Hi
I am wrestling with the K-jetronic. It is the type without Kat and comes from a B 230E.
the problem I am having is warm start:
After leaving the car sit for about 20 minutes it takes ages to get it back starting again, it could be 3 - 4 atempts.
What Have I done so far:
exchanged fuel pump: No betterment, When it did not start the next time I opened the fuel line to the cold start valve and found fuel under pressure there.
Changed the injectors with new seal rings: no improvement.
changed the complete unit to another: still the same
checked ignition, exchanged coil, power unit and measured currents -- all working OK.
Checked fuel pressure: OK
adjusted cold start air valve to open more: no betterment.
Checked everything for air leaks, none.
Adjusted co. still no betterment.
Valve and ignition setting perfect, good compression.
Maybe i am overlooking something --
any ideas?
any ideas?
