![]() My poor volvo ![]() after an hour of putting things back into position with a crowbar and stepping on the hood : ![]() So yep..... life sucks right now.
97' 850 GLT |
#2 | |
Location: ↓ Lynchburg, VA →| '84 242Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
If the air bag didn't go off, that is not bad at all. With access to the parts, it wouldn't take more than a few hours to fix that.
Did the bag go off?
still rides with MrDoug
![]() Join Date: Feb 2007
at least it wasn't a Renault Modus
-Matt 1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes. 1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s. 1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p. the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k. |
#4 |
No airbags didn't go off, I know its pretty simple I mean all I need is a new hood and headlight and to fix up the mount for the radiator. How fast do you need to be going to set off the airbag?
#5 |
#6 |
15mph I think.
'89 764 Bone Stock (for now) '87 XJ loaded with all kinds of crap
#7 |
#8 |
500$ plus a trip to macco should cover that. The inner structures can most likely be repaired DIY, but otherwise it wouldn't take a pro very long to do that part.
#9 |
500$ for what?
#10 |
Isn't it a function of deceleration, not a function of speed at impact? If I understand it right an accelerometer triggers the air bag deployment.
The BMW said "I am the ultimate driving machine!" and the Volvo wagon said "Oh really?" |
#11 |
I don't recall if Volvo used a spring type delcel, but I beileve they are calibrated for a 15 MPH single car impact with immovable object. So I 2 car impact will go off at a higher speed.
#12 |
Doctor Who
+1, but i think it also has to be at a minimum speed (15mph?)
![]() Hefty, rear-wheel-drive, and comfortable, the 700- and 900-series wagons were essentially an evolution of the 265 philosophy. Fun, boxy, fast, boxy, and fun. More right angles than a box full of right angles. BrickSpeed forums! |
#13 |
#14 |
Speed at impact is not the criterion, except with an immovable barrier (approxiamtely since there is a rebound effect that causes the speed change to be greater than the impact speed). Also, the damage appears to be above the level of the bumper/frame, and therefore to a less rigid area of the car and the deceleration occured over a comparatively longer time interval. The sensing mechanism on that vintage of vehicle is probably a spring and ball or spring and magnet arrangement to close a ground to arm the bag. This is the way the threshold is set. The term used is 'speed change'. In a car/car collision there is usually some post-impact speed of each and the change, in a co-linear collision (head-on or rear-end) is simply the difference between the impact speed and the post-impact speed. It is more complex in oblique or right-angle collisions because the sensor is aligned with the long axis of the car. Hence in a purely side impact the sensor will never arm the bag - they are meant to deploy in collision up to about +/- 30 degrees from frontal. The newer incarnations of airbag technology are more sophisticated than the spring/ball.
#15 | |
#16 |
Doctor Who
Ahhh, good to know. Perhaps less sophisticated, but appears to work well enough, if it didn't trigger in this case (probably when it shouldn't..).
So, what happened to the tahoe? Scraped the head-height 'bumper' a bit? gotta love how your bumper isn't even touched. I believe that there should be a standard height for bumpers, an that all vehicles must have one at that height. And on a somewhat unrelated rant, what is up with modern so-called 'bumpers', that are foam padded $800 panels? I tapped into someone leaving a parking lot a few months ago, and the lady gets out of her car, stares at her bumper, looks for scratches, and finally decides no damage was done. I literally TAPPED it, less than i've seen people do when parking. Come on, it's a freakin bumper. BUMPer. |
#17 | |
Please don't use the word "deceleration." There is no such thing, it's just acceleration in the opposite direction(of the vector). I taught physics at a Univeristy for a couple of years and that took us almost a month to pound into Freshman heads.
-Michael Tbricks build Quote:
#18 |
Doctor Who
But what about braking... how is that acceleration in any direction?
#19 |
It's been several years since I've done any write-ups on this stuff. But if I remember right we either showed it as acceleration in the opposite direction or as added friction. I believe in the case of a car it would be the later.
#20 |
Doctor Who
*nod* that makes sense. Though, take a look at 2. below:
deceleration noun 1. a decrease in rate of change; "the deceleration of the arms race" [ant: acceleration] 2. (physics) a rate of decrease in velocity [ant: acceleration] 3. the act of decelerating; decreasing the speed; "he initiated deceleration by braking" [ant: acceleration] |
#21 |
The professor that I taught with would have kicked you in the teeth for that She almost kicked me when I showed her something along those lines. I finally decided it was in my best interest to agree with the doctor in front of me than some guy that wrote the dictionary. |
#22 |
Doctor Who
Damn dictionary people...
I remember being told similar things in my physics class as well, so i think you are on the money. |
#23 |
Had the same beating in the Navy nuke school physics class
#24 |
Well nothing happened to the tahoe except a dent about the size of a quarter on his left side... and ya it was his bumper height that did all this sh**. Wish it would have been a civic in front of me. But anyways, I got charged for wreckless driving, that is 117$ ticket and 3 points on my license. The tahoe turned into my lane then slammed on his brakes cuz of the guy in front of him. w/e...
#25 |
| Thread Tools | |
| Display Modes | |
