Old 12-11-2007, 04:07 PM   #1
paulofvf
paulofvf's Avatar
Default 940....stumbles,misfires, hesitates...jerky acceleration
Iīve been having a problem on my 93 940 b200ft ...
the car runs fine on LPG , but it runs badly when on petrol, under load
symptoms are:when on petrol, i hit the gas and it will hesitate ....as if the mixture is too rich or sometimes he will just stop revving ....and feel as if i had hit an invisible wall
if i keep pressing the accelerator it will continu to hesitate and make some bump noise somewhere in the front .....then around 2500rpm it will return to normal, and later between 3500/4500rpm will feel again like hesitating
under acceleration sometimes it misfires a lot , sometimes it misfires less........i hear some kind of backfire in the air filter box when this happens..or so it seems
what do you think it could be??
"If you overtake iīm going to follow you home and sh!it in your slippers"
93 Volvo 940 b200ft (sold)
91 Volvo 940 d24tic (sold)
89 Volvo 245 d24tic turbolook black
88 Volvo 745 b200et
70 volvo 142 b20A
02 Volvo s60 2.0t
91 miata
97 e36 320i
91 VFR 750 rc36
95 VFR 750 rc36 II
01 ducati 750SS
paulofvf is offline   Reply With Quote
Old 12-12-2007, 08:01 AM   #2
paulofvf
paulofvf's Avatar
today it was worst, but after a few acellerations it became better, then worst again
do you think it could be the fuel pump relay?
Old 12-12-2007, 08:57 AM   #3
NitroX5
NitroX5's Avatar
my symptoms are the same as your
http://forums.turbobricks.com/showth...y+acceleration
inside my opinion
'98 S70R B5254T K24, H-rods, P&P Head, SS 3" exh, R mani, FMIC, Alfa BBK, D2 coilovers,Pegs, Dynaudio system, Emanage/VEMS
Project:B5244T3 Ported RN head, HRC 20G
740 '90: T5 swap: B5254T 19T, VEMS
Oldest setup: 740 1987 TIC '91 B230FT
Full 3" SS exhaust
Prt & plsh 531 38exh, A-cam
19T Prt&Plsh a lot @ 18PSI
MSnS II 4a year--> Fred Chips
M90, Sachs Racing PP,kevlar clutch
G80, adj Koni's, Dual sways
Siemens 65lb,Walbro 255,JAW WBO
760 tail lights,Polaris,HID's, E85Conversion
NitroX5 is offline   Reply With Quote
Old 12-12-2007, 09:05 AM   #4
paulofvf
paulofvf's Avatar
inside my opinion
yep!!! kinda like it, in mine it takes longer to rev again, and car becomes more hesitating....
here in Portugal, a friend of mine from a portuguese volvo forum told me it could be the fuel pump relay, have you checked it? i have to check mine!!
i run my 940 on LPG and it runs fine!! only does that when on petrol , iīve changed spark plugs,
Old 12-12-2007, 09:33 AM   #5
NitroX5
NitroX5's Avatar
I can do more hesitate, but i get off the throttle for a while(usually), but if i keep forced-pushing henceforward the car jerk all the time.
I didn't check the relay since 3 month:D . I think is good or possible the coil surface burned, and not support enough volts to pump??
Old 12-18-2007, 10:42 PM   #6
paulofvf
paulofvf's Avatar
been noticing that the problem is getting worse......it only revvīs if i go gently on the throttle......., that means that i canīt go uphill
by the other hand, once the RPM are above 4000 or so, it revs a lot better....
do you think it could be bad mixture????
Old 12-18-2007, 10:45 PM   #7
slowmotion
slowmotion's Avatar
I think that's just vac leaks somewhere. Mine behaves very much the same when there's a leak.
Does the LPG system use the AMM? Could be that too.
slowmotion is offline   Reply With Quote
Old 12-18-2007, 10:52 PM   #8
paulofvf
paulofvf's Avatar
but if it was a vac leak then it would do the same when on LPG? or not?
i really donīt know if the LPG uses the AMM....but i think it doesnīt! it flushes the LPG directly through the ....intake (i think it is called that way)
Old 12-18-2007, 10:56 PM   #9
slowmotion
slowmotion's Avatar
Try unplugging the AMM and see if the problem is the same or worse (when using petrol).
i.e. If the AMM is good, it should run a LOT worse unplugged.
Old 12-18-2007, 10:58 PM   #10
paulofvf
paulofvf's Avatar
will try that tomorrow (itīs already 3a.m here in portugal)!
Old 12-19-2007, 11:14 AM   #11
sweetswede
sweetswede's Avatar
have you tried changing plugs?
Originally Posted by kyle242gt View Post
You made neither a Volvo symbol nor a pair of titties?
You sir, are a disappointment.
sweetswede is offline   Reply With Quote
Old 12-19-2007, 11:26 AM   #12
paulofvf
paulofvf's Avatar
theyīre new!
Old 12-20-2007, 12:39 AM   #13
paulofvf
paulofvf's Avatar
today i removed the fuse from the LPG system......and it started running fine on petrol!
so i believe the problem is due to the LPG........WTF?!
Old 12-20-2007, 01:10 AM   #14
HonestJhon
HonestJhon's Avatar
maybe both fuel systems are running at the same time?
HonestJhon is offline   Reply With Quote
Old 12-20-2007, 01:41 AM   #15
paulofvf
paulofvf's Avatar
that is what i think itīs happening when running on petrol!
but when i run LPG everything is fine!
by the other hand, if i take the fuse, it runs fine on petrol, but i canīt run on LPG
Old 12-21-2007, 05:19 AM   #16
zacharyblackwagon
yo-
spray some water or carb cleaner on the injectors when your car is idling... listen for change in rpm.. i was having real similar problems as you and it turned out to be a leaky injector seal. Also, wiggle some wires and see if anything odd happens.
good luck.
zacharyblackwagon is offline   Reply With Quote
Old 12-23-2007, 02:55 PM   #17
fige
KING OF TBOT
fige's Avatar
My car had some stuttering problems etc. I replaced the ignition coil. and it worked
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
