Not such a PRVert Anymore
![]() Update at bottom read and respond dammit!
The 260's dead and almost gone, just too unreliable, and not comfortable for long trips, looked at lots of turbo's and didn't like the top end power surge compared to a bottom end rise of power from my V6, so when I found out I lost my license, I bought this 760 from Angus as he was looking to sell it and I have time to get a car on the road and save a few bucks. I've replaced the injectors on one bank as one was causing a misfire and I got 6 from ebay and only 4 injector seal kits from FCP when I bought parts. The plans for this car currently are: Get it RWC'd (currently need to replace fan motor, front control arm bushes, and other odds and ends, otherwise not much else needed) Upgrade to Bilstien HD shocks front and rear with Kings springs on the front and the rear, but not sure which spring I should use as I don't want to be cutting anything. Alarm/remote central locking. Xenon headlamps Window's tinted. Stereo upgraded (will be using old headunit from old car as it worked great and the stock volvo one in this is useless) but after that planned Pioneer Head unit with JBL stereo components. Replacement interior (stock one is worn, replacement one for car is from an 85 and different shade) Might use 900 seats and door trim even though they won't match the tan interior. S90 door handles. 900 cruise control. I still have the manual box from my old car and that will eventually go in, maybe once I've gone to MS or shortly before my 24V motor is ready to slot in and blow the diff up :p ![]() How it could look. ![]() ![]() ![]() Paint will come up really nice with a proper cut and polish. ![]() ![]() Interior needs a lot of work, parts to replace it ready. ![]() ![]() Has a little panel damage. ![]()
#2 | |
![]() 24v??????? What did those come in, and are they PRVs, just developed a bit more?
Any pictures?
#3 | |
![]() Quote:
more info please!
rofl |
#4 |
![]() 24v PRV's came in Citroen's... They had something arround 200hp.
For example: Citroen XM V6 24V http://ultimatespecs.com/?option=4&b...l=450&car=1944 Alex, I've just bought a 760 GLE V6 to... Mine is from '90 and have the Independent Rear Suspension with the self leveling system. I suppose that your's have it to. If yes, are you planning to lower yours? ... how?? |
#5 | |
![]() Quote:
#6 |
![]() Have 940 black leather interior now and converting the later door trims to fit the earlier kind is dead easy, there is two holes in the bottom of the door or near the bottom and they are covered with a plastic cover, cut the inisides of the plastic bit out and they just go in.
Stripped interior out, not sure if I use grey carpet or tan, still tossing up over it. Need to get suspension bushes replaced asap as well really want it rego'd. |
#7 |
![]() Interiors in, think I'll put in the tan carpet door pockets and glue on the tan carpet on
the rear doors, too much grey still. ![]() ![]() ![]() ![]() ![]() Also need to mount the rear seat correctly and the headrests. ![]() Seat comparison. ![]() ![]() 3.5" JBL GTO speakers for the dash, sound brilliant! ![]() Now has 740 GL tails, which are older and are a different plastic that resists fading more. ![]() Installed Pioneer 50WX4 with 2 rca out HU. ![]() LED numberplate lights! The things soon to be fitted to this car is: Bilstien HD shocks front and rear. Low Kings springs on the front and the rear. Alarm/remote central locking. Window tint. S90 door handles. Cat-back exhaust (current one stuffed) K&N filter (ease of maintainence) Front and rear brakes changed (fronts ebc greenstuffs with slotted rotors, rears above average brakes and pads) as well as E/brake pads. Stainless Steel brake lines. Ordered the Bilstien shocks from the US, Kings springs do stock height 200lbs IRS springs, which I'll be ordering reset 30mm lower to match the front, replacing front and rear brakes as well as handbrake pads, SS brake lines as I plan to push the brakes because of the good suspension, and yeah, it's really shaping up to be finished soon (before the middle of feb). Last edited by VQ; 02-03-2008 at 01:41 AM.. |
#8 |
![]() Since no-one posts in here i'll just do a non visual update as my phone doesn't want to talk to my computer to be able to upload pics, however, the car now has tinted windows (35% all around), my Bilsiten HD's are in and I'm putting a hotdog muffler on the rear after the diff, just to save effort and money.
Alarm will be installed in the next day, front brakes were replaced and look awesome, if they weren't hidden :p and my rear brakes were fine, but I still replaced them, anyone want a complete set of rear handbrake pads? I have no need for them as mine were hardly worn even after 315,000km's... However I REALLY want to work out why the ABS light comes on and why the speedo works only on full or no throttle... |
#9 |
![]() As my phone hadn't been talking with the computer I haven't been able to post any visual updates, but now I can cos its working and I've been busy as I've been on holidays for a week.
First things first, I had my windows tinted. ![]() Ashcool tint, was quite cheap and supposedly has a lifetime warranty. I bought a PWR V8 transmission oil cooler as I want to extend the life of the transmission if I can. ![]() 250X200X60mm I think it is. K&N air filter. comparing width to a paper one. ![]() Whats in this box from America? ![]() Bilstein HD's! ![]() ![]() Fitting them to the front with King Springs (which are meant to be 30mm lower) and are 160lbs front springs with new strut top. ![]() Compared to stock spring. ![]() Been mentioned in the installation guide from the Brits, but the stock tube is so thin and lacks pressure! ![]() Assembled strut ready to go in. ![]() Fitted. ![]() Approx 10mm lower then stock blown dampers with stock springs. ![]() The rear end was a bit trickier, in that the shocks don't just bolt in because of the nivomat mount on the bottom. What I did was get the mount out of the nivo and pressed out the center from the lower half of the Bilstiein HD which then had the part mount from the nivo pushed in, fits perfect. The rear springs for IRS are the catalog King Spring's springs, but because they don't do low's like on live axle 700's due to not being able to combat the camber, they only sell stock height, but you can then pay to have them reset lower, which I did, and of course unlike the live axle 700 stuff and the front of mine, they actually lowered the rear.... Anyway on with the pics! Replacement shocks and springs. ![]() Mount after it had been pressed out from the Nivo insert and all the rubber removed with wire wheel. ![]() Shock with the centre bush pressed out ready for the nivo mount. ![]() Mounted to the car. ![]() Comparison of springs. ![]() Stock. ![]() New shock and spring ![]() ![]() ![]() Camberrrrr (anyone know how to correct it? I like the look, but Im worried about tyre wear.) ![]() ![]() I also did the front and rear brakes, no pics of the rear though. Worn out and stock yuck. ![]() Slotted Rotors and EBC greenstuff pads yummy. ![]() ![]() The car now handles great, has a compliant ride and isn't too stiff IMO, and it brakes well too, SS lines will go on once car is rego'd. General pics of the car. Up on stands at work waiting for the front wheels to have it's tyres swapped from the tyre shop. ![]() ![]() ![]() ![]() ![]() ![]() Still got heaps to do cosmetically inside and out, but I did the fuel door on today! ![]() Roadworthy and registration will be happening in the next week with any luck... |
#10 |
![]() rear camber doesnt look terrible....and looks to have settled out a bit. it happens when you lower the irs
-Billy Volvoless for the first time since 1990... ![]() 2002 Toyota Avalon XLS (comfy gradma car) 1996 Chevrolet Tahoe LS 2WD (hauls ass) 1990 Mazda Miata (track toy) |
#11 |
![]() Got a new windscreen on, such a major difference, as the old one was original, and sand blasted badly, car won't pass roadworthy with that much camber on one side, need a wheel alignment and to change the lower control arms for the sway bar ones, which should have nicer bushes in, otherwise I am needing to replace the top ones.
Car now accelerates from a standstill, but still runs pig rich, I'll be changing the AMM ASAP basically. |
#12 |
![]() Still waiting on parts from FCP for the suspension arms, considering I asked for them, he did the diff bushes. Put a bit more of the interior together so it now is more complete and that's about it sadly, I really really really want it on the road though.
#13 |
![]() Well a small update.
Car is at home, fitted decor panel and eventually got the engine running normal no, changed the fuel pump, FPR, ECU, O2 sensor again, and made sure all the vacuum lines were sealed. No longer rich running! ![]() ![]() Finished the interior off more. ![]() Have been scrubbing these back to coat them with heaps of lacquer as I like shiny suspension parts, for the IRS sway bar. ![]() ![]() Sadly it's not alloy. |
#14 |
Benchracer Tribe
![]() I may have an AMM off a PRV Volvo, LH 2.2. You are welcome to it though I have no way to test the bloody thing.
"you can't leave your thingy hanging in public... you can get arrested." "What's Arkansas supposed to be, Kansas for pirates?" Forg "I think I can touch the tire. Damn! I can touch the tire! That hurts!" 240Psycho (on the back seat of my 94 Jetta while I was driving to a J/Y) "Use the barbed adapter like what I use to inflate the air camping mattresses and my dates." FTF Engineering i am inspired. i will replace my windsheild... with an intercooler.swedishK Feedback! |
#15 |
![]() The car is registered finally!
Still need to get new bumpers and paint them and the mirrors, fit new door trim from a s90, s90 door handles (only thing I actually have ready to go on), basically LOTS of work. Also need to get some taller stiffer springs for the rear once I get my tax money too. Goes well, handles very well for something so big and looks awesome IMO. Sorry for the dodgy pics but can't take anything decent till the weekend. ![]() ![]() ![]() |
#16 |
![]() Well done...its got number plates.im sure you have alot of cruzin to do.looking good
#17 |
![]() What. There aren't anymore headlight wipers.
#18 |
![]() piiimp.
i have been looking for something similar for a while now but i think i am going to go down the s90 v70 track. maybe even 960. i love these. its good to see you restore it to the glory it should be! good job |
#19 |
![]() Looking great Alex, when I first bought the car I had a visions of making it into something nice, then it was going to become a daily driver, then I realised I had too many projects already, and I'm glad you're putting in the effort to make it into something decent.
Headlight wipers are pretty pointless here, it never snows and the roads aren't dirty enough for the headlights to need regular cleaning.
I have over 300 parts for sale to suit 100, 200, 700 and 900 series Volvo's, for more info see: http://zyrex.org/gallery/Cars/acw/volvoparts/ Updated April 21st 2016. |
#20 |
![]() Thanks Angus and others, the car is far from perfect, the auto isn't right, it make a few noises from the wheels, the LH 2.2 isn't much better then KJet. And the bodywork is far from perfect, but mostly I can replace them, only the rear quarters have small dents and the big dent above the taillight that I need to fix eventually.
Next to do:
This photo is taken of the car on my 1/3 hill with a 8 draw tool chest in the boot, weighing less then a full size adult. ![]() The rear is 2 inches lower then stock and the front is about one, I also want that evened up. Maybe even lower on the front.... ![]() ![]() And this is my current passenger side indicator as the real one fell out during some spirited driving, and I'm waiting on LT to get me a pair of the 89> headlamps as there aren't any at the wreckers in Melbourne. ![]() |
#21 |
![]() I love the top pic, it looks good, even if it's totally impractical.
That pic on the country road isn't Bulban Road near Werribee by any chance? The trim panel between the tail lights makes the car look better, I'm glad mine came with one. I love the indicator, very TB ![]() |
#22 |
![]() I wouldn't trust king springs on a big volvo.. I mean maybe a 240 but never a 7/9/8, there is just something not right about it, to heavy, to much bodyroll maybe. I think the rates are far to soft. I used to have that Ford Fairmont, ultra lows in the back and it went down a similar amount under load
#23 |
![]() It went down because they are shorter by 30mm then what they recommend and they don't sell lows for the IRS as it can't correct the camber, keep in mind the stock springs are jsut there to sorta hold the body and the Nivomats do the work, but I got rid of them.
But the king springs are just fine, 160lb's in the front and I'll be going stiffer in the rear, ordered the new springs which are far cheaper then what these cost me. Lots of Aussies use them as they are local and cheapish and good quality, the fronts I like, just yeah they haven't put much effort into the rear ones. And remember is has Bilstien HD's. My 760 is maybe 150kg's heavier then the 264 was, so they aren't that much heavier either. Very little bodyroll as well compared to even new cars. And yeah it that road I believe, after the racecourse, the indicator fell off while I did a slight speed run on there. Didn't go that fast really either. With that weight in the boot I think most of the rear of the car scrapes the bottom of the driveway, but only on the rear. |
#24 |
![]() Yeah i think its only the rear i would worry about, the front seems fine and there wouldn't be much difference between that and a 264 its the just the rear I am wary of, I think its just because all irs's i've seen with binned nivo put extra pressure on the springs. how much did you get the bils for? I bet they make one hell of a difference! haha. whenever i do shocks i try to do it right, it makes the suspension combo. i remember my golf was so bouncy
#25 |
![]() Heh, they cost a bit under $700 with postage at the time, almost half of it was postage somehow. annoyingly.
The difference of the handling between this car stock and my 264 is comparing a hovercraft to a boat, so much body roll at speeds the stock suspensions didn't roll at on the 760, and with the stiffer suspension it will go through corners three times faster then what my 264 would. If not faster when I put some wider tyres on. Doesn't understeer like the 264 did doing a fast U turn at all, but that could be because of the 205/60's I had on there and this has 195/60's... |
