides a little more strength. I tested these by jacking up the front of the car from one side, so they appear to work right
edit:// hee, my binder clip is showing!
Have to put the back end of my car back on before I can go test it... I'll let you know if I've built a deathtrap.
FAQ:
Q: It's really that easy?
A: Yes.
Q: Seriously?
A: Ya I know, right?
Old 09-10-2007, 09:44 PM   #2
Karl Buchka
Originally Posted by the poi
Q: Seriously?
Srsly, like, the correct answer is:
A: Ya, inorite!
But I digress. If you die, I call dibs on your car mangled, bloody corpse.
Old 09-11-2007, 07:40 PM   #3
towerymt
the real Towery
towerymt's Avatar
Originally Posted by the poi View Post
bad juju? do you really want a puddle of crud building up in there, grinding on the strut shaft? I get lots of little rocks between the spring and the lower seat, so it will get into that "cup" for sure. I'd trim the sleeve down to ~1/4" or more below the top of the strut. The spring will likely grind against the top 1" or so of the sleeve, so don't be alarmed. You weren't going to use that part of the thread, anyway. I primed/painted my strut tubes and slid the sleeves on with nothing around the top and they've been fine. I replaced a bent strut tube and the sleeve came off OK, and it wasn't rusty underneath since I coated the bare strut tube after grinding.
Old 09-11-2007, 07:51 PM   #4
the poi
Has been
the poi's Avatar
bad juju?
ick, i was kinda worried about it, but figured it'd be fine--there's no way for anything to "drain" out of the smaller "cup" that's already in there (formed by the gland nut thingy). Wouldn't I have the same issue even if I cut down the thread tube because of that? What I really want is a bellows to put in there, but I can't find anything from the usual places. Know of anything that would work?
edit:// also, shouldn't it be "Puddle of Crudd"?
Old 09-11-2007, 08:45 PM   #5
towerymt
the real Towery
towerymt's Avatar
Just looked like it could hold more crudd.
My 240 bilstein bellows might work. I think they had some splits. I'm thinking if you cut one down and it was a few inches tall, it could be zip tied to the sleeve. As I recall, it has a small diameter opening at the top, so it was meant to fit up high on the bilstein (since it has the large diameter shaft, being inverted and all). But on the koni, it might fit close around the koni shaft. i'll take a look tonight. I stopped using the bellows when I did coilovers because they didn't really fit well inside the 2.5" springs. I have some loose springs I can check clearance on, though, so maybe they can work. Did the konis come with any boots/bellows?
they're OK.
Old 09-11-2007, 08:54 PM   #6
badvlvo
Bad for Babies
badvlvo's Avatar
Nice work. Now you need some bling brakes to match.
Died at age 35
Old 09-11-2007, 09:00 PM   #7
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Looking good Chris.
Brakes are in the works last I heard
Old 09-11-2007, 11:20 PM   #8
the poi
Has been
the poi's Avatar
Ya, unfortunately I'll have to put up with some homo's awkward sexual advances until I get them
Old 09-11-2007, 11:22 PM   #9
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Looks sweet man
Old 09-11-2007, 11:29 PM   #10
thelostartof
unbalanced chemical
thelostartof's Avatar
so wait when did you weld those to the struts?
Old 09-12-2007, 12:20 AM   #11
socalsean
back in the game
socalsean's Avatar
Wow Chris....an entire post without "italics"? What's gotten into you?!!!1111
I still have those take off 4 pot Brembos (calipers, brackets, rotors, & lines) from an 850 at work. If you're interested I can get a price. Let me know
socalsean is offline   Reply With Quote
Old 09-12-2007, 01:31 AM   #12
Stereophile33
Stereophile33's Avatar
Chris, those look great. We have starting mocking up with those and just cutting the threaded sleeve so it fits under the nut.
Why so stiff???
in quasi-retirement...
Stereophile33 is offline   Reply With Quote
Old 09-13-2007, 08:02 PM   #13
the poi
Has been
the poi's Avatar
Bwahaha, holy ****, the car can sorta handle now. Jeebus! It doesn't roll about like a tugboat!
However, it appears the inside wheel rim is contacting the sleeve on one (or both!) sides. There's about 1/8th of clearance there, is that flex about "normal" for a cast aluminum 18" wheel? if it is, I'll just space the wheel out. If that isn't normal, I suppose I should try to figure out what thats about...
Old 09-13-2007, 09:41 PM   #14
Pennybridge Pioneer
You're an idiot
Pennybridge Pioneer's Avatar
normal
i think "normal" went out the window a long time ago.
btw we're going to look at a wagagon on Saturday
leave me alone, I know what I'm doing
Pennybridge Pioneer is offline   Reply With Quote
Old 09-14-2007, 03:01 AM   #15
the poi
Has been
the poi's Avatar
Thats what I hear. Lets hope my wheels don't flop completely off before then.
Old 09-15-2007, 03:26 PM   #16
Default dust covers
Looks great. I ran my coil overs for awhile without dust covers but had too much buildup of crud on the shaft. The Bilstein dust covers Towery mentioned worked. They just fit inside the springs. If you don't want to have the springs hit the top of the threaded sleeve. You can buy barrel springs from various sources such as http://www.bluecoilspring.com/ and also from AFCO. The barrel shaped springs take away a bit of the side loading, too.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 09-25-2007, 09:24 AM   #17
Moon_walk
you guys know that you can convert 960 regular struts with koni inserts ?
by the way . where did you get that coilover kit ?
here's what i did
above is original .
below is with strut insert
picture of my older insert .. exchanged it due to that it was to soft
close up of the thread and nut
Moon_walk is offline   Reply With Quote
Old 09-25-2007, 09:31 AM   #18
740Weapon
Traitor
740Weapon's Avatar
you are way to fearless.
kick ass.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 09-19-2008, 10:49 PM   #19
DrvSfly
Bored Clown
DrvSfly's Avatar
I hate you. You weren't around when I ghetto dropped my 960. Then I dropped it into a ditch, got the insurance money, and built a turbocharged cabrio. All was well.
Drive Safely
I think we'll either get rid of religion, or it will get rid of us.
'83 245 TIc sold
'97 960 totalled
'94 745 totalled (not mine)
'87 744 totalled (not mine)
'91 780 totalled and sold
'81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
DrvSfly is offline   Reply With Quote
Old 09-19-2008, 11:02 PM   #20
volvo940tuner
volvo940tuner's Avatar
holy thread resurrection batman
this is still one of my favorite projects though.
'93 944-SOLD
'91 745 TIC- PARTED OUT
'97 854 R- SOLD
'96 854T Platinum- SOLD
'98 S70 GLT- SOLD
'98 V70R-SOLD
'95 854 T5-R--teh yellow
'90 744 TIC SE
'96 854R-winter car
'88 BMW E30 325IS
volvo940tuner is offline   Reply With Quote
Old 09-20-2008, 01:14 AM   #21
Tom Wiley
so how are the coilovers holding up?
Tom Wiley is offline   Reply With Quote
Old 09-20-2008, 03:30 AM   #22
Alex Buchka
8 cylinders
It's hard to say. Chris only drives the car 5 miles a year.
Old 09-20-2008, 04:07 AM   #23
the poi
Has been
the poi's Avatar
So to answer the question, they're like new.
Old 09-22-2008, 06:47 PM   #24
Kevin Hawkinson
Better Red than Dead
Kevin Hawkinson's Avatar
Italics are so AWESOME!!!
-Kevvie Hoikansanalainenen
Kevin Hawkinson is offline   Reply With Quote
Old 06-18-2009, 11:51 AM   #25
SouthSideSlider
SouthSideSlider's Avatar
hey do you think 850 K sport coilovers would fit rigt on?
Originally Posted by blkaplan View Post
i love vibrators. How loud is that one?
Originally Posted by Fivehundred View Post
The things you can achieve with a bit of vibration......
1987Volvo 780 GLE: stock, boring and in questionable condition
1989 Volvo 740TiC wagon:B230ET,G80 Locker, Port polish,Oversized valves,10PSI(MBC) ,M cam (parts car now)
1980 Suzuki GS1100e: semi cafe racer project
SouthSideSlider is offline   Reply With Quote
