ASSFACEHOLE
Can I get away with running 110 leaded for a single track day? I have ten gallons, was unable to find unleaded local as of yet. I was thinking about using it as an additive. I know the risk is to the cat and the o2 sensor, neither of which I am attached to. Would prefer to run open dp but Sears point rules are that you have to have a full exhaust..
We're headed out at 10.. Any advice?
67' 220 84' Honda sabre v65 85' Ford Econoline E350 Box Van 90' 740 16v 90' 740 turbo (parts) |
bigpimpin740t@yahoo.com
pull the o2 and roll out
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com one down, whose next? |
ASSFACEHOLE
Just get a plug? Know what the thread is?
#4 |
Traitor
3/8 or 1/2" NPT works but isnt the official thread size. i forget which one it is(n't). buy one of each. its cheaper than a new O2 sensor
also, e-bay sells test pipes for like $30 if you want to save the cat. wont help tonite... but in the future.
'92 944 Turbo:13.400@99.68. Sold. '90 744 16 Valve. 16.317@85.55. Sold '92 244 http://pbase.com/740weapon |
#5 |
old spark plug??
that what I intalled in mine to protect the threads while welding the bung on... |
#6 |
i used a npt fitting from home depot before
#7 |
ARRRRHARHAR
![]() Join Date: Dec 2002
haven't had a problem with leaded gas and sensors. might shorten the life span but its unlikely that a single hit will wipe it out.
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! ported volvo heads |
#8 | |
bewst bewbies & chunga!
+1 if the sensors are relatively new (which they should be due to a stage zero) then everything "should" be fine. if you have the 10 yr old cat, it might sufer a little bit but who cares your gonna replace that anywya. |
#9 |
ASSFACEHOLE
Thanks for the input, I picked up the plugs. Once the car cools down a little bit I'll make sure the o2's broken free. Should I just roll up with an empty tank and go full race gas or mix it?
#10 |
ASSFACEHOLE
Gone in 13. I'm hoping for a low fifteen if I can get any kind of hook at all, I think I've gotten slower with the stick and bigger wheels but oh well.. Nice cold day. Wish me luck, I'll report back late tonight or tomorrow.
#11 | |
as far as the race gas, i would roll up on an empty tank. might as well get the best use out of the rg while you have it. |
#12 |
ASSFACEHOLE
86' 745. Mod list is short, 97' b230ft bored .60 over, milled thirty thou, 37# injectors, home made cai. Basically this is a baseline run.
*edit, m47 w/3.93 |
#13 |
1/4 mile?? :(
I was thinking "track" as in turns and braking late and all that fun stuff !!!! |
#14 |
the real Towery
yeah, me too. definitely don't worry about the O2 and cat then. A full day at a road course (the real "Sears Point") would still be OK.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting 1992 244 | The 92 |
#15 |
should be good for a baseline. how much boost you making? 10 psi? stock?
#16 |
unbalanced chemical
![]() Join Date: Jun 2002
leave the 02 in
I ran over 100+ gal of 110 leaded through my 02 and 50k later that 02 still passes smog just fine and returns 21+mpg
![]() Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
#17 |
I can automate that.
I didn't know you could still get leaded fuel
guess so...but not for long http://en.wikipedia.org/wiki/Gasoline ...fuel containing lead may continue to be sold for off-road uses, including aircraft, racing cars, farm equipment, and marine engines until 2008 http://www.epa.gov/history/topics/lead/02.htm good riddance
I think people think I think things that I don't think. "We can have democracy in this country, or we can have great wealth concentrated in the hands of a few, but we can't have both." Louis D. Brandeis "Religion is what keeps the poor from murdering the rich". - Napoleon Bonaparte |
#18 |
![]() Join Date: Oct 2004
Too late for now, but the thread is 18x1.5 IIRC. Plugs can be had easily enough at the local autozone/kragen/whatever chain store in the 'Help' isle.
For drag's I wouldn't worry about the cat or O2. Yeah, it'll shorten the life a little on each, but not enough to worry about. Good luck!! Go break something!
RIP Doug "Mr. Doug" Williams, 4/15/2009 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644). |
| Thread Tools | |
| Display Modes | |
